Str1974 |
Member ![]() ![]() Group: Members Posts: 90 Joined: 23-January 19 From: Dallas Member No.: 22,820 Region Association: Southwest Region ![]() |
I have a 1974 1.8 L with a current Bosch distributor (0 231 181 009). I have two vac ports on my throttle body , one that goes to the distributor (vac retard) and one that comes from the distributor (vac advance) back to the throttle body.
I'm replacing my old distributor for a new 123ignition w/Bluetooth adjustment. The 123 dizzy has an optional port on it for a vac line, so therefore one of my vac lines going from and towards the intake manifold would need to be "capped". I'm hearing that I could either chose to cap either the retard line or the advance line or all together cap both ports on my intake manifold and choose to run my new dizzy without any vac lines. I've also read that "The 914 distributor has a centrifugal advance built into it. This mechanism causes the distributor timing to change as the engine's RPM increases. The advancement of the timing is necessary because at higher RPMs, the engine needs to ignite the fuel earlier than at idle. In other words, if there were no centrifugal advance, then at higher RPMs, the full force from the combustion would impact the cylinder when it was already through the major part of it's stroke. This would result in lost power output. The centrifugal advance changes the timing so that ignition occurs earlier. Additionally, the fuel injection may advance or retard the timing based upon the vacuum pressure from the engine." It's this last line from above that has me wondering how vacuum pressure from the engine works if there are no vac lines going or returning from the dizzy to the intake manifold??? Or , am I completely wrong that the vac ports on the intake manifold / distributor has nothing to do with it. I'm still a novice and would like to understand more about this topic, or at least be less confused.... |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
I don't have L-jet, I have d-jet and so its not blue tooth enabled, but there are presets that we can select, with or without the vac advance as well. I have read that some have been running with out the vac but I found that I if I didn't have it connected the idle would be way too fast and the timing off. I ran it with and with out, and on severa different settings and found only one way it ran correctly with correct idle etc, and that's with the vac line from the TB hooked up to the distributor. Others may have done differently, but that is where the idle is correct, and my A/F is where it should be.
Phil |
Lo-Fi Version | Time is now: 20th June 2024 - 12:34 PM |
