| orangecrate |
Dec 7 2019, 11:33 AM
Member ![]() ![]() Group: Members Posts: 187 Joined: 16-September 13 From: Apache Junction AZ Member No.: 16,394 Region Association: Southwest Region |
So I been workin on the orangecrate off an on for what seems like forever... seems I now have rod issues. Knock knock.... Any way I'm lookin at building a motor, or rebuilding. Inexpensively (IMG:style_emoticons/default/lol-2.gif) I have only 2 real conditions I want to meet. 1- It will run 80 mph all day thru the desert in the summer in Phoenix and sit at stoplights with out cooking itself. 2- It will pull the 6% grades that you hit leaving the valley at 70 in the summer without cooking itself. 75 would be nicer. Guess I"m talking a torque motor. This is a stock 72 with stock gearing. And maybe one size up tires. Did I say it needs to be reliable? Like Phoenix to Portland and back any time of year reliable. And inexpensive.. I'd love to buy a Raby motor but $$$. Oh yea. I will be doing the assembly myself. And I'd like to use as much of the 1.7 as possible if possible. Thanks for the input. Build away. (IMG:style_emoticons/default/beer.gif)
| rhodyguy |
Dec 7 2019, 01:58 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Do the 1.7 case spigots and heads limit cyl/piston selection?
| Superhawk996 |
Dec 7 2019, 02:56 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,136 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Do the 1.7 case spigots and heads limit cyl/piston selection? Only to the extent that 1.7L heads have smaller valves/ports and will limit airflow. Machine work can fix case/head fit. I built my original car's engine from a 1.7L and at the time I couldn't afford 2.0L heads. I went 96mm flat top pistons, carbs, performance cam, and had the 1.7L heads fly cut to accomodate the 96mm cylinders. The engine never really achieved it's potential from the displacment bump due to the heads restricting flow and my running stock heat exchanger pipes (minus exchangers for weight reduction (IMG:style_emoticons/default/lol-2.gif) ). Upping the compression ratio helped. Better than what I had started with but certainly wasn't Raby HP (IMG:style_emoticons/default/smile.gif) Per Mark Henry's note. Budget really needs to be known. I had sort of assumed that best plan would be to source fresh 2.0L AAP heads from HAM but those alone are $1700-1900 per pair (with aforementioned coatings) so may not exactly be "cheap" depending on OP's point of view. |
| orangecrate |
Dec 7 2019, 03:51 PM
Do the 1.7 case spigots and heads limit cyl/piston selection? Only to the extent that 1.7L heads have smaller valves/ports and will limit airflow. Machine work can fix case/head fit. I built my original car's engine from a 1.7L and at the time I couldn't afford 2.0L heads. I went 96mm flat top pistons, carbs, performance cam, and had the 1.7L heads fly cut to accomodate the 96mm cylinders. The engine never really achieved it's potential from the displacment bump due to the heads restricting flow and my running stock heat exchanger pipes (minus exchangers for weight reduction (IMG:style_emoticons/default/lol-2.gif) ). Upping the compression ratio helped. Better than what I had started with but certainly wasn't Raby HP (IMG:style_emoticons/default/smile.gif) Per Mark Henry's note. Budget really needs to be known. I had sort of assumed that best plan would be to source fresh 2.0L AAP heads from HAM but those alone are $1700-1900 per pair (with aforementioned coatings) so may not exactly be "cheap" depending on OP's point of view |
orangecrate touring power Dec 7 2019, 11:33 AM
mepstein Add an oil cooler. Tangerine makes a bolt on kit. Dec 7 2019, 12:32 PM
Superhawk996 2.0L Stock or maybe 2056 is probably the sweet spo... Dec 7 2019, 12:55 PM
Mark Henry First is it knocking? Many newbies mistake a ... Dec 7 2019, 01:44 PM
orangecrate
First is it knocking? Many newbies mistake a ... Dec 7 2019, 03:31 PM
ctc911ctc
First is it knocking? Many newbies mistake a ... Dec 12 2019, 11:42 AM
orangecrate
[quote name='Superhawk996' post='2768... Dec 7 2019, 03:57 PM
Bleyseng As Superhawk says - a 2056cc with a external oil c... Dec 7 2019, 02:33 PM
orangecrate
As Superhawk says - a 2056cc with a external oil ... Dec 7 2019, 04:06 PM
Mark Henry
As Superhawk says - a 2056cc with a external oil... Dec 7 2019, 04:16 PM
orangecrate There is a very good Porsche wrecking yard in PHX.... Dec 7 2019, 04:04 PM
Superhawk996
There is a very good Porsche wrecking yard in PHX... Dec 7 2019, 04:38 PM
Superhawk996
There is a very good Porsche wrecking yard in PHX... Dec 7 2019, 04:49 PM
Tdskip
My rebuilt 1.7L 66m crank with 96mm pistons = 191... Dec 8 2019, 08:32 PM
Superhawk996
showuser=22428]Superhawk996 - just a 2.0L of 205... Dec 8 2019, 09:25 PM
thelogo Building a expensive .aircooled .motor that need t... Dec 8 2019, 02:32 PM
Tdskip @Superhawk996 - thanks for the response but I wa... Dec 9 2019, 07:16 AM
Superhawk996
[b]@[url=http://www.914world.com/bbs2/index.php?s... Dec 9 2019, 06:13 PM
orangecrate Been doin a little figuring and thinking . Based ... Dec 9 2019, 08:11 AM
914forme Have you checked into Original Customs engine prog... Dec 9 2019, 08:41 AM
Have you checked into [url=http://www.originalcus... Dec 9 2019, 09:32 AM
rhodyguy Doing it right, chances are you will need machine ... Dec 9 2019, 09:56 AM
Tdskip @superhawk996 - thanks for following up and good... Dec 10 2019, 09:46 AM
VaccaRabite When I did my motor (2056) it started as a 1.7L ca... Dec 10 2019, 10:32 AM
Tdskip Super helpful post Zach Dec 10 2019, 10:36 AM
Bleyseng Sorry, there is no waay I’d a Subie in 914. Just... Dec 10 2019, 04:13 PM
orangecrate What are y'all's thoughts on a 1911 ?? I... Dec 10 2019, 08:48 PM
Tdskip
What are y'all's thoughts on a 1911 ?? ... Dec 10 2019, 09:14 PM
michael7810
What are y'all's thoughts on a 1911 ?? ... Dec 12 2019, 09:20 AM
Bleyseng Its going cost about the same to build a stock 1.7... Dec 11 2019, 12:57 PM
VaccaRabite 1911 can be a great engine making similar power to... Dec 12 2019, 11:36 AM
orangecrate
1911 can be a great engine making similar power t... Dec 28 2019, 06:45 PM
Tdskip Good luck and please keep us posted Dec 28 2019, 08:16 PM
MM1 Did you ever get that stock 1.7 running? Nov 2 2020, 06:07 PM
rbzymek So when my 1975 1.8L overheated and failed with lo... Nov 2 2020, 07:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th October 2026 - 03:45 PM |
