> Suspension and Brake Refresh, New Wheels and Suspension Adjusted
tvdinnerbythepool
post Oct 9 2019, 10:55 AM
Back is done, on to the front (later in this thread)
Hey guys,
Starting winter projects: Rear Brakes/Suspension are up first.
-This is a street/daily driver. Just trying to get the sagging ass up and improve the ride quality. -
So far I've got New:
100lb Weltmesiter 914rubber Springs
914rubber upper and lower shock rubber bushings
Plan is to buy:
KYG 9003 Bilstein Struts
Rear control arm bushings (914Rubber)
Rear Caliper Rebuild Kit (If that seems beyond me I will send to PMB)
Discs and Pads will be addressed as needed once I get it all apart. Turn the discs if needed or replace with new pads. We shall see.
Any suggestions on anything else with the rear brakes/suspension??
Thanks all! -Rob
Front Suspension/Brakes will be part 2 of the project. Just trying to keep it manageable and on budget ish
tvdinnerbythepool
post Nov 16 2019, 07:05 PM
Starting to see some progress and feeling like I didn't ruin everything and she may drive once more. Lol!Attached Image
post Nov 23 2019, 01:36 PM
914-6 GT in waiting
QUOTE(tvdinnerbythepool @ Nov 16 2019, 08:05 PM) *
I'm curious about the rear shafts. None of the ones I've taken apart seem to have washers on the ends of the shafts. Is that correct?
tvdinnerbythepool
post Nov 23 2019, 02:07 PM
QUOTE(mepstein @ Nov 23 2019, 11:36 AM) *
@mepstein
I put the washers on there...it just feels wierd to not! Should I take them off? Was there a reason to NOT use a washer?
tvdinnerbythepool   Suspension and Brake Refresh   Oct 9 2019, 10:55 AM
mepstein   Just say NO to KYB struts. Spend the money on Bils...   Oct 9 2019, 11:01 AM
SirAndy   Just say NO to KYB struts :agree:   Oct 9 2019, 12:02 PM
914_teener   Hope your budget is $1800. Might as well do...   Oct 9 2019, 11:51 AM
Tbrown4x4   PMB is the benchmark for caliper rebuilds, but I h...   Oct 9 2019, 05:13 PM
rhodyguy   Better off spending more now rather than might bei...   Oct 9 2019, 05:31 PM
roblav1   As others said, don't use KYB.   Oct 9 2019, 06:23 PM
914Sixer   KYB= Kill Your Back. If you want to feel every pe...   Oct 10 2019, 04:22 AM
tvdinnerbythepool   Awesome, thanks for the input guys. Sounds like K...   Oct 10 2019, 07:40 AM
tvdinnerbythepool   @Tbrown4x4 did I see you by the Olympia airport a...   Oct 10 2019, 07:41 AM
Tbrown4x4   I was down that way for a wedding , but we took th...   Oct 11 2019, 04:54 AM
tvdinnerbythepool   Hey guys! I've seen a few methods online b...   Oct 24 2019, 10:24 PM
mepstein   Hey guys! I've seen a few methods online ...   Oct 25 2019, 06:13 AM
914werke   From that pic it looks like you may have more work...   Oct 25 2019, 12:24 AM
Tbrown4x4   I'm reading that you are blasting the calipers...   Oct 25 2019, 05:01 AM
tvdinnerbythepool   @914werke for sure! It was a ton of work just...   Oct 25 2019, 09:59 AM
tvdinnerbythepool   1 down! Took about 40 minutes with heat and pr...   Oct 25 2019, 10:49 AM
TonyA   Like that operating room clean look of your shop....   Oct 25 2019, 01:31 PM
mepstein   Mine took 5-10 minutes each side but I really laid...   Oct 25 2019, 11:17 AM
914werke   :( Mmmm IDK... I chuck them up in the lathe ...   Oct 25 2019, 11:42 AM
tvdinnerbythepool   Calipers stripped, blasted and painted. Will repo...   Oct 31 2019, 08:14 AM
Tdskip   It will be. Like all vintage German cars 914s resp...   Oct 31 2019, 10:12 AM
