3.0 /6 in storage the case is filing with oil, and starting to leak on the floor. |
Mark Henry |
Dec 26 2019, 12:51 PM
So my '74 /6 conversion with the DWD sump tank is slowly leaking down into the engine sump. I have a leaking #6 rocker shaft that I'll have to R&R so I know my engine is full to at least to the exhaust rockers. I know it doesn't drain enough to do this if I drive at least weekly. I have a buddy who's well worn engine has hydrolocked a few times due to this.
I had to start and move the car, quite the smoke show. Only automatic cure I've seen so far is a $300 valve from Rothsport. Or I could just install a ball valve and red tag my dash for just over $20. I know it's a common 911 issue, do you other /6 owners have this issue and what do you do about it? |
76-914 |
Dec 26 2019, 08:13 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
https://www.amazon.com/Everflow-Supplies-21...C202&sr=8-5
Horizontal installation only. Approved for water, oil and gas to 150psi. (IMG:style_emoticons/default/beerchug.gif) |
jd74914 |
Dec 26 2019, 09:49 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
https://www.amazon.com/Everflow-Supplies-21...C202&sr=8-5 Horizontal installation only. Approved for water, oil and gas to 150psi. (IMG:style_emoticons/default/beerchug.gif) Not really so good when you add acceleration (either lateral or longitudinal depending on what direction you orient it). That’s why it says horizontal installations only because it can’t handle gravity. Swing checks are never really a tight shutoff either. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:27 PM |
