| malcolm2 |
Dec 16 2019, 11:07 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
I am gonna make a 2 liter from my 1.8. So I have a refreshed 71mm crank that I have been told has been ground to -0.010.
I measured as best as I can with a digital mic and got about 59.66 on the mains and 49.65 on the rod journals. Where can I find the STD specs and ranges ? were they 60 and 50, respectively? Since I know nothing about this crank, how can I verify the 71 mm measurement? |
| malcolm2 |
Dec 21 2019, 02:47 PM
OK, maybe not the super duper accurate tools but I feel better after these measurements. They are the Mitutoyo brand... so this is what I got.
#1 main is 0.0072 under #2 main is 0.0076 under #3 main is 0.0072 under #4 main is 0.00925 under Rod journals are all 0.0084 under So I had already bought some 0.010 under (0.25mm) main bearings, so I am gonna get some plasti-gauge and see where the clearance ends up. What are the thoughts of the group?? |
malcolm2 Is there a "how to.." for crank measurement Dec 16 2019, 11:07 PM
Superhawk996 @malcolm2
My understanding is that this crank th... Dec 17 2019, 06:17 AM
malcolm2 YES, It seems that @jtprettyman has passed it on... Dec 17 2019, 08:46 AM
malcolm2 How about the 71mm measurement? Not that it matte... Dec 17 2019, 08:51 AM
Superhawk996
How about the 71mm measurement? Not that it matt... Dec 17 2019, 02:13 PM
Mark Henry
How about the 71mm measurement? Not that it mat... Dec 17 2019, 11:26 PM
Mark Henry I only use STD cranks or standard (under) cranks I... Dec 17 2019, 09:24 AM
malcolm2
I only use STD cranks or standard (under) cranks ... Dec 17 2019, 09:48 AM
Superhawk996 Also for what it’s worth, I provided this crank ... Dec 17 2019, 02:34 PM
malcolm2 OK it passed the hammer test. very high pitched t... Dec 17 2019, 06:30 PM
Superhawk996
With my method of measuring last night, I got a ... Dec 18 2019, 08:53 AM
malcolm2
With my method of measuring last night, I got a... Dec 18 2019, 10:03 AM
Superhawk996
Thanks for your input. I certainly hope you don... Dec 18 2019, 02:58 PM
Superhawk996
OK, maybe not the super duper accurate tools but ... Dec 21 2019, 07:36 PM
Mark Henry Sounds like a lot. If you're right about #4 yo... Dec 21 2019, 03:24 PM
malcolm2
Your rods should at least have the big ends done.... Jan 20 2020, 08:59 AM
Superhawk996
So question 1: how do you "DO" the rod... Jan 20 2020, 12:41 PM
malcolm2 Both micrometers were checked prior to the last me... Dec 23 2019, 10:08 AM
Superhawk996
Both micrometers were checked prior to the last m... Dec 23 2019, 10:34 AM
malcolm2
3) For hobbyists like myself, Plastigage can ser... Dec 23 2019, 10:44 AM
malcolm2 UPDATE>>>>>
Todd is the Director o... Jan 14 2020, 08:38 PM
Superhawk996 Rod measurements align a whole lot closer to what ... Jan 15 2020, 06:00 AM
jtprettyman @Superhawk996
Yes, these were done with a very n... Jan 15 2020, 08:58 AM
malcolm2 Rod Balancing, End-to-end. I also wondered how in... Jan 21 2020, 08:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th September 2026 - 10:25 AM |
