Running GREAT and then rough…..hhhhmmmm, engine runs rough at one place in the power band |
ctc911ctc |
Dec 13 2019, 10:16 AM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
-Update -
I removed the TPS, calibrated it as per instructions on the Bird. Here are some pictures. I would like to be able to "RING" this out, not sure what I would be looking for. Though we know that one course is to install a new board and then calibrate. There is little else I could find to assure operation. Any experience with asserting these things are good. Some pics Any ideas would be great! -End of Update- I am a bit befuddled as to which way to go so I decided that the 914W team would like to hear about this puzzle. Background '74 2.0, garaged from '84 until 2018, 22K miles Running since June. Repaired or replaced: Entire Fuel System - tank, lines, injectors, pump, pressure reg Adjusted the valves Removed and rang-out the engine harness, Rebuilt the MPS Rebuilt the Plenum and tested it for leaks - none observed New gaskets at the plenum and manifold at the engine Rebuilt Throttle Body, very minor leaks around the actuator (throttle), New circuit card New Plugs, points, cap and inspected the distributor for all of the regular ailments - super tight. Engine idles great, pulls like a monster - sounds like a German symphony HOWEVER Last night I drove it back from the paint shop on 93 heading south from NH to Boston (lots of beeps from newer Porsches (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/wink.gif) ) and found that the car started to buck and the engine runs rough when just a small amount of throttle is applied. More Detail If you are doing 55 and want to maintain that speed, it is necessary to apply a small amount of gas to sustain the speed. This is when the cars starts to exhibit this "miss/run-rough" puzzle. If more throttle is applied the bucking stops, the engine is smooth and all is well. Conversely, while de-accelerating there is no bucking. This problem is NOT velocity-dependent, sustaining at 30/40/50/60 will exhibit the same reaction. WHERE WOULD YOU START TO LOOK IF YOU HAD THIS CHALLENGE? |
ChrisFoley |
Dec 16 2019, 09:57 AM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I've experienced similar symptoms when the MPS was adjusted a bit too lean. At some areas in the fuel map it gets lean enough to cause slight misfire.
ChrisFoley |
Dec 18 2019, 06:15 AM
I've experienced similar symptoms when the MPS was adjusted a bit too lean. At some areas in the fuel map it gets lean enough to cause slight misfire. I wrote this precisely because of the bucking you are experiencing. It is my contention that all you need to do is enrich the MPS setting a small amount to eliminate the misfire which results in bucking during light throttle cruise. I bet you would also notice an increase in power at WOT. Easy peasy. If your MPS is not set up for in situ adjustability you can still open it up to make a change, and reassemble it in half an hour. |
ctc911ctc |
Dec 18 2019, 09:39 AM
Chris!
The muffler you sold me works and sounds great! Great advice, I rebuilt the MPS as per your instructions and developed a method of 'relative relationships' to put it back together. Using the H method I was within a few percents of calibration. I am going to check all of the basics and then PRIOR to going deeper will make this adjustment. Question - if the ECU adjustment is turned to the RIGHT a click or two would this accomplish the same thing? Thank You, Tangerine Chris! I've experienced similar symptoms when the MPS was adjusted a bit too lean. At some areas in the fuel map it gets lean enough to cause slight misfire. I wrote this precisely because of the bucking you are experiencing. It is my contention that all you need to do is enrich the MPS setting a small amount to eliminate the misfire which results in bucking during light throttle cruise. I bet you would also notice an increase in power at WOT. Easy peasy. If your MPS is not set up for in situ adjustability you can still open it up to make a change, and reassemble it in half an hour. |
ChrisFoley |
Dec 18 2019, 10:38 AM
Question - if the ECU adjustment is turned to the RIGHT a click or two would this accomplish the same thing? Brant is correct. And because the injection pulse is so short at idle the range of the ECU knob is quite narrow. In my experience when the MPS setting is near optimal the effect of the ECU knob will be more noticeable, and idle will be clearly better away from either extreme position. I suggest that you back out the center screw in the MPS diaphragm by a turn and a half. Record the inductance values for comparison then install it in the car for a test drive. |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:37 AM |
