Distributor Shaft Alignment, Small sector to Left/driver side? or Right/pass. side? |
Gatornapper |
Dec 14 2019, 08:40 PM
Senior Member Group: Members Posts: 1,235 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Haynes Manual, page 65, Fig. 3.6, referenced from page 64, Pp. 6, #7: "install it so that.........an angle of 12 deg. .......with the small sector facing towards the outside of the car."
On my 914, the small sector is on the left. If I'm reading this correctly, this is ambiguous and does not clarify it "the outside of the car" is the Driver's side or Passenger side....... Can someone clarify this please? Or am I missing something (not the first time...)..... TIA, GN |
rhodyguy |
Dec 18 2019, 09:50 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,089 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
The one pictured that has the circles is for a Djet system. A Ljet dist has no trigger point wiring provision. You want a part number ending in AB. I'm confused.
Gatornapper |
Dec 19 2019, 08:58 AM
Post 6 is mine - BEFORE I got the body rotated properly - BUT the position of the rotor did not change, as that is determined by the position of distributor driveshaft.
The pic on post 25 I got off this forum as I wanted a pic not of the distributor but of the rotor position at TDC. Yes, the distributor is different, but I am not concerned with that. My dizzy is a 178 009 that apparently the Porsche dealer put int when they installed the Webers and many say is not good for this engine. I am soon replacing it with a nice 1.8 dizzy I just got off eBay that has vacuum advance. It is an 0 231 181 009/022 905 205 AA. No one has yet answered my question of the position of the rotor at TDC - it must be the same on all 914 - 4's as I see it, and I believe it, when facing the front of the car from the rear, should point to about 11 o'clock, and that's where the cap tower to Plug #1 must also be at TDC. That's where it is in the pic I posted on post #25 and the reason I posted that pic. I believe that is where my #1 cap tower was located before I started having engine problems. But now, at TDC, the rotor is pointed to about 1 o'clock. HOW DID IT CHANGE? Could the gear on the bottom of the dizzy shaft slip? I cannot see how it could. And is not 11 o'clock (from the rear) the position of all rotors and the #1 cap tower on all 914's? TIA, GN The one pictured that has the circles is for a Djet system. A Ljet dist has no trigger point wiring provision. You want a part number ending in AB. I'm confused. |
theer |
Dec 19 2019, 02:25 PM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
No one has yet answered my question of the position of the rotor at TDC - it must be the same on all 914 - 4's as I see it, and I believe it, when facing the front of the car from the rear, should point to about 11 o'clock, and that's where the cap tower to Plug #1 must also be at TDC. That's where it is in the pic I posted on post #25 and the reason I posted that pic. I believe that is where my #1 cap tower was located before I started having engine problems. But now, at TDC, the rotor is pointed to about 1 o'clock. HOW DID IT CHANGE? Could the gear on the bottom of the dizzy shaft slip? I cannot see how it could. And is not 11 o'clock (from the rear) the position of all rotors and the #1 cap tower on all 914's? The answer is NO. The rotor in the 009 points to different "clock" position than the rotor in a stock dist. It's still the #1 cylinder, though, so all that matters is that you have the wires matched up to the rotor's position underneath. Hope that helps. |
Lo-Fi Version | Time is now: 4th June 2024 - 08:17 PM |
