rear alignment question, how many degrees change in camber/caster per mm for shims |
DRPHIL914 |
Dec 3 2019, 09:09 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
also I want to clarify does adding shims increase negative camber?
- looking for a fast easy answer of if I want to just a slight amount of negative camber since it seems I am at 0 now, to go to 2 degrees negative how many mm generally will it take- trying to just buy a few shims not a bunch! currently does appear that the right and left a same, my initial check was 0 and 0. Phil. |
jmitro |
Dec 3 2019, 11:14 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
6mm of rear shims = 1 degree of camber
Lo-Fi Version | Time is now: 11th June 2024 - 04:00 PM |
