Fog Light Switch You Have Never Seen, Does Not Exist In Catalog OR PET 914 613 451 10 |
914Sixer |
Dec 15 2019, 01:34 PM
914 Guru Group: Members Posts: 8,901 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Here is a two stage fog light switch that has a 914 part number and is listed for 911 fog lights. Switch is off to the left side and is separate from the 911 switches. I am guessing when you pull it out to the second stage it would be wired to the rear fog light.
Attached image(s) |
sixnotfour |
Dec 15 2019, 02:23 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
pelican;
QUOTE I have a the same 4 terminal switch with front and rear fog lights. Brown= ground Grey = power 12v + Blue = to front fog light relay White/green = to rear fog light The rear fog light is not fused and its really important you use the correct lead in the rear fog light to power the blub. I had mine mixed up and it caused a really big problem (melted headlight switch loom) Attached image(s) |
Lo-Fi Version | Time is now: 6th June 2024 - 07:54 AM |
