> Pertronix Ignitor III, any experience P-related or not?
sportlicherFahrer
post Apr 6 2015, 06:15 PM
Nothing to see here.
Was checking up on ignition upgrades from Pertronix again and saw that they offer the Ignitor III for our vacuum dizzies now. Supposed to work like a box style ignition without the box(multiple spark, rev limiter). Did a search here and didn't see anything for that model. Anybody used an Ignitor III and have any useful feedback on or off a Porsche? Not looking for opinions on whether or not Pertronix belongs in our cars or not, just on the functionality of the Ignitor III. With that said, I know this may start a (IMG:style_emoticons/default/stromberg.gif) storm..... (IMG:style_emoticons/default/stirthepot.gif)
ClayPerrine
post Dec 11 2019, 02:28 PM
If you are looking for a distributor that works well with carbs, get the stock distributor for a 74-74 1.8L L-Jet engine.
Then get this from Pertronix.
https://pertronix.com/electronic-ignition-c...;model=914#auto
Any of the three will work fine. The Ignitor I is what we have been running for years.
Put it in, set the timing to 7.5 degrees at idle. Leave both vacuum connections disconnected.
Then (IMG:style_emoticons/default/driving.gif)
Gatornapper
post Dec 11 2019, 08:09 PM
Clay -
Thank you! What distributor would that be?
The Pertronix was ordered Monday and will be here next Monday.......
RE: The advance curve on the Dansk (which is now $67) - Pelican Parts does not have that information and sent me to the European supplier for the Dansk distributor.
Every indication is that the Dansk is a clone of the 009 and thus shares the advance curve of the 009........
GN
QUOTE(ClayPerrine @ Dec 11 2019, 03:28 PM) *
ClayPerrine
post Dec 11 2019, 09:54 PM
I don't know the part number, but you should be able to place a wanted to buy ad in the parts forum.
Clay
QUOTE(Gatornapper @ Dec 11 2019, 08:09 PM) *
Clay -
GN
Gatornapper
post Dec 12 2019, 07:39 AM
Clay -
Thanks. Talked to Pelican yesterday - they say the dizzy for the '74 1.8 is the Dansk, which is a clone of the 009........which I now have 2 of........
hmmmm.............
GN
QUOTE(ClayPerrine @ Dec 11 2019, 10:54 PM) *
Clay
Clay -
GN
sportlicherFahrer   Pertronix Ignitor III   Apr 6 2015, 06:15 PM
76-914   :popcorn:   Apr 6 2015, 09:38 PM
colingreene   I personally have had problems with the parts they...   Apr 7 2015, 11:00 AM
Java2570   I've heard of others using Ignitor II but I...   Apr 7 2015, 12:20 PM
SLITS   I've heard of others using Ignitor II but I...   Apr 7 2015, 12:48 PM
SKL1   Why would this be better than Permatune? I'v...   Apr 7 2015, 12:45 PM
Dave_Darling   Why would this be better than Permatune? The Per...   May 25 2015, 08:35 PM
sportlicherFahrer   Part number 71847v. They run about $130 on S...   Apr 7 2015, 01:01 PM
Java2570   I don't see the specific instructions for the ...   Apr 7 2015, 01:27 PM
euro911   I've been running a -II on my 2056 for over 3 ...   May 25 2015, 04:55 PM
boxsterfan   Opinions on the Pertronix are like reviews on Amaz...   May 25 2015, 05:23 PM
cuddyk   I have a P-III on my 65 mustang. Works great. The ...   May 25 2015, 09:17 PM
Jetsetsurfshop   You guys that are using the Pertronix III, what co...   Aug 10 2017, 04:48 PM
Perry Kiehl   Jet, check the classifieds. I have a Pertronix SVD...   Aug 10 2017, 06:20 PM
bandjoey   II installed on otherwise stock (blue coil) motor....   Aug 10 2017, 07:13 PM
solex   I just installed the III and cannot seem to get th...   Aug 11 2019, 01:39 PM
porschetub   I just installed the III and cannot seem to get t...   Aug 11 2019, 03:14 PM
bbrock   According to the Pertronix III instructions, it is...   Aug 11 2019, 03:45 PM
