> CV Joint, 12-pt bit size for bolts?
dcecc1968
post Nov 19 2019, 08:52 AM
Can't seem to find a reference for the size of this bit. Thanks for your help.
-Don
injunmort
post Nov 19 2019, 09:18 AM
triple square size 8
wndsrfr
post Nov 19 2019, 09:51 AM
QUOTE(injunmort @ Nov 19 2019, 07:18 AM) *
IMO replace them with 6point allen head and cross drill the heads for safety wire. Somebody here sells them...
jcd914
post Nov 19 2019, 10:36 AM
QUOTE(wndsrfr @ Nov 19 2019, 07:51 AM) *
IMO using 6 point Allen bolts is a mistake. In my experience the allen heads strip much easier than the 12 point triple square bolts. The triple square drive was designed to handle more torque than the older design of the allen heads.
The key to being successful with either style bolt is cleaning the heads of the bolts out so the tool fits all the way in so you have full engagement. Also make sure the threads on the bolt and in the bolt hole are clean when you assemble them. And use a torque wrench to get the correct torque on them.
The safety wire is a very good idea but kind of a PITA to wire them.
Jim
dcecc1968   CV Joint   Nov 19 2019, 08:52 AM
jcd914   Can't seem to find a reference for the size o...   Nov 19 2019, 09:11 AM
mepstein   My local FLAPS had 4 different size bits for about...   Nov 19 2019, 09:16 AM
injunmort   triple square size 8   Nov 19 2019, 09:18 AM
wndsrfr   triple square size 8 IMO replace them with 6poin...   Nov 19 2019, 09:51 AM
jcd914   triple square size 8 IMO replace them with 6poi...   Nov 19 2019, 10:36 AM
Olympic 914   The key to being successful with either style b...   Nov 19 2019, 12:30 PM
rick 918-S   The key to being successful with either style ...   Nov 19 2019, 12:37 PM
bdstone914   [quote name='wndsrfr' post='2763302' date='Nov 19...   Nov 19 2019, 12:37 PM
Chi-town   triple square size 8 IMO replace them with 6poi...   Nov 19 2019, 10:24 AM
dcecc1968   Appreciate it fellas!   Nov 19 2019, 10:30 AM
ClayPerrine   :agree: If you follow the factory procedure to r...   Nov 19 2019, 12:50 PM
cuddy_k   Triple square bolts are harder to strip if the fe...   Nov 19 2019, 03:04 PM
dcecc1968   Great advice as always fellas!   Nov 19 2019, 09:12 PM
Rob-O   :agree: If you follow the factory procedure to ...   Nov 19 2019, 10:15 PM
Tdskip   As others have suggested you REALLY need to make s...   Nov 20 2019, 10:56 AM
Mikey914   Or start by hand and get 3-4 turns in before going...   Nov 20 2019, 11:12 AM
Rob-O   Or start by hand and get 3-4 turns in before goin...   Nov 20 2019, 12:32 PM
Valy   Allen bolts are a mistake. Use the original bolts...   Nov 21 2019, 01:23 AM
- Lo-Fi Version Time is now: 25th October 2026 - 10:00 PM
