> 914World Classifieds Rules
> FS Engine jack tool and leftover parts, Tangerine R. engine lift tool for floor jack $100
marksteinhilber
post Dec 9 2019, 04:20 PM
(SOLD) Fiberglass front air dam. Not stock or LE valence. Has been reinforced at tabs and there are some other FG repairs on backside, ready to prep and paint. accepts rubber lower skirt from 914 rubber, but none included. $70
(SOLD) Tangerine Racing jack tool for changing engines. Has round dowel plug that drops into standard floor jack. Does not fit Harbor Freight Pittsburg and other brands that has screw in fitting. $100 plus shipping
(SOLD) rear reflector - PORSCHE between taillights for 914. Trunk lock must be removed, but trunk can be opened using small push rod through small hole in reflector, or by setting up a remote cable release. $60 for reflector, unfortunately I couldn't find the 12V release solenoid.
(SOLD) targa sail bottom narrow chrome moldings, Left side is brand new from Sierra Madre, in package, with 4 clips. Right side is used but good condition, no clips. Old ones from your car can be reused. new were about $30 each. $35 for the pair.
sail rear trim hold down bracket. one only for L or R. shown in photo with targa side trim mouldings $8
(SOLD) 1975-76 914 door cards, Right and Left. no significant rips visible, but masonite board has some warp due to moisture, useable, restorable. most hardware for handles and pockets have been removed and not included $20 each Local pickup suggested.
(SOLD) 914 US tail light assembly ® with lens & bulbs, good working condition, no melts or cracks in housing. decent rear seal. needs new lens seal. Lens is driver quality with crazing, some faint stress cracks, and is missing one of the three threaded holders. Crazing and cracks don't leak water. no hex nuts or washers for housing. $40 matching (L) tail light lens also driver quality, with some crazing. $10
Passenger foam footrest $25
(SOLD)Drivers plywood footboard with throttle stop $15
Working AM FM Sapphire radio complete with faceplate and knobs. Correct for 74 faceplate weave. I have video of it playing available. Mono $250 possible show car resto???
Shifter plastic bushing, dirty but new $4
Gearbox side shift console with fork and bronze slider bushings. Bronze bushings need to be brazed together to stay in place or the bronze bushing needs a groove machined to add a circlip. roll pin in ball fitting has slop that needs attention. I fixed another of these by drilling and tapping for a set screw at 90 degrees to roll pin. $40
(SOLD) Steel repair parts. L and R footwell corners inside front wheel wells. You harvest what you need instead of fabricating part that is not made. Has jacking donuts too! $20 each. I can cut these down to what you want for shipping if desired.
(SOLD) Wiper sheet metal valence pieces. Not perfect, but easier to fix these parts than to fab new parts from scratch. Or use for repair pieces to repair curved channels. $10 per side.
Driver side inner and outer suspension console. From dry Cali car. very little rust in hell hole area. I can harvest what you need from this piece so you can install. $150 harvested. $80 as is but is bulky to ship.
[attachmentid=722
252]Attached Image[attachmentid
=722257]Attached Image Attached Image
marksteinhilber
post Dec 11 2019, 12:47 PM
bdstone has spoken for the engine jack lift plate and it is sold.
I have edited the listing to include more condition information and pictures. The following people are first in line for parts after considering updated pictures and condition:
racingredsc - sail panel bottom trim and taillight parts.
pneuhyde - first in line on center reflector. I have another one that is different as wall art in my son's room. This one is likely a reproduction and doesn't show any type of hexagonal pattern in the reflectors, more of a metal flake look behind the acrylic face. This one is priced accordingly and would also make nice wall art.
pneuhyde
post Dec 11 2019, 08:58 PM
QUOTE(marksteinhilber @ Dec 11 2019, 11:47 AM) *
Thanks Mark. I think I will bow out, Not looking for a wall hanging
Steve
marksteinhilber   FS Engine jack tool and leftover parts   Dec 9 2019, 04:20 PM
bdstone914   I will take the engine plate. Bruce   Dec 9 2019, 05:49 PM
MM1   I assume BDStone914 meant the Tangerine Racing jac...   Dec 9 2019, 06:08 PM
Thunderchief   I already have the rear reflector but if you can f...   Dec 9 2019, 06:15 PM
marksteinhilber   I already have the rear reflector but if you can ...   Dec 11 2019, 10:40 AM
racingredsc   I will take the sail panel trim. Any pictures?   Dec 9 2019, 06:46 PM
racingredsc   I will take the sail panel trim. Any pictures? A...   Dec 9 2019, 06:48 PM
marksteinhilber   Wow, quick responses. Bruce will get the Tangerin...   Dec 10 2019, 12:07 PM
pneuhyde   Wow, quick responses. Bruce will get the Tangeri...   Dec 10 2019, 05:55 PM
marksteinhilber   bdstone has spoken for the engine jack lift plate ...   Dec 11 2019, 12:47 PM
pneuhyde   bdstone has spoken for the engine jack lift plate...   Dec 11 2019, 08:58 PM
Craigers17   Mark, I'll take the fiberglass air dam if you...   Dec 12 2019, 02:17 AM
marksteinhilber   Mark, I'll take the fiberglass air dam if yo...   Dec 16 2019, 06:41 PM
mepstein   I sent 6 steel bumpers x-country to Oscar - DE to ...   Dec 16 2019, 06:57 PM
marksteinhilber   I sent 6 steel bumpers x-country to Oscar - DE to...   Dec 16 2019, 11:21 PM
bkrantz   Do you still have the L and R front floor corners?...   Dec 16 2019, 10:11 PM
marksteinhilber   Do you still have the L and R front floor corners...   Dec 16 2019, 11:16 PM
bkrantz   Do you still have the L and R front floor corner...   Dec 17 2019, 08:57 PM
Tdskip   Can I grab the Wiper sheet metal valence pieces pl...   Dec 18 2019, 12:01 PM
marksteinhilber   Can I grab the Wiper sheet metal valence pieces p...   Dec 20 2019, 12:59 PM
DMAYHALL   Are the door cards still available ?   Jan 13 2020, 12:10 PM
DMAYHALL   Will take the door cards if still available, thank...   Jan 13 2020, 10:29 PM
- Lo-Fi Version Time is now: 9th September 2026 - 11:36 AM
