Rev Limiter (123 Ignition) |
Not_A_Six |
Dec 3 2019, 06:12 PM
Member Group: Members Posts: 110 Joined: 28-November 18 From: North Idaho Member No.: 22,682 Region Association: Pacific Northwest |
The positive reviews here have me looking hard at a 123Ignition dizzy replacement on my '73 2.0 w/ stock D-Jet.
But, the version they offer for the 914 that's compatible w/ D-Jet (123\PORSCHE-4-R-V-IE) has a fixed 8000 rpm rev limiter. The thought of my motor turning to shrapnel at 8000 rpm is a just tad bit worrisome. (IMG:style_emoticons/default/icon8.gif) Ed at 123 Ignition said that the OEM rev-limiting rotor won't work in their dizzy, and suggested an aftermarket stand-alone rev limiter. But, I'm not too enthusiastic about adding an extra box at additional expense, just to limit revs. Has anyone here used the 123Iginition w/ D-Jet? What did you do to limit rpm? Anyone just run without a rev limiter? Thanks. |
Mark Henry |
Dec 4 2019, 09:36 AM
You want no more than a 6K redline and never use a limiter as a shift indicator.
Depends on the cam but torque drops of at 5400 rpm with most cams, some hotter street cams it's about 5600. |
Not_A_Six |
Dec 4 2019, 09:52 AM
You want no more than a 6K redline and never use a limiter as a shift indicator. Depends on the cam but torque drops of at 5400 rpm with most cams, some hotter street cams it's about 5600. Thanks. I was more concerned with somebody over-revving the engine accidentally and thought the rev limiter would be a valuable (essential?) safety valve. I do know how to drive, after all. (IMG:style_emoticons/default/wink.gif) |
VaccaRabite |
Dec 5 2019, 08:16 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Thanks. I was more concerned with somebody over-revving the engine accidentally and thought the rev limiter would be a valuable (essential?) safety valve. I do know how to drive, after all. (IMG:style_emoticons/default/wink.gif) How would you accidentally rev past 6K? A rev limiter won't save the engine from a money shift (typically 5th to 2nd) since that is a mechanical over-rev and not caused by the gas pedal. Only way I see this as possible is racing the car (AX or track) and not paying attention to the sounds your car is making. Zach |
Lo-Fi Version | Time is now: 6th June 2024 - 10:54 AM |
