| sportlicherFahrer |
Apr 6 2015, 06:15 PM
Nothing to see here. ![]() ![]() ![]() Group: Members Posts: 1,124 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest
Was checking up on ignition upgrades from Pertronix again and saw that they offer the Ignitor III for our vacuum dizzies now. Supposed to work like a box style ignition without the box(multiple spark, rev limiter). Did a search here and didn't see anything for that model. Anybody used an Ignitor III and have any useful feedback on or off a Porsche? Not looking for opinions on whether or not Pertronix belongs in our cars or not, just on the functionality of the Ignitor III. With that said, I know this may start a (IMG:style_emoticons/default/stromberg.gif) storm..... (IMG:style_emoticons/default/stirthepot.gif)
| sportlicherFahrer |
Dec 7 2019, 07:13 PM
The 009 and pertronix units will "work" but they have the wrong curve and will never run properly. I'd recommend a stock unit over those, and with vacuum hooked up in a T from each carb to the advance pot, or pony up for the 123 unit that seems to be working well on these engines.
| Gatornapper |
Dec 7 2019, 07:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,290 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States
Jim -
PRICELESS information - thank you. You know I have Weber IDF-44's, right? Not D-jet. Now - where to connect the vacuum line? On the IDF 44's there is a very small tube for a vacuum connection at the bottom of the carbs - is this point of sufficient size? TIA, GN The 009 and pertronix units will "work" but they have the wrong curve and will never run properly. I'd recommend a stock unit over those, and with vacuum hooked up in a T from each carb to the advance pot, or pony up for the 123 unit that seems to be working well on these engines. |
sportlicherFahrer Pertronix Ignitor III Apr 6 2015, 06:15 PM
76-914 :popcorn: Apr 6 2015, 09:38 PM
colingreene I personally have had problems with the parts they... Apr 7 2015, 11:00 AM
Java2570 I've heard of others using Ignitor II but I... Apr 7 2015, 12:20 PM
SLITS
I've heard of others using Ignitor II but I... Apr 7 2015, 12:48 PM
SKL1 Why would this be better than Permatune? I'v... Apr 7 2015, 12:45 PM
Dave_Darling Why would this be better than Permatune?
The Per... May 25 2015, 08:35 PM
sportlicherFahrer Part number 71847v. They run about $130 on S... Apr 7 2015, 01:01 PM
Java2570 I don't see the specific instructions for the ... Apr 7 2015, 01:27 PM
euro911 I've been running a -II on my 2056 for over 3 ... May 25 2015, 04:55 PM
boxsterfan Opinions on the Pertronix are like reviews on Amaz... May 25 2015, 05:23 PM
cuddyk I have a P-III on my 65 mustang. Works great. The ... May 25 2015, 09:17 PM
Jetsetsurfshop You guys that are using the Pertronix III, what co... Aug 10 2017, 04:48 PM
Perry Kiehl Jet, check the classifieds. I have a Pertronix SVD... Aug 10 2017, 06:20 PM
bandjoey II installed on otherwise stock (blue coil) motor.... Aug 10 2017, 07:13 PM
solex I just installed the III and cannot seem to get th... Aug 11 2019, 01:39 PM
porschetub
I just installed the III and cannot seem to get t... Aug 11 2019, 03:14 PM
bbrock According to the Pertronix III instructions, it is... Aug 11 2019, 03:45 PM
SteveL I have had a Pertronix in place of the points for ... Aug 11 2019, 03:53 PM
solex I checked everything even called Pertronix prior t... Aug 11 2019, 05:18 PM
Gatornapper My dizzy just went bad & I have MSD and see th... Dec 7 2019, 06:58 PM
solex Spoke with Carl from Pertronix.
