> Why not use bushing grease on a-arm bushings?
Tdskip
post Nov 16 2019, 01:01 PM
Hi guys - I know how it is commonly done including Ian’s great video. Is there a reason why not to use bushing grease instead of softsoap?
So you want the bushing NOT to move or rotate ones installed? I assume that is a reason but wanted to ask.
Thanks.
Tdskip
post Nov 18 2019, 06:55 AM
As a sidenote to this discussion on the British cars that I’ve worked on, specifically MGB and Triumphs and Healeys The reproduction rubber bushings or atrociously bad, they will crack and degrade even if the car sits in a temperature controlled garage. As a result I only use poly bushings when I do maintenance on the suspensions and as Dylan has said there are a range of different compliance available. On those cars at least I would never use anything other than poly.
Tdskip   Why not use bushing grease on a-arm bushings?   Nov 16 2019, 01:01 PM
Chi-town   petroleum based greases will degrade rubber   Nov 16 2019, 01:30 PM
914werke   An alternate to soap would be Glycerin   Nov 16 2019, 01:56 PM
Tdskip   Hi guys - happy Saturday. What about standard sil...   Nov 16 2019, 02:47 PM
IronHillRestorations   KY works great on factory rubber bushings   Nov 17 2019, 06:33 AM
bbrock   The press fit of the original rubber bushings is s...   Nov 17 2019, 09:37 AM
Tdskip   The press fit of the original rubber bushings is ...   Nov 17 2019, 10:43 AM
jmitro   So you want the bushing NOT to move or rotate one...   Nov 17 2019, 11:03 AM
Superhawk996   So you want the bushing NOT to move or rotate on...   Nov 17 2019, 11:44 AM
Tdskip   Great discussion, thanks   Nov 17 2019, 11:59 AM
Chi-town   Or just use a quality poly bushing like Powerflex ...   Nov 17 2019, 03:33 PM
Superhawk996   Or just use a quality poly bushing like Powerflex...   Nov 17 2019, 04:04 PM
Tdskip   Well - tried the URO bushings and they kept deform...   Nov 17 2019, 04:17 PM
Superhawk996   Well - tried the URO bushings and they kept defor...   Nov 17 2019, 05:02 PM
bbrock   Well - tried the URO bushings and they kept defor...   Nov 17 2019, 06:11 PM
Tdskip   @Superhawk996 - thanks for the detailed response....   Nov 17 2019, 05:22 PM
Chi-town   When a rubber bushing binds it acts as just like t...   Nov 17 2019, 09:23 PM
jmitro   It also doesn't bind like the rubber stock un...   Nov 17 2019, 11:32 PM
Mikey914   The OEM are intended to set a zero preload on the ...   Nov 17 2019, 09:45 PM
Chi-town   If you get a Powerflex bushing to bind you have do...   Nov 18 2019, 12:39 AM
Mikey914   If you get a Powerflex bushing to bind you have d...   Nov 18 2019, 10:54 AM
914bub   They are torsilastic bushings. ...   Nov 18 2019, 01:00 AM
Tdskip   As a sidenote to this discussion on the British ca...   Nov 18 2019, 06:55 AM
IronHillRestorations   The factory front bushings are relatively cheap, ...   Nov 18 2019, 07:18 AM
Chi-town   If you set up the bushings according to the angles...   Nov 18 2019, 03:04 PM
Mikey914   We are making the rears now and will be ready in a...   Nov 18 2019, 03:56 PM
Chi-town   We are making the rears now and will be ready in ...   Nov 18 2019, 04:00 PM
Mikey914   We are making the rears now and will be ready in...   Nov 18 2019, 09:11 PM
Superhawk996   There is a obviously a heated debate of poly vs. r...   Nov 18 2019, 07:25 PM
Chi-town   Modern rubber bushing design is completely differe...   Nov 18 2019, 10:56 PM
Mikey914   EPDM that was used on the OEM parts has stood up f...   Nov 19 2019, 12:40 AM
Superhawk996   The ultimate design would be to go to a roller b...   Nov 19 2019, 05:21 AM
Chi-town   I completely agree with @Superhawk996 on this on...   Nov 19 2019, 10:11 AM
Mikey914   We are trying to restore our 75 bumpers and notic...   Nov 19 2019, 10:45 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:35 AM