SteveL   I have had a Pertronix in place of the points for ...   Aug 11 2019, 03:53 PM
solex   I checked everything even called Pertronix prior t...   Aug 11 2019, 05:18 PM
Gatornapper   My dizzy just went bad & I have MSD and see th...   Dec 7 2019, 06:58 PM
solex   Spoke with Carl from Pertronix. (1) I'm on va...   Aug 15 2019, 08:35 AM
sportlicherFahrer   :wavebye: OP here. I ended up canning the Ignitor...   Aug 16 2019, 07:12 PM
solex   Got it running, after checking everything I had m...   Aug 22 2019, 12:24 PM
Rand   Pertronix worked great for me for 20+ years. Then ...   Aug 22 2019, 02:29 PM
Al Meredith   I've had problems with two pertronix units . I...   Aug 22 2019, 02:43 PM
solex   I've had problems with two pertronix units . ...   Aug 22 2019, 04:07 PM
solex   I have given up. I order there epoxy coil with 0....   Aug 31 2019, 04:45 PM
ndfrigi   here is my experienced with pertronix, bought my ...   Aug 31 2019, 05:22 PM
solex   I have no doubt that Pertronix I & II works ba...   Sep 2 2019, 04:13 PM
sportlicherFahrer   The 009 and pertronix units will "work" ...   Dec 7 2019, 07:13 PM
Gatornapper   Jim - PRICELESS information - thank you. You kno...   Dec 7 2019, 07:53 PM
Gatornapper   Hmmm.....just thinking - my '76 2.0 was runnin...   Dec 7 2019, 08:33 PM
rbzymek   I installed a Pertronix III ignitor, Flamethrower ...   Dec 7 2019, 07:52 PM
Gatornapper   Thanks for the info......... I'd love the 123...   Dec 7 2019, 07:57 PM
sportlicherFahrer   I'm running with 40's on mine. Stock cam w...   Dec 7 2019, 08:22 PM
Gatornapper   Jim - Totally got you on the vacuum lines being ...   Dec 7 2019, 08:48 PM
sportlicherFahrer   I honestly don't have any hard data on the dif...   Dec 9 2019, 05:52 AM
Gatornapper   Seems this should be so simple - but it's not....   Dec 9 2019, 08:20 AM
sportlicherFahrer   I've also heard of folks using the 205AB from ...   Dec 9 2019, 08:29 AM
sportlicherFahrer   Checking out the pertronix website, it looks like ...   Dec 9 2019, 09:10 AM
Gatornapper   Asked Pertronix about this - it will not fit/work ...   Dec 10 2019, 12:25 PM
Gatornapper   Decision made. Ordered new 009 dizzy from AA and ...   Dec 9 2019, 10:49 AM
ClayPerrine   Decision made. Ordered new 009 dizzy from AA and...   Dec 10 2019, 07:17 AM
Gatornapper   Clay - Thanks. Car had an 009 in it when I got i...   Dec 10 2019, 12:37 PM
Gatornapper   Clay & Perry - What is it about the advance c...   Dec 10 2019, 02:50 PM
rbzymek   Clay, What is the best option for a 1.8L dizzy sho...   Dec 10 2019, 07:46 AM
ClayPerrine   Clay, What is the best option for a 1.8L dizzy sh...   Dec 10 2019, 10:52 AM
IronHillRestorations   009 is a great distributor, for a generator engine   Dec 10 2019, 07:56 AM
Gatornapper   As you said, "The "009" mechanical ...   Dec 12 2019, 09:11 PM
sportlicherFahrer   Saw reviews on Amazon and Summit of guys running t...   Dec 10 2019, 12:33 PM
Gatornapper   Jim - Very interesting - but the 009 is on the wa...   Dec 10 2019, 12:52 PM
rhodyguy   It will work. Just not optimized curve. Find TDC o...   Dec 10 2019, 02:08 PM
Gatornapper   Sitting on TDC right now........of course, no mark...   Dec 10 2019, 03:13 PM
sportlicherFahrer   Should be able to see the notch on the flywheel th...   Dec 10 2019, 03:18 PM
Gatornapper   Already did that. Used small mirror to see 27 deg...   Dec 10 2019, 03:23 PM
Gatornapper   Ok, seeing from this chart what may be the issue. ...   Dec 10 2019, 03:22 PM
yeahmag   It may have been mentioned, but the 009 has too mu...   Dec 10 2019, 05:58 PM
Gatornapper   Aaron - Thank you. Ok, guys. What are my altern...   Dec 10 2019, 06:32 PM
