> Is there a "how to.." for crank measurement, and bearing verification?
malcolm2
post Dec 16 2019, 11:07 PM
I am gonna make a 2 liter from my 1.8. So I have a refreshed 71mm crank that I have been told has been ground to -0.010.
I measured as best as I can with a digital mic and got about 59.66 on the mains and 49.65 on the rod journals.
Where can I find the STD specs and ranges ? were they 60 and 50, respectively?
Since I know nothing about this crank, how can I verify the 71 mm measurement?
malcolm2
post Dec 17 2019, 06:30 PM
OK it passed the hammer test. very high pitched tuning fork ring. The 1.8 has an even higher ring and lasts longer. If that means anything... (IMG:style_emoticons/default/piratenanner.gif)
I have a set of micrometers coming from a workmate tomorrow. If he forgets, there is always Harbor Freight for $40.
With my method of measuring last night, I got a consistent 49.65 on all 4 rod journals.
Book says std is 49.97 - 49.98. That puts them at 0.33mm under which is -0.01299. Seams excessive.
More accurate measurements tomorrow, I guess.
So @Superhawk996 , did this crank ever run in it's current state? Or you took it out and polished it, but never installed?
malcolm2   Is there a "how to.." for crank measurement   Dec 16 2019, 11:07 PM
Superhawk996   @malcolm2 My understanding is that this crank th...   Dec 17 2019, 06:17 AM
malcolm2   YES, It seems that @jtprettyman has passed it on...   Dec 17 2019, 08:46 AM
malcolm2   How about the 71mm measurement? Not that it matte...   Dec 17 2019, 08:51 AM
Superhawk996   How about the 71mm measurement? Not that it matt...   Dec 17 2019, 02:13 PM
Mark Henry   How about the 71mm measurement? Not that it mat...   Dec 17 2019, 11:26 PM
Mark Henry   I only use STD cranks or standard (under) cranks I...   Dec 17 2019, 09:24 AM
malcolm2   I only use STD cranks or standard (under) cranks ...   Dec 17 2019, 09:48 AM
Superhawk996   Also for what it’s worth, I provided this crank ...   Dec 17 2019, 02:34 PM
malcolm2   OK it passed the hammer test. very high pitched t...   Dec 17 2019, 06:30 PM
Superhawk996   With my method of measuring last night, I got a ...   Dec 18 2019, 08:53 AM
malcolm2   With my method of measuring last night, I got a...   Dec 18 2019, 10:03 AM
Superhawk996   Thanks for your input. I certainly hope you don...   Dec 18 2019, 02:58 PM
malcolm2   OK, maybe not the super duper accurate tools but I...   Dec 21 2019, 02:47 PM
Superhawk996   OK, maybe not the super duper accurate tools but ...   Dec 21 2019, 07:36 PM
Mark Henry   Sounds like a lot. If you're right about #4 yo...   Dec 21 2019, 03:24 PM
malcolm2   Your rods should at least have the big ends done....   Jan 20 2020, 08:59 AM
Superhawk996   So question 1: how do you "DO" the rod...   Jan 20 2020, 12:41 PM
malcolm2   Both micrometers were checked prior to the last me...   Dec 23 2019, 10:08 AM
Superhawk996   Both micrometers were checked prior to the last m...   Dec 23 2019, 10:34 AM
malcolm2   3) For hobbyists like myself, Plastigage can ser...   Dec 23 2019, 10:44 AM
malcolm2   UPDATE>>>>> Todd is the Director o...   Jan 14 2020, 08:38 PM
Superhawk996   Rod measurements align a whole lot closer to what ...   Jan 15 2020, 06:00 AM
jtprettyman   @Superhawk996 Yes, these were done with a very n...   Jan 15 2020, 08:58 AM
malcolm2   Rod Balancing, End-to-end. I also wondered how in...   Jan 21 2020, 08:30 AM
- Lo-Fi Version Time is now: 15th September 2026 - 10:25 AM
