L-Jetronic Fuel Injection and Distributor question, Intake Manifold Vac Ports to/from distributor |
Str1974 |
Nov 24 2019, 12:05 PM
Member Group: Members Posts: 90 Joined: 23-January 19 From: Dallas Member No.: 22,820 Region Association: Southwest Region |
I have a 1974 1.8 L with a current Bosch distributor (0 231 181 009). I have two vac ports on my throttle body , one that goes to the distributor (vac retard) and one that comes from the distributor (vac advance) back to the throttle body.
I'm replacing my old distributor for a new 123ignition w/Bluetooth adjustment. The 123 dizzy has an optional port on it for a vac line, so therefore one of my vac lines going from and towards the intake manifold would need to be "capped". I'm hearing that I could either chose to cap either the retard line or the advance line or all together cap both ports on my intake manifold and choose to run my new dizzy without any vac lines. I've also read that "The 914 distributor has a centrifugal advance built into it. This mechanism causes the distributor timing to change as the engine's RPM increases. The advancement of the timing is necessary because at higher RPMs, the engine needs to ignite the fuel earlier than at idle. In other words, if there were no centrifugal advance, then at higher RPMs, the full force from the combustion would impact the cylinder when it was already through the major part of it's stroke. This would result in lost power output. The centrifugal advance changes the timing so that ignition occurs earlier. Additionally, the fuel injection may advance or retard the timing based upon the vacuum pressure from the engine." It's this last line from above that has me wondering how vacuum pressure from the engine works if there are no vac lines going or returning from the dizzy to the intake manifold??? Or , am I completely wrong that the vac ports on the intake manifold / distributor has nothing to do with it. I'm still a novice and would like to understand more about this topic, or at least be less confused.... |
Bleyseng |
Nov 26 2019, 05:32 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
As all 914's had the vacuum advance hooked up until 74 I thought it was a emission thing to unplug it. I have noticed that it gives a slight bit of help on take off with the bump in advance. 75-76 Djet cars had it hooked up again.
Lo-Fi Version | Time is now: 16th June 2024 - 07:06 AM |
