Fuel Pump Wire, Ground? |
trojanhorsepower |
Nov 17 2019, 07:55 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
So, I moved the fuel pump to the front of the car and ran a wire back to the engine compartment. What do folks do with the dangling ground wire? Same with the brake switch. Two wires one connector, so what did you do with the other wire?
Thanks Peter |
Highland |
Nov 17 2019, 08:54 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I don't think you need the one in the engine compartment. Just insulate it so it doesn't short against any adjacent hot wire.
At least that's what I'm doing unless the experts here say otherwise. (IMG:style_emoticons/default/confused24.gif) |
Jonathan Livesay |
Nov 17 2019, 10:21 PM
Senior Member Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
I don't think you need the one in the engine compartment. Just insulate it so it doesn't short against any adjacent hot wire. At least that's what I'm doing unless the experts here say otherwise. (IMG:style_emoticons/default/confused24.gif) Yes, don't need it, ground is ground. Run a wire from the + side of the fuel pump plug under the engine shelf up through the tunnel and to where ever you have mounted your fuel pump plug it to the positive side of the pump and then just ground to the nearest ground stud (anything with brown wires connected to it). |
Lo-Fi Version | Time is now: 1st June 2024 - 09:59 PM |
