> Distributor Shaft Alignment, Small sector to Left/driver side? or Right/pass. side?
Gatornapper
post Dec 14 2019, 08:40 PM
Haynes Manual, page 65, Fig. 3.6, referenced from page 64, Pp. 6, #7: "install it so that.........an angle of 12 deg. .......with the small sector facing towards the outside of the car."
On my 914, the small sector is on the left.
If I'm reading this correctly, this is ambiguous and does not clarify it "the outside of the car" is the Driver's side or Passenger side.......
Can someone clarify this please? Or am I missing something (not the first time...).....
TIA,
GN
rjames
post Dec 15 2019, 02:25 PM
I'm made of metal
Maybe I’m missing something... Is the rotor is pointing at #1 when it is tdc? If yes, tighten the dizzy, but not too tight. From there, check that the points gap is correct.
Set the dwell 44-45 degrees and you are ready to start the car and then set dynamic timing.
Points and dwell must be set right for the car to start.
There is also a mark on the flywheel that you can see from engine bay that indicates tdc for #1 if you pry back the engine tin/seal a bit.
Gatornapper
post Dec 15 2019, 07:34 PM
Thanks!
I have previously marked the following on both the front side of the impeller where you can see it and the flywheel:
TDC (black), 7.5 deg. BTDC (white), and 27 deg. BTDC (red).
GN
QUOTE(rjames @ Dec 15 2019, 03:25 PM) *
Gatornapper   Distributor Shaft Alignment   Dec 14 2019, 08:40 PM
Garland   Check out this post. 914 post link Replying to ...   Dec 15 2019, 12:18 AM
Gatornapper   Thank you. So, how did mine get about 180 degrees...   Dec 15 2019, 07:02 AM
Gatornapper   Thanks Garland..... Perhaps I'm not on TDC, n...   Dec 15 2019, 07:15 AM
Superhawk996   Thanks Garland..... Perhaps I'm not on TDC, ...   Dec 15 2019, 10:15 AM
Gatornapper   SuperHawk -et al - "Easiest way is to pull ...   Dec 18 2019, 01:05 PM
Gatornapper   Ok, #1 is at TDC, and this is the position of the ...   Dec 15 2019, 12:37 PM
Superhawk996   This is also with the points set by static timi...   Dec 15 2019, 01:06 PM
Superhawk996   This is also with the points set by static tim...   Dec 15 2019, 01:41 PM
Gatornapper   SH - MY BAD! My brain was not plugged in yes...   Dec 15 2019, 07:27 PM
sixnotfour   non bosch rotor make sure it actually is push into...   Dec 15 2019, 12:43 PM
Gatornapper   non bosch rotor make sure it actually is push int...   Dec 15 2019, 12:47 PM
Garland   Are you sure you’re getting the distributor hous...   Dec 15 2019, 01:04 PM
rjames   Maybe I’m missing something... Is the rotor is p...   Dec 15 2019, 02:25 PM
Gatornapper   Thanks! I have previously marked the followin...   Dec 15 2019, 07:34 PM
cary   You got this. When you are CERTAIN you are at TDC ...   Dec 16 2019, 12:47 AM
914_teener   You got this. When you are CERTAIN you are at TDC...   Dec 16 2019, 10:37 AM
Gatornapper   Like some help checking my reasoning here: Dizzy ...   Dec 16 2019, 08:58 PM
injunmort   in your picture, you are not timed on #1. that is ...   Dec 17 2019, 06:09 PM
Gatornapper   That was old pic, I realized it was incorrect. It...   Dec 18 2019, 10:02 AM
Gatornapper   Mort - In my rotor pic, that is exactly where #1 ...   Dec 26 2019, 07:59 AM
rhodyguy   If the engine is at TDC on #1, and the dist drive ...   Dec 17 2019, 06:51 PM
Gatornapper   My bad, as I said. I had put dizzy in when engine...   Dec 18 2019, 10:04 AM
sixnotfour   boxer engine so 1 of 2 cyl.s can be at TDC... what...   Dec 18 2019, 01:18 PM
Gatornapper   Thank you. Totally agree - trying to get to groun...   Dec 18 2019, 02:44 PM
Superhawk996   Thank you. Totally agree - trying to get to grou...   Dec 19 2019, 11:04 AM
Gatornapper   Question: Is this not the correct position for th...   Dec 18 2019, 02:47 PM
theer   Question: Is this not the correct position for t...   Dec 18 2019, 04:40 PM
sixnotfour   rotate your distributor to line up with rotor,,, y...   Dec 18 2019, 04:30 PM
Gatornapper   Did that some time ago. Engine is firing #1 when ...   Dec 18 2019, 07:47 PM
rhodyguy   is that a picture of the distributor in your car?   Dec 18 2019, 08:18 PM
theer   Sorry in advance if I’m missing something or if ...   Dec 18 2019, 08:25 PM
rhodyguy   The one pictured that has the circles is for a Dje...   Dec 18 2019, 09:50 PM
Gatornapper   Post 6 is mine - BEFORE I got the body rotated pro...   Dec 19 2019, 08:58 AM
theer   No one has yet answered my question of the positi...   Dec 19 2019, 02:25 PM
Gatornapper   The answer is NO. The rotor in the 009 points ...   Mar 3 2020, 06:24 AM
injunmort   this last pic of rotor has it pointed at #2. that ...   Dec 19 2019, 09:13 AM
Gatornapper   Dear friend Mort - I totally understand what you ...   Dec 19 2019, 07:06 PM
injunmort   I don't know what you guys mean by different c...   Dec 19 2019, 05:13 PM
injunmort   if I am understanding you correctly, you say rotor...   Dec 19 2019, 07:26 PM
Gatornapper   Mort - Thank you. "if I am understanding ...   Dec 19 2019, 07:39 PM
Gatornapper   PS: I have verified with my timing light that #1 ...   Dec 19 2019, 07:26 PM
injunmort   cant tell what position that is without looking at...   Dec 19 2019, 07:59 PM
Gatornapper   In the Haynes manual on p. 65, Figure 3.6, there i...   Dec 19 2019, 08:09 PM
injunmort   I think you are missing somethings. that drive and...   Dec 19 2019, 08:52 PM
Gatornapper   Again, bro - I totally get that. The dizzy drives...   Dec 19 2019, 09:23 PM
injunmort   many years ago I was restoring an early 1930's...   Dec 19 2019, 09:10 PM
injunmort   have no idea with out seeing orientation of rotor....   Dec 19 2019, 09:41 PM
Gatornapper   Mort - See my post 6 and the pic in it. In this ...   Dec 20 2019, 09:26 AM
Gatornapper   I understand totally that the timing is set wherev...   Dec 25 2019, 08:26 AM
porschetub   I understand totally that the timing is set where...   Dec 25 2019, 09:17 PM
sixnotfour   I understand totally that the timing is set wher...   Dec 25 2019, 10:29 PM
Gatornapper   THANK YOU AS WELL! Totally makes sense! ...   Dec 26 2019, 07:27 AM
- Lo-Fi Version Time is now: 10th December 2025 - 07:53 AM
