Rebuiding Inside-out |
bkrantz |
Oct 16 2019, 08:47 PM
914 Guru Group: Members Posts: 7,802 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I realize most rebuilds go from the inside to the outside, but I am struck by how straight and clean the outer panels, including paint, look on my 73 2.0. And all the nasty stuff is hidden underneath--which I know is also not unusual.
Any way, I bought the car knowing most of what it was: a 2.0 with all the sport and appearance group equipment, including 5 good Fuchs, and the original fuel injection. The original engine is confirmed by a COA. In contrast to the exterior the interior was mixed at best, with some funky carpet. And the front and rear trunks (and engine compartment, and interior) had been sprayed with black undercoating. So after a month, I have the car stripped to a bare shell, except for suspension and steering. I measured everything I could, and the body is very square and on spec. I need to patch some local rust spots, and replace the rear floor. And then do some minor straightening: right headlight bucket, front edge of right front fender, rear panel, etc. Attached thumbnail(s) |
FourBlades |
Dec 8 2019, 11:26 AM
From Wreck to Rockin Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Looking good! Do some diagonal measurements from the base of the windshield to the corner of the buckets. I had a car that was off by one inch on one side! Made fitting the headlights exciting until I realized and fixed it. Don't neglect the vertical checks as well. I have a feeling from your work that you know all that. (IMG:style_emoticons/default/biggrin.gif) John |
bkrantz |
Dec 8 2019, 09:35 PM
Looking good! Do some diagonal measurements from the base of the windshield to the corner of the buckets. I had a car that was off by one inch on one side! Made fitting the headlights exciting until I realized and fixed it. Don't neglect the vertical checks as well. I have a feeling from your work that you know all that. (IMG:style_emoticons/default/biggrin.gif) John Thanks, John. The diagonal measurements (and lots more) check out. I also compared positions to the front hood (a very straight one). |
Lo-Fi Version | Time is now: 8th June 2024 - 10:39 AM |
