> Door stay kit
post Dec 7 2019, 09:58 PM
914-6 GT in waiting
Help me understand. The door stay kit I’m using comes with a pin but it’s too big for the hole. I could make the hole bigger but there’s still no groove for a clip. Stock pin on right
@Mikey914
Mikey914
post Dec 9 2019, 02:00 AM
The rubber man
We initially made them to the OEM size. The complaint was they "clicked" when the doors opened and closed. Problem was that not everyone had the problem. So we made them slightly larger to eliminate the problem. They can be easily filed down to get a get a custom fit for your car.
It's the only way to get a perfect fit.
By the way the steering rack rebuild service we do has a similar issue. The shafts often are darkened with oxidation and pitting. We actually make our bushings with a smaller diameter and hone each one for a perfect fit (after we polish the shaft).
The idea is that the tolerance will be back to if not tighter than the factory, but the process was difficult enough that we don't sell the bushings stand alone as the process of educating and with different levels of capabilities we would have a more difficult time selling just the parts.
The parallel is that there are varying levels of degradation in the mount holes. Fortunately this is a pretty simple application.
Gravity makes the clip redundant, they are difficult enough to remove when you are trying.
mepstein   Door stay kit   Dec 7 2019, 09:58 PM
Krieger   Iirc the pins were made oversized because the mont...   Dec 8 2019, 12:07 AM
mepstein   Iirc the pins were made oversized because the mon...   Dec 8 2019, 07:47 AM
mb911   That explains why they fit so tight for me and end...   Dec 8 2019, 05:48 AM
roblav1   Turn 'em on a lathe! On mine, which I just...   Dec 8 2019, 07:18 AM
FlacaProductions   Check here (specifically posts 14 and 16): http://...   Dec 8 2019, 08:42 AM
Mikey914   We initially made them to the OEM size. The compla...   Dec 9 2019, 02:00 AM
raynekat   So we made them slightly larger to eliminate the ...   Dec 10 2019, 11:18 AM
914forme   :agree: So my plans to be buried in space in my 9...   Dec 9 2019, 04:40 AM
Mikey914   Yes we are trying to be a little more clear for ou...   Dec 9 2019, 10:29 AM
mepstein   I appreciate that 914rubber is making the parts. I...   Dec 9 2019, 10:50 AM
BeatNavy   I appreciate that 914rubber is making the parts. ...   Dec 10 2019, 08:52 AM
raynekat   So if I have to file the pin smaller to fit the ho...   Dec 10 2019, 01:43 AM
bbrock   I happened to glance at the door stay on my Nissan...   Dec 10 2019, 08:37 AM
Bartlett 914   I happened to glance at the door stay on my Nissa...   Dec 11 2019, 08:54 AM
Mikey914   Forgot we did change the arms. So perhaps This nex...   Dec 10 2019, 11:51 PM
Superhawk996   Wow! Hard group to please on this topic. L...   Dec 11 2019, 06:06 AM
mepstein   I think it would be helpful to print in the part d...   Dec 11 2019, 07:21 AM
ThePaintedMan   :agree: They do one heck of a job trying to please...   Dec 11 2019, 07:43 AM
Mikey914   Guys, I do really appreciate the input. We made ch...   Dec 11 2019, 07:50 AM
mepstein   Guys, I do really appreciate the input. We made c...   Dec 11 2019, 08:33 AM
ctc911ctc   All, I bought this kit for both doors and install...   Dec 18 2019, 04:21 PM
Mikey914   All, I bought this kit for both doors and instal...   Dec 18 2019, 05:12 PM
oldschool   I've been hoping to get the repair kit.......S...   Dec 18 2019, 11:07 PM
bbrock   @[url=http://www.914world.com/bbs2/index.php?showu...   Jan 15 2020, 10:37 AM
Mikey914   Our current game plan is to go back to stock hole ...   Jan 15 2020, 11:00 AM
bbrock   Our current game plan is to go back to stock hole...   Jan 15 2020, 11:05 AM
914lover17   Our current game plan is to go back to stock hole...   Sep 7 2021, 09:34 PM
jfort   glad to see this thread. my kit is somewhere, neve...   Jan 15 2020, 01:47 PM
bbrock   glad to see this thread. my kit is somewhere, nev...   Jan 15 2020, 03:27 PM
Front yard mechanic   Just use bailing wire and end the bitching :stooge...   Sep 8 2021, 06:34 AM
- Lo-Fi Version Time is now: 19th September 2026 - 02:55 AM