tvdinnerbythepool   RE: Suspension and Brake Refresh   Oct 31 2019, 10:28 AM
tvdinnerbythepool   RE: Suspension and Brake Refresh   Oct 31 2019, 10:29 AM
tvdinnerbythepool   RE: Suspension and Brake Refresh   Oct 31 2019, 10:30 AM
DucRS   Calipers are looking good! Please chime in o...   Oct 31 2019, 11:10 AM
mepstein   Here’s Eric’s /PMB Performance video for rebui...   Oct 31 2019, 11:18 AM
tvdinnerbythepool   @ducrs I followed the pelican disassembly article...   Nov 1 2019, 07:30 AM
mepstein   I’m pretty sure all the calipers had nuts for th...   Nov 1 2019, 07:34 AM
tvdinnerbythepool   I’m pretty sure all the calipers had nuts for t...   Nov 1 2019, 07:45 AM
mepstein   [quote name='mepstein' post='2758729' date='Nov 1...   Nov 1 2019, 07:55 AM
bbrock   I’m pretty sure all the calipers had nuts for t...   Nov 1 2019, 08:00 AM
mepstein   [quote name='mepstein' post='2758729' date='Nov 1...   Nov 1 2019, 08:48 AM
tvdinnerbythepool   Drivers side sans nuts   Nov 1 2019, 07:46 AM
tvdinnerbythepool   Drivers side caliper rebuilt! Still sourcing b...   Nov 5 2019, 07:46 PM
eatpez   Drivers side caliper rebuilt! Still sourcing ...   Nov 5 2019, 08:00 PM
Tbrown4x4   Yes, those look great!   Nov 5 2019, 09:34 PM
914werke   Shafted!   Nov 7 2019, 02:14 PM
TargaToy   Shafted! I've been curious, since you m...   Nov 15 2019, 02:32 PM
tvdinnerbythepool   914Rubber 100lb Springs on Bilsteins :headbang...   Nov 13 2019, 09:45 AM
mepstein   914Rubber 100lb Springs on Bilsteins :headban...   Nov 13 2019, 10:27 AM
tvdinnerbythepool   914Rubber 100lb Springs on Bilsteins :headba...   Nov 13 2019, 11:29 AM
type2man   If you already have the rear arms out, I would def...   Nov 13 2019, 06:26 PM
tvdinnerbythepool   Bearings are in! Going to make a threaded to...   Nov 14 2019, 11:11 PM
tvdinnerbythepool   Maybe a stupid question...how do I know when the h...   Nov 15 2019, 11:55 AM
tvdinnerbythepool   Should the hub shaft be flush with bearing??   Nov 15 2019, 11:56 AM
Tbrown4x4   The shoulder on the hub will bottom out on the inn...   Nov 15 2019, 01:14 PM
914werke   If you look at the process for installing either t...   Nov 15 2019, 03:35 PM
TargaToy   If you look at the process for installing either ...   Nov 15 2019, 03:59 PM
Mikey914   Actually when Elephant made their rods they used a...   Nov 15 2019, 06:19 PM
914werke   Actually when Elephant made their rods they used ...   Nov 16 2019, 12:21 AM
Mikey914   Actually when Elephant made their rods they used...   Nov 16 2019, 11:22 PM
tvdinnerbythepool   Starting to see some progress and feeling like I d...   Nov 16 2019, 07:05 PM
mepstein   Starting to see some progress and feeling like I ...   Nov 23 2019, 01:36 PM
tvdinnerbythepool   Starting to see some progress and feeling like I...   Nov 23 2019, 02:07 PM
mepstein   [quote name='mepstein' post='2764453' date='Nov 2...   Nov 23 2019, 02:10 PM
tvdinnerbythepool   @mepstein I was thinking the same thing! :co...   Nov 23 2019, 03:13 PM
mepstein   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Nov 24 2019, 12:24 PM
tvdinnerbythepool   With the back pretty much wrapped up it's on t...   Nov 23 2019, 12:54 PM
tvdinnerbythepool   RE: Suspension and Brake Refresh   Nov 23 2019, 12:54 PM
tvdinnerbythepool   This was the worse of the two sides   Nov 23 2019, 12:55 PM
mepstein   Heat up the fittings that hold the bushings until ...   Nov 23 2019, 01:31 PM
