Fuel Pump Wire, Ground? |
trojanhorsepower |
Nov 17 2019, 07:55 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
So, I moved the fuel pump to the front of the car and ran a wire back to the engine compartment. What do folks do with the dangling ground wire? Same with the brake switch. Two wires one connector, so what did you do with the other wire?
Thanks Peter |
trojanhorsepower |
Dec 5 2019, 07:57 PM
One more question. Is the ground point at the fuse block a bolt or a stud? I see a captive nut there near where I think the ground should be, if that is it anyone know the thread details?
ClayPerrine |
Dec 6 2019, 07:30 AM
Life's been good to me so far..... Group: Admin Posts: 15,518 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
One more question. Is the ground point at the fuse block a bolt or a stud? I see a captive nut there near where I think the ground should be, if that is it anyone know the thread details? It is a stud. It is located on the inside of the mounting bracket for the fuse box. You should see a bunch of brown wires under the nut. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:20 AM |
