Distributor Shaft Alignment, Small sector to Left/driver side? or Right/pass. side? |
Gatornapper |
Dec 14 2019, 08:40 PM
Senior Member Group: Members Posts: 1,235 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Haynes Manual, page 65, Fig. 3.6, referenced from page 64, Pp. 6, #7: "install it so that.........an angle of 12 deg. .......with the small sector facing towards the outside of the car."
On my 914, the small sector is on the left. If I'm reading this correctly, this is ambiguous and does not clarify it "the outside of the car" is the Driver's side or Passenger side....... Can someone clarify this please? Or am I missing something (not the first time...)..... TIA, GN |
Garland |
Dec 15 2019, 12:18 AM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Gatornapper |
Dec 15 2019, 07:15 AM
Thanks Garland.....
Perhaps I'm not on TDC, not on compression stroke - but one rev out... Will check later today...... GN |
Superhawk996 |
Dec 15 2019, 10:15 AM
914 Guru Group: Members Posts: 5,884 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Thanks Garland..... Perhaps I'm not on TDC, not on compression stroke - but one rev out... Will check later today...... GN It is not possible for a backfire to destroy the gear interface between the crank and the distributor. Easiest way is to pull valve cover. Look at the valves. When both are closed and you're at TDC you know your on the compression stroke. There is no possibility of being 180 out if both valves are closed. Setting aside all other nonsene of manual, if you set to TDC #1 based on piston and valve position, and then align the distributor into the notches such that the rotor is pointing at Cylinder #1 spark plug terminal, it will be correct. |
Lo-Fi Version | Time is now: 4th June 2024 - 07:07 AM |
