> touring power, build an engine !!!!
orangecrate
post Dec 7 2019, 11:33 AM
So I been workin on the orangecrate off an on for what seems like forever... seems I now have rod issues. Knock knock.... Any way I'm lookin at building a motor, or rebuilding. Inexpensively (IMG:style_emoticons/default/lol-2.gif) I have only 2 real conditions I want to meet. 1- It will run 80 mph all day thru the desert in the summer in Phoenix and sit at stoplights with out cooking itself. 2- It will pull the 6% grades that you hit leaving the valley at 70 in the summer without cooking itself. 75 would be nicer. Guess I"m talking a torque motor. This is a stock 72 with stock gearing. And maybe one size up tires. Did I say it needs to be reliable? Like Phoenix to Portland and back any time of year reliable. And inexpensive.. I'd love to buy a Raby motor but $$$. Oh yea. I will be doing the assembly myself. And I'd like to use as much of the 1.7 as possible if possible. Thanks for the input. Build away. (IMG:style_emoticons/default/beer.gif)
orangecrate
post Dec 7 2019, 04:04 PM
There is a very good Porsche wrecking yard in PHX. I'm not against good used parts either. I'm not familiar with all displacement increases with new pistons, What does the 96mm give you? and where in the rpm range did your motor run out of steam due to the small heads?
Superhawk996
post Dec 7 2019, 04:49 PM
QUOTE(orangecrate @ Dec 7 2019, 05:04 PM) *
My rebuilt 1.7L 66m crank with 96mm pistons = 1910cc. I had Weber 40 IDF carbs, a Bosch 009 distributor (dont' get me started - it was the late 80's I was young and stupid (IMG:style_emoticons/default/rolleyes.gif) ) and a performance "carb" cam (for which I don't remember the exact spec's) had a decent powerband from 2500 rpm - about 4500 rpm but then it seemed to run out of steam on it's way to 5500 rpm. Basically just making noise, building RPM's a bit slower, and not really "pulling" like it did in the power band.
I wish I had known more back then. I wouldn't do that engine again. (IMG:style_emoticons/default/happy11.gif)
Tdskip
post Dec 8 2019, 08:32 PM
QUOTE(Superhawk996 @ Dec 7 2019, 05:49 PM) *
@Superhawk996 - just a 2.0L or 2056 instead?
orangecrate   touring power   Dec 7 2019, 11:33 AM
mepstein   Add an oil cooler. Tangerine makes a bolt on kit.   Dec 7 2019, 12:32 PM
Superhawk996   2.0L Stock or maybe 2056 is probably the sweet spo...   Dec 7 2019, 12:55 PM
Mark Henry   First is it knocking? Many newbies mistake a ...   Dec 7 2019, 01:44 PM
orangecrate   First is it knocking? Many newbies mistake a ...   Dec 7 2019, 03:31 PM
ctc911ctc   First is it knocking? Many newbies mistake a ...   Dec 12 2019, 11:42 AM
rhodyguy   Do the 1.7 case spigots and heads limit cyl/piston...   Dec 7 2019, 01:58 PM
Superhawk996   Do the 1.7 case spigots and heads limit cyl/pisto...   Dec 7 2019, 02:56 PM
orangecrate   Do the 1.7 case spigots and heads limit cyl/pist...   Dec 7 2019, 03:51 PM
orangecrate   [quote name='Superhawk996' post='2768...   Dec 7 2019, 03:57 PM
Bleyseng   As Superhawk says - a 2056cc with a external oil c...   Dec 7 2019, 02:33 PM
orangecrate   As Superhawk says - a 2056cc with a external oil ...   Dec 7 2019, 04:06 PM
Mark Henry   As Superhawk says - a 2056cc with a external oil...   Dec 7 2019, 04:16 PM
orangecrate   There is a very good Porsche wrecking yard in PHX....   Dec 7 2019, 04:04 PM
Superhawk996   There is a very good Porsche wrecking yard in PHX...   Dec 7 2019, 04:38 PM
Superhawk996   There is a very good Porsche wrecking yard in PHX...   Dec 7 2019, 04:49 PM
Tdskip   My rebuilt 1.7L 66m crank with 96mm pistons = 191...   Dec 8 2019, 08:32 PM
Superhawk996   showuser=22428]Superhawk996 - just a 2.0L of 205...   Dec 8 2019, 09:25 PM
thelogo   Building a expensive .aircooled .motor that need t...   Dec 8 2019, 02:32 PM
Tdskip   @Superhawk996 - thanks for the response but I wa...   Dec 9 2019, 07:16 AM
Superhawk996   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 9 2019, 06:13 PM
orangecrate   Been doin a little figuring and thinking . Based ...   Dec 9 2019, 08:11 AM
914forme   Have you checked into Original Customs engine prog...   Dec 9 2019, 08:41 AM
mepstein   Have you checked into [url=http://www.originalcus...   Dec 9 2019, 09:32 AM
rhodyguy   Doing it right, chances are you will need machine ...   Dec 9 2019, 09:56 AM
Tdskip   @superhawk996 - thanks for following up and good...   Dec 10 2019, 09:46 AM
VaccaRabite   When I did my motor (2056) it started as a 1.7L ca...   Dec 10 2019, 10:32 AM
Tdskip   Super helpful post Zach   Dec 10 2019, 10:36 AM
Bleyseng   Sorry, there is no waay I’d a Subie in 914. Just...   Dec 10 2019, 04:13 PM
orangecrate   What are y'all's thoughts on a 1911 ?? I...   Dec 10 2019, 08:48 PM
Tdskip   What are y'all's thoughts on a 1911 ?? ...   Dec 10 2019, 09:14 PM
michael7810   What are y'all's thoughts on a 1911 ?? ...   Dec 12 2019, 09:20 AM
Bleyseng   Its going cost about the same to build a stock 1.7...   Dec 11 2019, 12:57 PM
VaccaRabite   1911 can be a great engine making similar power to...   Dec 12 2019, 11:36 AM
orangecrate   1911 can be a great engine making similar power t...   Dec 28 2019, 06:45 PM
Tdskip   Good luck and please keep us posted   Dec 28 2019, 08:16 PM
MM1   Did you ever get that stock 1.7 running?   Nov 2 2020, 06:07 PM
rbzymek   So when my 1975 1.8L overheated and failed with lo...   Nov 2 2020, 07:45 PM
- Lo-Fi Version Time is now: 17th October 2026 - 03:46 PM
