| jat914 |
Dec 15 2019, 02:20 PM
Newbie ![]() Group: Members Posts: 27 Joined: 3-December 13 From: Arizona Member No.: 16,718 Region Association: None |
I had to replace the fan belt on my race built 2065 motor. The replacement belt is made in China and at high rpms it kept flying off! Has anyone had this problem and is there a solution?
rgalla9146 It is less likely a counry of origin issue and mor... Dec 15 2019, 07:13 PM
porschetub
It is less likely a counry of origin issue and mo... Dec 17 2019, 02:19 PM
cuddy_k
It is less likely a counry of origin issue and mo... Dec 18 2019, 10:18 PM
brant Gates makes a belt with ribs on the exterior
Itâ€... Dec 17 2019, 03:03 PM
sixnotfour the new continental/ ContiTech are made in .......... Dec 17 2019, 03:38 PM
914Sixer Make sure you are using the correct size belt. 9.... Dec 17 2019, 04:06 PM
porschetub
Make sure you are using the correct size belt. 9... Dec 17 2019, 08:18 PM
jcd914 This was a fairly common issue for track use or au... Dec 17 2019, 04:27 PM
jat914
This was a fairly common issue for track use or a... Dec 19 2019, 02:50 PM
porschetub
This was a fairly common issue for track use or ... Dec 20 2019, 02:22 PM
914Sixer Belt Dec 18 2019, 06:59 AM
rhodyguy The mount bracket for the alt. My car made a chirp... Dec 19 2019, 11:12 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2026 - 06:49 PM |
