Converting a 901 side shift to a 4 speed. |
9144me2enjoy |
Nov 26 2019, 06:35 PM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
I have a 74-914 with a 4 cyl Raby engine 2270cc. It has the 901 side shift trans. Tired of the dog bone pattern. What would it cost to go to a 4 speed, 1st to 2nd position and make the smaller gear integral with the main shaft and possibly replace 4th gear with a lower highway ratio gear for mileage. I know this is common with V8 conversions etc. What is your thoughts. Thanks
Mark Henry |
Nov 28 2019, 10:47 AM
My 914/6 3.0 conversion is custom geared A, F, O, X, HB (flipped).
I can easily use it as a 4 speed for jack rabbit starts, but having the granny gear 1st comes in very handy for stop and go traffic, line ups, starting on grades, parking, etc. The flipped HB is one tooth shorter than the H that V8 guys use, following the aircooled 3K rpm rule and stock height tires I can only use it at 90 mph and over. For street use with an aircooled engine would make an H gear all but useless. |
ClayPerrine |
Nov 28 2019, 10:58 AM
Life's been good to me so far..... Group: Admin Posts: 15,527 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
My 914/6 3.0 conversion is custom geared A, F, O, X, HB (flipped). I can easily use it as a 4 speed for jack rabbit starts, but having the granny gear 1st comes in very handy for stop and go traffic, line ups, starting on grades, parking, etc. The flipped HB is one tooth shorter than the H that V8 guys use, following the aircooled 3K rpm rule and stock height tires I can only use it at 90 mph and over. For street use with an aircooled engine would make an H gear all but useless. My 2.4 has a custom geared 901, A, GA, Fiipped ZD, S, ZD. I found the HB I had in 5th kept me from running 60 mph. I could run over 60, or below 60 but not at 60. It would overheat. Fan was turning too slow in 5th, and too fast in 4th. Changed 5th for the ZD, and it was fine. |
Lo-Fi Version | Time is now: 13th June 2024 - 05:19 AM |
