> Pertronix Ignitor III, any experience P-related or not?
sportlicherFahrer
post Apr 6 2015, 06:15 PM
Nothing to see here.
Was checking up on ignition upgrades from Pertronix again and saw that they offer the Ignitor III for our vacuum dizzies now. Supposed to work like a box style ignition without the box(multiple spark, rev limiter). Did a search here and didn't see anything for that model. Anybody used an Ignitor III and have any useful feedback on or off a Porsche? Not looking for opinions on whether or not Pertronix belongs in our cars or not, just on the functionality of the Ignitor III. With that said, I know this may start a (IMG:style_emoticons/default/stromberg.gif) storm..... (IMG:style_emoticons/default/stirthepot.gif)
sportlicherFahrer
post Dec 9 2019, 05:52 AM
I honestly don't have any hard data on the differences between a Bosch 009 and the flamethrower. My flamethrower ran like crap, and my stock distributor with the pertronix ignitor II driving my 6AL runs strong as hell.
As far as your 009 running fine, it all comes down to how you have your particular engine dialed in I suppose. From what I've read and experienced over the years, I don't think they have the optimal advance curve for any road going application. Fine for idle to WOT on a track, which is where they gained popularity with the big crowd. Just my opinion though.
Haven't seen a true evaluation of vac vs. no vac. That'd be interesting to see.
Gatornapper
post Dec 9 2019, 08:20 AM
Seems this should be so simple - but it's not.
Seems like the least expensive path to great carb performance (Pelican: here -
https://www.pelicanparts.com/techarticles/9...iming_carbs.htm )
would be a 205AA dizzy with vacuum advance, Pertronix ignitor, and MDS with timing set at 34 deg. BTDC at 3200 rpm.
But it appears you cannot get a 205AA anywhere at a reasonable cost.
I'm reluctant to get another 009 - although at one time mine ran fine - because of comments here.....and a 123 is out of my budget and a goal someday.....
GN
QUOTE(sportlicherFahrer @ Dec 9 2019, 06:52 AM) *
sportlicherFahrer   Pertronix Ignitor III   Apr 6 2015, 06:15 PM
76-914   :popcorn:   Apr 6 2015, 09:38 PM
colingreene   I personally have had problems with the parts they...   Apr 7 2015, 11:00 AM
Java2570   I've heard of others using Ignitor II but I...   Apr 7 2015, 12:20 PM
SLITS   I've heard of others using Ignitor II but I...   Apr 7 2015, 12:48 PM
SKL1   Why would this be better than Permatune? I'v...   Apr 7 2015, 12:45 PM
Dave_Darling   Why would this be better than Permatune? The Per...   May 25 2015, 08:35 PM
sportlicherFahrer   Part number 71847v. They run about $130 on S...   Apr 7 2015, 01:01 PM
Java2570   I don't see the specific instructions for the ...   Apr 7 2015, 01:27 PM
euro911   I've been running a -II on my 2056 for over 3 ...   May 25 2015, 04:55 PM
boxsterfan   Opinions on the Pertronix are like reviews on Amaz...   May 25 2015, 05:23 PM
cuddyk   I have a P-III on my 65 mustang. Works great. The ...   May 25 2015, 09:17 PM
Jetsetsurfshop   You guys that are using the Pertronix III, what co...   Aug 10 2017, 04:48 PM
Perry Kiehl   Jet, check the classifieds. I have a Pertronix SVD...   Aug 10 2017, 06:20 PM
bandjoey   II installed on otherwise stock (blue coil) motor....   Aug 10 2017, 07:13 PM
solex   I just installed the III and cannot seem to get th...   Aug 11 2019, 01:39 PM
porschetub   I just installed the III and cannot seem to get t...   Aug 11 2019, 03:14 PM
bbrock   According to the Pertronix III instructions, it is...   Aug 11 2019, 03:45 PM
SteveL   I have had a Pertronix in place of the points for ...   Aug 11 2019, 03:53 PM
