> touring power, build an engine !!!!
orangecrate
post Dec 7 2019, 11:33 AM
So I been workin on the orangecrate off an on for what seems like forever... seems I now have rod issues. Knock knock.... Any way I'm lookin at building a motor, or rebuilding. Inexpensively (IMG:style_emoticons/default/lol-2.gif) I have only 2 real conditions I want to meet. 1- It will run 80 mph all day thru the desert in the summer in Phoenix and sit at stoplights with out cooking itself. 2- It will pull the 6% grades that you hit leaving the valley at 70 in the summer without cooking itself. 75 would be nicer. Guess I"m talking a torque motor. This is a stock 72 with stock gearing. And maybe one size up tires. Did I say it needs to be reliable? Like Phoenix to Portland and back any time of year reliable. And inexpensive.. I'd love to buy a Raby motor but $$$. Oh yea. I will be doing the assembly myself. And I'd like to use as much of the 1.7 as possible if possible. Thanks for the input. Build away. (IMG:style_emoticons/default/beer.gif)
Bleyseng
post Dec 10 2019, 04:13 PM
Aircooled Baby!
Sorry, there is no waay I’d a Subie in 914. Just hot thru rebuilding and installing a 2.5l in my son’s Synchro vanagon and its really nice but but not in a 914 come on!
Len’s heads are the way to go for sure and its easy to get 120-130hp in a 2056 . Mine revs to 6500 rpms easy cruises all day at 100 mph.
orangecrate   touring power   Dec 7 2019, 11:33 AM
mepstein   Add an oil cooler. Tangerine makes a bolt on kit.   Dec 7 2019, 12:32 PM
Superhawk996   2.0L Stock or maybe 2056 is probably the sweet spo...   Dec 7 2019, 12:55 PM
Mark Henry   First is it knocking? Many newbies mistake a ...   Dec 7 2019, 01:44 PM
orangecrate   First is it knocking? Many newbies mistake a ...   Dec 7 2019, 03:31 PM
ctc911ctc   First is it knocking? Many newbies mistake a ...   Dec 12 2019, 11:42 AM
rhodyguy   Do the 1.7 case spigots and heads limit cyl/piston...   Dec 7 2019, 01:58 PM
Superhawk996   Do the 1.7 case spigots and heads limit cyl/pisto...   Dec 7 2019, 02:56 PM
orangecrate   Do the 1.7 case spigots and heads limit cyl/pist...   Dec 7 2019, 03:51 PM
orangecrate   [quote name='Superhawk996' post='2768...   Dec 7 2019, 03:57 PM
Bleyseng   As Superhawk says - a 2056cc with a external oil c...   Dec 7 2019, 02:33 PM
orangecrate   As Superhawk says - a 2056cc with a external oil ...   Dec 7 2019, 04:06 PM
Mark Henry   As Superhawk says - a 2056cc with a external oil...   Dec 7 2019, 04:16 PM
orangecrate   There is a very good Porsche wrecking yard in PHX....   Dec 7 2019, 04:04 PM
Superhawk996   There is a very good Porsche wrecking yard in PHX...   Dec 7 2019, 04:38 PM
Superhawk996   There is a very good Porsche wrecking yard in PHX...   Dec 7 2019, 04:49 PM
Tdskip   My rebuilt 1.7L 66m crank with 96mm pistons = 191...   Dec 8 2019, 08:32 PM
Superhawk996   showuser=22428]Superhawk996 - just a 2.0L of 205...   Dec 8 2019, 09:25 PM
thelogo   Building a expensive .aircooled .motor that need t...   Dec 8 2019, 02:32 PM
Tdskip   @Superhawk996 - thanks for the response but I wa...   Dec 9 2019, 07:16 AM
Superhawk996   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 9 2019, 06:13 PM
orangecrate   Been doin a little figuring and thinking . Based ...   Dec 9 2019, 08:11 AM
914forme   Have you checked into Original Customs engine prog...   Dec 9 2019, 08:41 AM
mepstein   Have you checked into [url=http://www.originalcus...   Dec 9 2019, 09:32 AM
rhodyguy   Doing it right, chances are you will need machine ...   Dec 9 2019, 09:56 AM
Tdskip   @superhawk996 - thanks for following up and good...   Dec 10 2019, 09:46 AM
VaccaRabite   When I did my motor (2056) it started as a 1.7L ca...   Dec 10 2019, 10:32 AM
Tdskip   Super helpful post Zach   Dec 10 2019, 10:36 AM
Bleyseng   Sorry, there is no waay I’d a Subie in 914. Just...   Dec 10 2019, 04:13 PM
orangecrate   What are y'all's thoughts on a 1911 ?? I...   Dec 10 2019, 08:48 PM
Tdskip   What are y'all's thoughts on a 1911 ?? ...   Dec 10 2019, 09:14 PM
michael7810   What are y'all's thoughts on a 1911 ?? ...   Dec 12 2019, 09:20 AM
Bleyseng   Its going cost about the same to build a stock 1.7...   Dec 11 2019, 12:57 PM
VaccaRabite   1911 can be a great engine making similar power to...   Dec 12 2019, 11:36 AM
orangecrate   1911 can be a great engine making similar power t...   Dec 28 2019, 06:45 PM
Tdskip   Good luck and please keep us posted   Dec 28 2019, 08:16 PM
MM1   Did you ever get that stock 1.7 running?   Nov 2 2020, 06:07 PM
rbzymek   So when my 1975 1.8L overheated and failed with lo...   Nov 2 2020, 07:45 PM
- Lo-Fi Version Time is now: 17th October 2026 - 03:50 PM