(1) I'm on va... Aug 15 2019, 08:35 AM
sportlicherFahrer :wavebye: OP here. I ended up canning the Ignitor... Aug 16 2019, 07:12 PM
solex Got it running, after checking everything I had m... Aug 22 2019, 12:24 PM
Rand Pertronix worked great for me for 20+ years. Then ... Aug 22 2019, 02:29 PM
Al Meredith I've had problems with two pertronix units . I... Aug 22 2019, 02:43 PM
solex
I've had problems with two pertronix units . ... Aug 22 2019, 04:07 PM
solex I have given up.
I order there epoxy coil with 0.... Aug 31 2019, 04:45 PM
ndfrigi here is my experienced with pertronix, bought my ... Aug 31 2019, 05:22 PM
solex I have no doubt that Pertronix I & II works ba... Sep 2 2019, 04:13 PM
Gatornapper Hmmm.....just thinking - my '76 2.0 was runnin... Dec 7 2019, 08:33 PM
rbzymek I installed a Pertronix III ignitor, Flamethrower ... Dec 7 2019, 07:52 PM
Gatornapper Thanks for the info.........
I'd love the 123... Dec 7 2019, 07:57 PM
sportlicherFahrer I'm running with 40's on mine. Stock cam w... Dec 7 2019, 08:22 PM
Gatornapper Jim -
Totally got you on the vacuum lines being ... Dec 7 2019, 08:48 PM
sportlicherFahrer I honestly don't have any hard data on the dif... Dec 9 2019, 05:52 AM
Gatornapper Seems this should be so simple - but it's not.... Dec 9 2019, 08:20 AM
sportlicherFahrer I've also heard of folks using the 205AB from ... Dec 9 2019, 08:29 AM
sportlicherFahrer Checking out the pertronix website, it looks like ... Dec 9 2019, 09:10 AM
Gatornapper Asked Pertronix about this - it will not fit/work ... Dec 10 2019, 12:25 PM
Gatornapper Decision made. Ordered new 009 dizzy from AA and ... Dec 9 2019, 10:49 AM
ClayPerrine
Decision made. Ordered new 009 dizzy from AA and... Dec 10 2019, 07:17 AM
Gatornapper Clay -
Thanks. Car had an 009 in it when I got i... Dec 10 2019, 12:37 PM
Gatornapper Clay & Perry -
What is it about the advance c... Dec 10 2019, 02:50 PM
rbzymek Clay,
What is the best option for a 1.8L dizzy sho... Dec 10 2019, 07:46 AM
ClayPerrine
Clay,
What is the best option for a 1.8L dizzy sh... Dec 10 2019, 10:52 AM
IronHillRestorations 009 is a great distributor, for a generator engine Dec 10 2019, 07:56 AM
Gatornapper As you said, "The "009" mechanical ... Dec 12 2019, 09:11 PM
sportlicherFahrer Saw reviews on Amazon and Summit of guys running t... Dec 10 2019, 12:33 PM
Gatornapper Jim -
Very interesting - but the 009 is on the wa... Dec 10 2019, 12:52 PM
rhodyguy It will work. Just not optimized curve. Find TDC o... Dec 10 2019, 02:08 PM
Gatornapper Sitting on TDC right now........of course, no mark... Dec 10 2019, 03:13 PM
sportlicherFahrer Should be able to see the notch on the flywheel th... Dec 10 2019, 03:18 PM
Gatornapper Already did that. Used small mirror to see 27 deg... Dec 10 2019, 03:23 PM
Gatornapper Ok, seeing from this chart what may be the issue.
... Dec 10 2019, 03:22 PM
yeahmag It may have been mentioned, but the 009 has too mu... Dec 10 2019, 05:58 PM
Gatornapper Aaron -
Thank you.