DRPHIL914   Looks nice , did you put the spring retainer clip ...   Nov 23 2019, 02:34 PM
tvdinnerbythepool   @DRPHIL914 Hi! Not sure what that means...can...   Nov 23 2019, 03:14 PM
DRPHIL914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Nov 23 2019, 04:47 PM
tvdinnerbythepool   @DRPHIL914 gotcha! Thanks for clarifying. Yes...   Nov 23 2019, 05:06 PM
mepstein   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Nov 23 2019, 05:44 PM
jmitro   There are 6 I think slots for the retainer that h...   Nov 24 2019, 02:29 PM
DRPHIL914   Looking at the tyre size charts for comparison my ...   Nov 23 2019, 07:16 PM
tvdinnerbythepool   Any one else have Rivieras that can weigh in? @d...   Nov 23 2019, 08:35 PM
DRPHIL914   Any one else have Rivieras that can weigh in? [...   Nov 24 2019, 06:35 AM
tvdinnerbythepool   Holy cow! That was stressful! Not sure ...   Dec 1 2019, 10:43 AM
cuddy_k   Holy cow! That was stressful! Not sure h...   Dec 2 2019, 09:58 PM
tvdinnerbythepool   Stupid question for the night. Bilsteins going up ...   Dec 2 2019, 09:40 PM
mepstein   Stupid question for the night. Bilsteins going up...   Dec 2 2019, 10:15 PM
tvdinnerbythepool   And while I'm asking...Torsion Bars! L fo...   Dec 2 2019, 09:43 PM
mepstein   And while I'm asking...Torsion Bars! L f...   Dec 2 2019, 10:15 PM
bbrock   And while I'm asking...Torsion Bars! L f...   Dec 3 2019, 08:55 AM
tvdinnerbythepool   Thank you! @mepstein and [b]@[url=http://ww...   Dec 3 2019, 08:10 AM
tvdinnerbythepool   Making slow progress on the front rebuild. Rebui...   Dec 18 2019, 10:34 PM
Mikey914   Making slow progress on the front rebuild. Rebu...   Dec 19 2019, 01:50 PM
maf914   Very nice looking work! Make sure the O-rings...   Dec 19 2019, 07:16 AM
tvdinnerbythepool   Thanks @mikey914 text with specs sent Can someo...   Dec 19 2019, 08:16 PM
bbrock   Thanks [b]@[url=http://www.914world.com/bbs2/ind...   Dec 20 2019, 12:50 AM
rgalla9146   If doing both calipers at the same time be sure to...   Dec 20 2019, 07:23 AM
tvdinnerbythepool   Thanks guys, trying to wrap my mind around it. Fou...   Dec 20 2019, 09:22 AM
tvdinnerbythepool   Did a test fit just to make sure I had it oriented...   Dec 21 2019, 02:39 PM
tvdinnerbythepool   New discs and bearings are in! Followed Ian...   Dec 21 2019, 02:40 PM
tvdinnerbythepool   This car is like the most frustrating game of Whac...   Jan 5 2020, 06:44 PM
DickSteinkamp   What do you guys think? Am I missing anything e...   Jan 5 2020, 07:44 PM
ndfrigi   with 195x60 tires, it should not be that close to ...   Jan 5 2020, 07:23 PM
mepstein   It’s the Rivs. That’s a wide tire for them but...   Jan 5 2020, 07:41 PM
tvdinnerbythepool   Here is a side view pic. The ride height is too hi...   Jan 5 2020, 08:14 PM
ndfrigi   Here is a side view pic. The ride height is too h...   Jan 5 2020, 09:37 PM
raynekat   Here is a side view pic. The ride height is too ...   Jan 5 2020, 09:45 PM
tvdinnerbythepool   RE: Suspension and Brake Refresh   Jan 5 2020, 08:15 PM
rhodyguy   Have you settled the suspension? You need to roll ...   Jan 5 2020, 08:19 PM
tvdinnerbythepool   Have you settled the suspension? You need to roll...   Jan 5 2020, 08:25 PM
mepstein   The type of wheel won’t make a difference. They ...   Jan 5 2020, 08:25 PM
burton73   The type of wheel won’t make a difference. They...   Jan 5 2020, 09:14 PM
- Lo-Fi Version Time is now: 28th September 2026 - 09:51 PM
