3.0 /6 in storage the case is filing with oil, and starting to leak on the floor. |
Mark Henry |
Dec 26 2019, 12:51 PM
So my '74 /6 conversion with the DWD sump tank is slowly leaking down into the engine sump. I have a leaking #6 rocker shaft that I'll have to R&R so I know my engine is full to at least to the exhaust rockers. I know it doesn't drain enough to do this if I drive at least weekly. I have a buddy who's well worn engine has hydrolocked a few times due to this.
I had to start and move the car, quite the smoke show. Only automatic cure I've seen so far is a $300 valve from Rothsport. Or I could just install a ball valve and red tag my dash for just over $20. I know it's a common 911 issue, do you other /6 owners have this issue and what do you do about it? |
roblav1 |
Dec 27 2019, 07:57 AM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Is yours leaking by through the pressure or scavenge side?
If scavenge, how about something like this?: http://www.improvedracing.com/oil-accumula...alve-p-555.html Flapper valve. Those rockers are a pain... just finished mine last night. Am trying those RSR seals this time. |
Lo-Fi Version | Time is now: 3rd June 2024 - 01:06 AM |