Ok, guys. What are my altern... Dec 10 2019, 06:32 PM
Gatornapper Aaron -
The total advance is easily reduced by be... Dec 10 2019, 07:17 PM
Tdskip Great chart, helps to visualize the considerations... Dec 10 2019, 06:39 PM
Gatornapper TD -
No mud at all. I looked at these and seriou... Dec 10 2019, 06:53 PM
Tdskip
TD -
No mud at all. I looked at these and serio... Dec 11 2019, 09:14 AM
Gatornapper Wondering where I could get a Bosche 009 made in B... Dec 10 2019, 08:05 PM
Tdskip
Wondering where I could get a Bosche 009 made in ... Dec 11 2019, 08:34 AM
Gatornapper Have you used them? If so, what has been your exp... Dec 11 2019, 09:29 AM
Gatornapper Found the advance curve for the Pertronix D182504 ... Dec 10 2019, 09:04 PM
ClayPerrine If you are looking for a distributor that works we... Dec 11 2019, 02:28 PM
Gatornapper Clay -
Thank you! What distributor would tha... Dec 11 2019, 08:09 PM
ClayPerrine I don't know the part number, but you should b... Dec 11 2019, 09:54 PM
Gatornapper Clay -
Thanks. Talked to Pelican yesterday - the... Dec 12 2019, 07:39 AM
ClayPerrine
Clay -
Thanks. Talked to Pelican yesterday - th... Dec 12 2019, 08:22 AM
Gatornapper Clay -
Do you see the '74 1.8 dizzy on either... Dec 12 2019, 09:57 AM
IronHillRestorations I put a brand new Pertronix SVDA on a customer car... Dec 12 2019, 07:50 AM
Gatornapper Perry -
Yes - their track record does not look go... Dec 12 2019, 09:49 AM
Gatornapper Perry -
Word seems to be that you do NOT leave th... Dec 12 2019, 09:53 AM
Tdskip This thread is practically begging for a table tha... Dec 12 2019, 08:49 AM
Gatornapper Bulls-eye.
This thread is practically begging fo... Dec 12 2019, 09:49 AM
sportlicherFahrer The ignitor I is prone to failure with KOEO for ex... Dec 12 2019, 10:07 AM
Gatornapper Jim -
Good news - makes sense Pertronix would fi... Dec 12 2019, 05:15 PM
rbzymek So I have a and OE dizzy that came off of a 1.8L ,... Dec 12 2019, 04:27 PM
Gatornapper I'm guessing, but the chart here
https://www... Dec 12 2019, 05:14 PM
Gatornapper From the Pelican Parts forum post in 2001, the diz... Dec 12 2019, 09:17 PM
914werke The ignitor I is prone to failure with KOEO for ex... Dec 12 2019, 07:23 PM
Gatornapper Rich -
Sorry - I'm relatively new at this 914... Dec 13 2019, 08:50 AM
Gatornapper Best price yet - Dansk - says it's for '74... Dec 12 2019, 08:56 PM
Gatornapper VERY INTERESTING.
A Pelican Parts forum discussio... Dec 12 2019, 09:04 PM
rbzymek GN-
I copied the dizzy part wrong. The good one i... Dec 13 2019, 09:37 AM
Gatornapper Ray -
Thanks - I did have the correct number.
No... Dec 13 2019, 10:05 AM
rbzymek Go with WTB. That's where I found mine for ... Dec 13 2019, 10:13 AM
Tdskip Hold on here - so we are putting down for future r... Dec 13 2019, 10:31 AM
rbzymek So the 231 181 009 aka 022 905 205AA has a curve d... Dec 13 2019, 10:52 AM
Gatornapper I agree - research I have done confirms that......... Dec 13 2019, 10:58 AM
Gatornapper What I'd like to know is where does the 022 90... Dec 13 2019, 11:03 AM
rbzymek FYI....
Dec 13 2019, 11:47 AM
Gatornapper AH-HA!
It's a VW Part number!
The 0 ... Dec 13 2019, 11:55 AM
Gatornapper Wondering if at this point we shouldn't move t... Dec 13 2019, 12:28 PM
rbzymek GN,
That's the Bosch number 231 181 009. The V... Dec 13 2019, 02:38 PM
Gatornapper NOW it makes sense!
Thank you!
On the Pe... Dec 13 2019, 06:59 PM
rbzymek Here is a graph of the curve base on the Pelican t... Dec 13 2019, 02:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th June 2026 - 12:32 PM |
