SOLD: Closed Course Motorsports 914-6 911 ITB Price Cut, Yep the ones that use the Triple Speeds |
914forme |
Jan 26 2019, 06:43 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
I will not be using these on my project.
Cost Read all about them here. Shamelessly pulled from their sight and modified with the things I added. (2) New cast aluminum manifolds (6) New treated Paper Gasket ITB gaskets (12) New stainless steel A-2, 6mm x 1.0mm x 30mm studs (12) New 6mm x 1.0mm hex lock nuts nylon insert, Zinc plated class 8.8 steel (12) New 6mm flat washers, Zinc plated steel (1) New vacuum port plug (1) New vacuum barb (2) Used Triumph throttle body sets - good used condition, degreased but could use a good cleaning/painting. (1) Used Triumph throttle position sensor (1) New linkage setup - requires use of the stock CIS bellcrank (2) New aluminum fuel rails - needs -6 AN o-ring boss adapters for fuel line tie in (1) Vacuum manifold setup with hoses and fittings (6) Triumph Seals for to of TBs to bolt rain hat adapters to (6) Velocity stacks (1) 911 CIS bell crank (see not above) (1) Set of 4 barbed fuel line adapters. Parts not included but required for a complete setup: (1) phenolic insulator/spacer kit (1) Fuel lines or with -6 AN female fittings (1) Air filter or velocity stack setup (1) Inline fuel filter (1) Fuel pressure regulator (1) EFI setup (Electronic Fuel Injection: Megasquirt, AEM Infinity, etc) |
914forme |
Nov 29 2019, 10:27 AM
Bump
I need these out of my garage. |
Lo-Fi Version | Time is now: 16th June 2024 - 10:30 PM |
