> touring power, build an engine !!!!
orangecrate
post Dec 7 2019, 11:33 AM
So I been workin on the orangecrate off an on for what seems like forever... seems I now have rod issues. Knock knock.... Any way I'm lookin at building a motor, or rebuilding. Inexpensively (IMG:style_emoticons/default/lol-2.gif) I have only 2 real conditions I want to meet. 1- It will run 80 mph all day thru the desert in the summer in Phoenix and sit at stoplights with out cooking itself. 2- It will pull the 6% grades that you hit leaving the valley at 70 in the summer without cooking itself. 75 would be nicer. Guess I"m talking a torque motor. This is a stock 72 with stock gearing. And maybe one size up tires. Did I say it needs to be reliable? Like Phoenix to Portland and back any time of year reliable. And inexpensive.. I'd love to buy a Raby motor but $$$. Oh yea. I will be doing the assembly myself. And I'd like to use as much of the 1.7 as possible if possible. Thanks for the input. Build away. (IMG:style_emoticons/default/beer.gif)
VaccaRabite
post Dec 12 2019, 11:36 AM
En Garde!
1911 can be a great engine making similar power to a 2056, slightly more peaky torque curve, slightly more rev happy.
If your bottom end is in great shape, you will still spend a lot of money on heads. And if you want power from non-stock EFI or carbs you will need a different cam (which means splitting the case).
On any engine you build, your biggest ticket item will be the heads. Buy the best you can afford. Don't go budget here. I'd be very wary of an $1800 1911 (I learned that lesson the hard way) as you can't buy the parts for that price, let alone the cost of building it. So you have to ask - what corners got cut (and if the case was align bored, lots of corners had to get cut to make selling at that price possible - unless the guy is taking a loss on the motor just to get it out of his shop.)
Stock or not, you will have a hard time getting a reliable new engine for under $5K. Sure, its possible, but not likely. Not any more.
Not much sucks more then buying a performance motor for ~$2K, and finding out you probably have to rebuild the whole thing after 15 minutes of run time and a sad compression test. My experience only, YMMV.
Zach
orangecrate   touring power   Dec 7 2019, 11:33 AM
mepstein   Add an oil cooler. Tangerine makes a bolt on kit.   Dec 7 2019, 12:32 PM
Superhawk996   2.0L Stock or maybe 2056 is probably the sweet spo...   Dec 7 2019, 12:55 PM
Mark Henry   First is it knocking? Many newbies mistake a ...   Dec 7 2019, 01:44 PM
orangecrate   First is it knocking? Many newbies mistake a ...   Dec 7 2019, 03:31 PM
ctc911ctc   First is it knocking? Many newbies mistake a ...   Dec 12 2019, 11:42 AM
rhodyguy   Do the 1.7 case spigots and heads limit cyl/piston...   Dec 7 2019, 01:58 PM
Superhawk996   Do the 1.7 case spigots and heads limit cyl/pisto...   Dec 7 2019, 02:56 PM
orangecrate   Do the 1.7 case spigots and heads limit cyl/pist...   Dec 7 2019, 03:51 PM
orangecrate   [quote name='Superhawk996' post='2768...   Dec 7 2019, 03:57 PM
Bleyseng   As Superhawk says - a 2056cc with a external oil c...   Dec 7 2019, 02:33 PM
orangecrate   As Superhawk says - a 2056cc with a external oil ...   Dec 7 2019, 04:06 PM
Mark Henry   As Superhawk says - a 2056cc with a external oil...   Dec 7 2019, 04:16 PM
orangecrate   There is a very good Porsche wrecking yard in PHX....   Dec 7 2019, 04:04 PM
Superhawk996   There is a very good Porsche wrecking yard in PHX...   Dec 7 2019, 04:38 PM
Superhawk996   There is a very good Porsche wrecking yard in PHX...   Dec 7 2019, 04:49 PM
Tdskip   My rebuilt 1.7L 66m crank with 96mm pistons = 191...   Dec 8 2019, 08:32 PM
Superhawk996   showuser=22428]Superhawk996 - just a 2.0L of 205...   Dec 8 2019, 09:25 PM
thelogo   Building a expensive .aircooled .motor that need t...   Dec 8 2019, 02:32 PM
Tdskip   @Superhawk996 - thanks for the response but I wa...   Dec 9 2019, 07:16 AM
Superhawk996   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 9 2019, 06:13 PM
orangecrate   Been doin a little figuring and thinking . Based ...   Dec 9 2019, 08:11 AM
914forme   Have you checked into Original Customs engine prog...   Dec 9 2019, 08:41 AM
mepstein   Have you checked into [url=http://www.originalcus...   Dec 9 2019, 09:32 AM
rhodyguy   Doing it right, chances are you will need machine ...   Dec 9 2019, 09:56 AM
Tdskip   @superhawk996 - thanks for following up and good...   Dec 10 2019, 09:46 AM
VaccaRabite   When I did my motor (2056) it started as a 1.7L ca...   Dec 10 2019, 10:32 AM
Tdskip   Super helpful post Zach   Dec 10 2019, 10:36 AM
Bleyseng   Sorry, there is no waay I’d a Subie in 914. Just...   Dec 10 2019, 04:13 PM
orangecrate   What are y'all's thoughts on a 1911 ?? I...   Dec 10 2019, 08:48 PM
Tdskip   What are y'all's thoughts on a 1911 ?? ...   Dec 10 2019, 09:14 PM
michael7810   What are y'all's thoughts on a 1911 ?? ...   Dec 12 2019, 09:20 AM
Bleyseng   Its going cost about the same to build a stock 1.7...   Dec 11 2019, 12:57 PM
VaccaRabite   1911 can be a great engine making similar power to...   Dec 12 2019, 11:36 AM
orangecrate   1911 can be a great engine making similar power t...   Dec 28 2019, 06:45 PM
Tdskip   Good luck and please keep us posted   Dec 28 2019, 08:16 PM
MM1   Did you ever get that stock 1.7 running?   Nov 2 2020, 06:07 PM
rbzymek   So when my 1975 1.8L overheated and failed with lo...   Nov 2 2020, 07:45 PM
- Lo-Fi Version Time is now: 18th October 2026 - 04:46 PM