Gatornapper   Aaron - The total advance is easily reduced by be...   Dec 10 2019, 07:17 PM
Tdskip   Great chart, helps to visualize the considerations...   Dec 10 2019, 06:39 PM
Gatornapper   TD - No mud at all. I looked at these and seriou...   Dec 10 2019, 06:53 PM
Tdskip   TD - No mud at all. I looked at these and serio...   Dec 11 2019, 09:14 AM
Gatornapper   Wondering where I could get a Bosche 009 made in B...   Dec 10 2019, 08:05 PM
Tdskip   Wondering where I could get a Bosche 009 made in ...   Dec 11 2019, 08:34 AM
Gatornapper   Have you used them? If so, what has been your exp...   Dec 11 2019, 09:29 AM
Gatornapper   Found the advance curve for the Pertronix D182504 ...   Dec 10 2019, 09:04 PM
ClayPerrine   If you are looking for a distributor that works we...   Dec 11 2019, 02:28 PM
Gatornapper   Clay - Thank you! What distributor would tha...   Dec 11 2019, 08:09 PM
ClayPerrine   I don't know the part number, but you should b...   Dec 11 2019, 09:54 PM
Gatornapper   Clay - Thanks. Talked to Pelican yesterday - the...   Dec 12 2019, 07:39 AM
ClayPerrine   Clay - Thanks. Talked to Pelican yesterday - th...   Dec 12 2019, 08:22 AM
Gatornapper   Clay - Do you see the '74 1.8 dizzy on either...   Dec 12 2019, 09:57 AM
IronHillRestorations   I put a brand new Pertronix SVDA on a customer car...   Dec 12 2019, 07:50 AM
Gatornapper   Perry - Yes - their track record does not look go...   Dec 12 2019, 09:49 AM
Gatornapper   Perry - Word seems to be that you do NOT leave th...   Dec 12 2019, 09:53 AM
Tdskip   This thread is practically begging for a table tha...   Dec 12 2019, 08:49 AM
Gatornapper   Bulls-eye. This thread is practically begging fo...   Dec 12 2019, 09:49 AM
sportlicherFahrer   The ignitor I is prone to failure with KOEO for ex...   Dec 12 2019, 10:07 AM
Gatornapper   Jim - Good news - makes sense Pertronix would fi...   Dec 12 2019, 05:15 PM
rbzymek   So I have a and OE dizzy that came off of a 1.8L ,...   Dec 12 2019, 04:27 PM
Gatornapper   I'm guessing, but the chart here https://www...   Dec 12 2019, 05:14 PM
Gatornapper   From the Pelican Parts forum post in 2001, the diz...   Dec 12 2019, 09:17 PM
914werke   The ignitor I is prone to failure with KOEO for ex...   Dec 12 2019, 07:23 PM
Gatornapper   Rich - Sorry - I'm relatively new at this 914...   Dec 13 2019, 08:50 AM
Gatornapper   Best price yet - Dansk - says it's for '74...   Dec 12 2019, 08:56 PM
Gatornapper   VERY INTERESTING. A Pelican Parts forum discussio...   Dec 12 2019, 09:04 PM
rbzymek   GN- I copied the dizzy part wrong. The good one i...   Dec 13 2019, 09:37 AM
Gatornapper   Ray - Thanks - I did have the correct number. No...   Dec 13 2019, 10:05 AM
rbzymek   Go with WTB. That's where I found mine for ...   Dec 13 2019, 10:13 AM
Tdskip   Hold on here - so we are putting down for future r...   Dec 13 2019, 10:31 AM
rbzymek   So the 231 181 009 aka 022 905 205AA has a curve d...   Dec 13 2019, 10:52 AM
Gatornapper   I agree - research I have done confirms that.........   Dec 13 2019, 10:58 AM
Gatornapper   What I'd like to know is where does the 022 90...   Dec 13 2019, 11:03 AM
rbzymek   FYI....   Dec 13 2019, 11:47 AM
Gatornapper   AH-HA! It's a VW Part number! The 0 ...   Dec 13 2019, 11:55 AM
Gatornapper   Wondering if at this point we shouldn't move t...   Dec 13 2019, 12:28 PM
rbzymek   GN, That's the Bosch number 231 181 009. The V...   Dec 13 2019, 02:38 PM
Gatornapper   NOW it makes sense! Thank you! On the Pe...   Dec 13 2019, 06:59 PM
rbzymek   Here is a graph of the curve base on the Pelican t...   Dec 13 2019, 02:55 PM
- Lo-Fi Version Time is now: 6th June 2026 - 01:41 PM