solex   I checked everything even called Pertronix prior t...   Aug 11 2019, 05:18 PM
Gatornapper   My dizzy just went bad & I have MSD and see th...   Dec 7 2019, 06:58 PM
solex   Spoke with Carl from Pertronix. (1) I'm on va...   Aug 15 2019, 08:35 AM
sportlicherFahrer   :wavebye: OP here. I ended up canning the Ignitor...   Aug 16 2019, 07:12 PM
solex   Got it running, after checking everything I had m...   Aug 22 2019, 12:24 PM
Rand   Pertronix worked great for me for 20+ years. Then ...   Aug 22 2019, 02:29 PM
Al Meredith   I've had problems with two pertronix units . I...   Aug 22 2019, 02:43 PM
solex   I've had problems with two pertronix units . ...   Aug 22 2019, 04:07 PM
solex   I have given up. I order there epoxy coil with 0....   Aug 31 2019, 04:45 PM
ndfrigi   here is my experienced with pertronix, bought my ...   Aug 31 2019, 05:22 PM
solex   I have no doubt that Pertronix I & II works ba...   Sep 2 2019, 04:13 PM
sportlicherFahrer   The 009 and pertronix units will "work" ...   Dec 7 2019, 07:13 PM
Gatornapper   Jim - PRICELESS information - thank you. You kno...   Dec 7 2019, 07:53 PM
Gatornapper   Hmmm.....just thinking - my '76 2.0 was runnin...   Dec 7 2019, 08:33 PM
rbzymek   I installed a Pertronix III ignitor, Flamethrower ...   Dec 7 2019, 07:52 PM
Gatornapper   Thanks for the info......... I'd love the 123...   Dec 7 2019, 07:57 PM
sportlicherFahrer   I'm running with 40's on mine. Stock cam w...   Dec 7 2019, 08:22 PM
Gatornapper   Jim - Totally got you on the vacuum lines being ...   Dec 7 2019, 08:48 PM
sportlicherFahrer   I honestly don't have any hard data on the dif...   Dec 9 2019, 05:52 AM
Gatornapper   Seems this should be so simple - but it's not....   Dec 9 2019, 08:20 AM
sportlicherFahrer   I've also heard of folks using the 205AB from ...   Dec 9 2019, 08:29 AM
sportlicherFahrer   Checking out the pertronix website, it looks like ...   Dec 9 2019, 09:10 AM
Gatornapper   Asked Pertronix about this - it will not fit/work ...   Dec 10 2019, 12:25 PM
Gatornapper   Decision made. Ordered new 009 dizzy from AA and ...   Dec 9 2019, 10:49 AM
ClayPerrine   Decision made. Ordered new 009 dizzy from AA and...   Dec 10 2019, 07:17 AM
Gatornapper   Clay - Thanks. Car had an 009 in it when I got i...   Dec 10 2019, 12:37 PM
Gatornapper   Clay & Perry - What is it about the advance c...   Dec 10 2019, 02:50 PM
rbzymek   Clay, What is the best option for a 1.8L dizzy sho...   Dec 10 2019, 07:46 AM
ClayPerrine   Clay, What is the best option for a 1.8L dizzy sh...   Dec 10 2019, 10:52 AM
IronHillRestorations   009 is a great distributor, for a generator engine   Dec 10 2019, 07:56 AM
Gatornapper   As you said, "The "009" mechanical ...   Dec 12 2019, 09:11 PM
sportlicherFahrer   Saw reviews on Amazon and Summit of guys running t...   Dec 10 2019, 12:33 PM
Gatornapper   Jim - Very interesting - but the 009 is on the wa...   Dec 10 2019, 12:52 PM
rhodyguy   It will work. Just not optimized curve. Find TDC o...   Dec 10 2019, 02:08 PM
Gatornapper   Sitting on TDC right now........of course, no mark...   Dec 10 2019, 03:13 PM
sportlicherFahrer   Should be able to see the notch on the flywheel th...   Dec 10 2019, 03:18 PM
Gatornapper   Already did that. Used small mirror to see 27 deg...   Dec 10 2019, 03:23 PM
Gatornapper   Ok, seeing from this chart what may be the issue. ...   Dec 10 2019, 03:22 PM
yeahmag   It may have been mentioned, but the 009 has too mu...   Dec 10 2019, 05:58 PM
Gatornapper   Aaron - Thank you. Ok, guys. What are my altern...   Dec 10 2019, 06:32 PM
