Airflow/Horsepower limit for stock 2.0L intake system? |
greggearhead |
Dec 12 2019, 11:32 AM
Newbie Group: Members Posts: 35 Joined: 19-March 11 From: Colorado Springs, CO Member No.: 12,836 Region Association: None |
OK, I did search, and couldn't really find anything.
My basic question - when does the 914 2.0L intake become a restriction to power? I have a built VW 412 - 2056 cc Type 4 * 9550 RAT cam * LE-180 heads (914 2L combustion chamber, 42mm intake, 36mm exhaust) * Mallory Unilite vacuum advance distributor, Mallory Promaster coil, Mallory Hyfire CDI * Stock 412 heater boxes & Thunderbird exhaust * 2L Bus plenum and throttle body * 2L 914 runners * Ford "Design II" F1TE-D9A (Bosch 0280150947) 24# injectors (modified) * SDS programmable EFI * Oil bath air cleaner housing modified to use large circular filter element I have a pair of IDF manifolds, and some VFR throttle bodies. Roughly equivalent to Weber 40IDFs (maybe a bit better in terms of flow). Engine made 115hp at the wheels. I'm just wondering if the (improved) stock intake is a cork or not? (IMG:http://www.914world.com/bbs2/uploads_offsite/i61.photobucket.com-12836-1576171976.1.jpg) |
Mikey914 |
Dec 14 2019, 04:45 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
From my experience the stock set up 2.0 will easily handle the airflow you are talking about, even with larger valves.
If you build a higher reving motor you would have some issues top end, but with you can selection the 2056 would be just fine. I think since you have the IBTs every one thinks you are going that direction. |
Lo-Fi Version | Time is now: 7th June 2024 - 10:49 AM |
