Distributor Shaft Alignment, Small sector to Left/driver side? or Right/pass. side? |
Gatornapper |
Dec 14 2019, 08:40 PM
Senior Member Group: Members Posts: 1,235 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Haynes Manual, page 65, Fig. 3.6, referenced from page 64, Pp. 6, #7: "install it so that.........an angle of 12 deg. .......with the small sector facing towards the outside of the car."
On my 914, the small sector is on the left. If I'm reading this correctly, this is ambiguous and does not clarify it "the outside of the car" is the Driver's side or Passenger side....... Can someone clarify this please? Or am I missing something (not the first time...)..... TIA, GN |
Gatornapper |
Dec 18 2019, 02:47 PM
Question:
Is this not the correct position for the rotor on every 914 for TDC on #1? (IMG:http://www.914world.com/bbs2/uploads/post-13474-1463348898_thumb.jpg) GN |
theer |
Dec 18 2019, 04:40 PM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Question: Is this not the correct position for the rotor on every 914 for TDC on #1? GN With a stock dizzy, I believe you are correct. I had a helluva time trying to figure out 1-3-4-2 wire orientation on an 009 or 050 cap, where the rotor didn't point in the same direction as stock.. the mark on the case was at a different spot on the dizzy case, so TDC was clear, but the wires needed to be properly oriented on the cap. |
Lo-Fi Version | Time is now: 4th June 2024 - 11:34 AM |