Gatornapper   Aaron - The total advance is easily reduced by be...   Dec 10 2019, 07:17 PM
Tdskip   Great chart, helps to visualize the considerations...   Dec 10 2019, 06:39 PM
Gatornapper   TD - No mud at all. I looked at these and seriou...   Dec 10 2019, 06:53 PM
Tdskip   TD - No mud at all. I looked at these and serio...   Dec 11 2019, 09:14 AM
Gatornapper   Wondering where I could get a Bosche 009 made in B...   Dec 10 2019, 08:05 PM
Tdskip   Wondering where I could get a Bosche 009 made in ...   Dec 11 2019, 08:34 AM
Gatornapper   Have you used them? If so, what has been your exp...   Dec 11 2019, 09:29 AM
Gatornapper   Found the advance curve for the Pertronix D182504 ...   Dec 10 2019, 09:04 PM
ClayPerrine   If you are looking for a distributor that works we...   Dec 11 2019, 02:28 PM
Gatornapper   Clay - Thank you! What distributor would tha...   Dec 11 2019, 08:09 PM
ClayPerrine   I don't know the part number, but you should b...   Dec 11 2019, 09:54 PM
Gatornapper   Clay - Thanks. Talked to Pelican yesterday - the...   Dec 12 2019, 07:39 AM
ClayPerrine   Clay - Thanks. Talked to Pelican yesterday - th...   Dec 12 2019, 08:22 AM
Gatornapper   Clay - Do you see the '74 1.8 dizzy on either...   Dec 12 2019, 09:57 AM
IronHillRestorations   I put a brand new Pertronix SVDA on a customer car...   Dec 12 2019, 07:50 AM
Gatornapper   Perry - Yes - their track record does not look go...   Dec 12 2019, 09:49 AM
Gatornapper   Perry - Word seems to be that you do NOT leave th...   Dec 12 2019, 09:53 AM
Tdskip   This thread is practically begging for a table tha...   Dec 12 2019, 08:49 AM
Gatornapper   Bulls-eye. This thread is practically begging fo...   Dec 12 2019, 09:49 AM
sportlicherFahrer   The ignitor I is prone to failure with KOEO for ex...   Dec 12 2019, 10:07 AM
Gatornapper   Jim - Good news - makes sense Pertronix would fi...   Dec 12 2019, 05:15 PM
rbzymek   So I have a and OE dizzy that came off of a 1.8L ,...   Dec 12 2019, 04:27 PM
Gatornapper   I'm guessing, but the chart here https://www...   Dec 12 2019, 05:14 PM
Gatornapper   From the Pelican Parts forum post in 2001, the diz...   Dec 12 2019, 09:17 PM
914werke   The ignitor I is prone to failure with KOEO for ex...   Dec 12 2019, 07:23 PM
Gatornapper   Rich - Sorry - I'm relatively new at this 914...   Dec 13 2019, 08:50 AM
Gatornapper   Best price yet - Dansk - says it's for '74...   Dec 12 2019, 08:56 PM
Gatornapper   VERY INTERESTING. A Pelican Parts forum discussio...   Dec 12 2019, 09:04 PM
rbzymek   GN- I copied the dizzy part wrong. The good one i...   Dec 13 2019, 09:37 AM
Gatornapper   Ray - Thanks - I did have the correct number. No...   Dec 13 2019, 10:05 AM
rbzymek   Go with WTB. That's where I found mine for ...   Dec 13 2019, 10:13 AM
Tdskip   Hold on here - so we are putting down for future r...   Dec 13 2019, 10:31 AM
rbzymek   So the 231 181 009 aka 022 905 205AA has a curve d...   Dec 13 2019, 10:52 AM
Gatornapper   I agree - research I have done confirms that.........   Dec 13 2019, 10:58 AM
Gatornapper   What I'd like to know is where does the 022 90...   Dec 13 2019, 11:03 AM
rbzymek   FYI....   Dec 13 2019, 11:47 AM
Gatornapper   AH-HA! It's a VW Part number! The 0 ...   Dec 13 2019, 11:55 AM
Gatornapper   Wondering if at this point we shouldn't move t...   Dec 13 2019, 12:28 PM
rbzymek   GN, That's the Bosch number 231 181 009. The V...   Dec 13 2019, 02:38 PM
Gatornapper   NOW it makes sense! Thank you! On the Pe...   Dec 13 2019, 06:59 PM
rbzymek   Here is a graph of the curve base on the Pelican t...   Dec 13 2019, 02:55 PM
- Lo-Fi Version Time is now: 6th June 2026 - 01:40 PM
