Clutch, oil-return tube O-rings done--lessons learned, etc, And a big THANKS to "wndsrfr"! |
anderssj |
Nov 22 2019, 08:58 AM
Dog is my copilot... Group: Members Posts: 1,664 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Good morning!
After a couple of semi-crappy experiences with shops in the local area, I've decided to take the plunge and fix my slipping clutch and leaky oil-return tubes myself--with considerable help, guidance, and moral support from "wndsrfr." (IMG:style_emoticons/default/first.gif) As a first step, I'm cataloging all the parts, bits, and pieces I think I'll need--but if it looks like I've left anything out, please let me know. 1. Clutch kit from Pelican--the one that includes a new flywheel. I've gone back through all the maintenance receipts and while I see at least one re-surfacing, it looks like the flywheel has never been replaced. I figure it's time... 2. Flywheel/crankcase seal (black Sabo piece from GoWesty). 3. I have a set of black Viton o-rings from a friend here on 914world, so I should be good to go. That said, should I consider new push-rod tubes (like the Dansk ones from Pelican)? I like the thought of the stainless ones from Chris at tangerine, but $$$--on the other hand, Christmas is only a little over a month away... (IMG:style_emoticons/default/santa_smiley.gif) 4. A case of Guiness. 5. New valve cover gaskets (OEM cork? Or the thicker ones from Mikey?) 6. New copper heat exchanger seals/gaskets (Victor Reinz @ Pelican?). 7. New copper flange nuts for heat exchanges from BelMetric (NCF8X12 - Copper Flange Nut): https://www.belmetric.com/hex-with-flange-c...-nut-p-189.html 8. New 8mm Schnorr washers for CVs (and maybe a couple of new CV bolts just in case). 8. A case of Guiness. 9. I'll probably do new motor and transmission mounts "while I'm in there." Looks like original 914 motor mounts are still available, but not trans mounts. Thinking of using 911 "sport" engine mounts (911-375-043-00) for the trans, but open to recommendations (Wevo "black cushion"?) 10. Transmission leaks slightly from the big black cover at the shift console, so will do the o-ring and seal while the transmission is out. That's what I have so far. Am I missing anything? Do I need more Guiness? (IMG:style_emoticons/default/beer3.gif) Appreciate your inputs (the support and expertise here on this site is amazing)! (IMG:style_emoticons/default/beerchug.gif) Thanks in advance, Steve A- |
anderssj |
Nov 22 2019, 07:16 PM
Thanks! I'm adding these things to my shopping list.
BTW, John likes Guiness, hence the over-supply. I'm more of an IPA guy myself (my son says IPA is like the "boomer's" pumpkin spice). Thanks again! |
bdstone914 |
Nov 23 2019, 08:45 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@anderssj date='Nov 22 2019
I have replated pushrod tubes for about haft of the new price. You also need the crush plate under the flywheel bolts, felt washer and pilot camshaft guide bearing. Bruce |
anderssj |
Nov 23 2019, 09:51 AM
@anderssj date='Nov 22 2019 I have replated pushrod tubes for about haft of the new price. You also need the crush plate under the flywheel bolts, felt washer and pilot camshaft guide bearing. Bruce Thanks Bruce! I'll PM you in a few days... Obviously I need to look up a few parts whose name I don't know ("pilot camshaft guide bearing") (IMG:style_emoticons/default/blink.gif) Is that the 111-105-313 pilot bearing? And the crush plate is the one with the 5 holes, correct? Still looking for transmission mounts. Seems like the only OEM style out there now are Uro-branded parts... May go with Wevo with black cushions. Also, any recommendations on which kind/brand of input shaft seal to use? Thanks again! Steve A- |
Lo-Fi Version | Time is now: 10th June 2024 - 07:16 AM |
