| mepstein |
Dec 7 2019, 09:58 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,915 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Help me understand. The door stay kit I’m using comes with a pin but it’s too big for the hole. I could make the hole bigger but there’s still no groove for a clip. Stock pin on right
? @Mikey914 Attached thumbnail(s) |
| Mikey914 |
Dec 9 2019, 02:00 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
We initially made them to the OEM size. The complaint was they "clicked" when the doors opened and closed. Problem was that not everyone had the problem. So we made them slightly larger to eliminate the problem. They can be easily filed down to get a get a custom fit for your car.
It's the only way to get a perfect fit. By the way the steering rack rebuild service we do has a similar issue. The shafts often are darkened with oxidation and pitting. We actually make our bushings with a smaller diameter and hone each one for a perfect fit (after we polish the shaft). The idea is that the tolerance will be back to if not tighter than the factory, but the process was difficult enough that we don't sell the bushings stand alone as the process of educating and with different levels of capabilities we would have a more difficult time selling just the parts. The parallel is that there are varying levels of degradation in the mount holes. Fortunately this is a pretty simple application. Gravity makes the clip redundant, they are difficult enough to remove when you are trying. |
| raynekat |
Dec 10 2019, 11:18 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,171 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest
So we made them slightly larger to eliminate the problem. They can be easily filed down to get a get a custom fit for your car. Mark of 914Rubber. The only problem with this is that if you file the pins a bit smaller, then they are too small for your lever arms. You'll get clicking there just as well. Pins might fit tight in the chassis receivers, but will will loose in your arms. |
mepstein Door stay kit Dec 7 2019, 09:58 PM
Krieger Iirc the pins were made oversized because the mont... Dec 8 2019, 12:07 AM
Iirc the pins were made oversized because the mon... Dec 8 2019, 07:47 AM
mb911 That explains why they fit so tight for me and end... Dec 8 2019, 05:48 AM
roblav1 Turn 'em on a lathe!
On mine, which I just... Dec 8 2019, 07:18 AM
FlacaProductions Check here (specifically posts 14 and 16):
http://... Dec 8 2019, 08:42 AM
914forme :agree: So my plans to be buried in space in my 9... Dec 9 2019, 04:40 AM
Mikey914 Yes we are trying to be a little more clear for ou... Dec 9 2019, 10:29 AM
mepstein I appreciate that 914rubber is making the parts. I... Dec 9 2019, 10:50 AM
BeatNavy
I appreciate that 914rubber is making the parts. ... Dec 10 2019, 08:52 AM
raynekat So if I have to file the pin smaller to fit the ho... Dec 10 2019, 01:43 AM
bbrock I happened to glance at the door stay on my Nissan... Dec 10 2019, 08:37 AM
Bartlett 914
I happened to glance at the door stay on my Nissa... Dec 11 2019, 08:54 AM
Mikey914 Forgot we did change the arms. So perhaps This nex... Dec 10 2019, 11:51 PM
Superhawk996 Wow! Hard group to please on this topic.
L... Dec 11 2019, 06:06 AM
mepstein I think it would be helpful to print in the part d... Dec 11 2019, 07:21 AM
ThePaintedMan :agree: They do one heck of a job trying to please... Dec 11 2019, 07:43 AM
Mikey914 Guys,
I do really appreciate the input. We made ch... Dec 11 2019, 07:50 AM
Guys,
I do really appreciate the input. We made c... Dec 11 2019, 08:33 AM
ctc911ctc All,
I bought this kit for both doors and install... Dec 18 2019, 04:21 PM
Mikey914
All,
I bought this kit for both doors and instal... Dec 18 2019, 05:12 PM
oldschool I've been hoping to get the repair kit.......S... Dec 18 2019, 11:07 PM
bbrock @[url=http://www.914world.com/bbs2/index.php?showu... Jan 15 2020, 10:37 AM
Mikey914 Our current game plan is to go back to stock hole ... Jan 15 2020, 11:00 AM
bbrock
Our current game plan is to go back to stock hole... Jan 15 2020, 11:05 AM
914lover17
Our current game plan is to go back to stock hole... Sep 7 2021, 09:34 PM
jfort glad to see this thread. my kit is somewhere, neve... Jan 15 2020, 01:47 PM
bbrock
glad to see this thread. my kit is somewhere, nev... Jan 15 2020, 03:27 PM
Front yard mechanic Just use bailing wire and end the bitching :stooge... Sep 8 2021, 06:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 19th September 2026 - 02:56 AM |
