> Air Compressor Size Question, How big is big enough?
BeatNavy
post Dec 26 2019, 02:18 PM
This may have been covered before, but I did not find it answered explicitly:
What size air compressor is good enough for doing a decent quality paint job on our cars and otherwise work with air tools? I don't have one now, but I am thinking of making the plunge and trying to paint my car at some point. I don't think I would really do anything bigger than a 914.
Here's a more specific question: is a 60 gallon, 3HP, 11.5 CFM at 40 psi; 10.2 CFM at 90 psi good for this? There's one on CL not far from me that could be a decent deal and serve as my post-Christmas gift to myself.
bbrock
post Dec 27 2019, 09:42 AM
Great advice on size. I will add that I would avoid an "oil-free" air compressor. When I started my build, I bought a barely used 60 gallon, 6 HP Devilbiss Pro Air II with killer cfm specs. I didn't know anything about oil-free compressors. Right off the bat, the thing seemed to have slow recovery times so I rebuilt the pistons. That didn't change much. Nevertheless, that unit got me through all the cutting, grinding, spraying primer, and even sandblasting the entire car, but I spent a LOT of time waiting for the compressor to catch up. Despite trying to be careful to keep it to a 50% duty cycle, recovering times got worse and a second piston rebuild was completed (About $50 per cylinder for parts). Finally, the compressor literally blew up, sending a shattered piston top into the head. Huge waste of money.
I now run a 60 gal. 5HP 2-stage compressor and and am MUCH happier with it. As others have said, it is more than enough for lower consumption tools and paint sprayers. It is adequate for blasting, but requires waiting for it to catch up to keep the duty cycle reasonable.
I think for most DIY occasional use guys, the 60 gal. 5HP 2-stage is about the sweet spot. You can do a lot with a smaller compressor, but you can also nurse this size through occasional more demanding tasks that smaller units couldn't handle. For example, when I have a lot of cabinet blasting to do, I try to set up one or two other projects that don't require air to switch off to while the compressor is catching up and getting a rest.
BeatNavy   Air Compressor Size Question   Dec 26 2019, 02:18 PM
TJB/914   This may have been covered before, but I did not ...   Dec 26 2019, 02:45 PM
BeatNavy   Hi Tom, Yup, definitely a 220/240 connection. Fo...   Dec 26 2019, 02:54 PM
tygaboy   I did a ton of research and (budget and space avai...   Dec 26 2019, 03:09 PM
Chris914n6   I have an older Craftsman 30gal 110v roll around t...   Dec 26 2019, 03:18 PM
76-914   I have an older Craftsman 30gal 110v roll around ...   Dec 26 2019, 08:06 PM
jd74914   Here's a more specific question: is a 60 gal...   Dec 26 2019, 03:31 PM
Superhawk996   It's like buying a boat. Whatever you buy, so...   Dec 26 2019, 03:52 PM
914Sixer   More hp is better. 3 is good 5 is better. 60 gal ...   Dec 26 2019, 04:24 PM
Superhawk996   40 HP VW is better :blink: v6qtHxp_ZGg I'v...   Dec 26 2019, 04:33 PM
BeatNavy   40 HP VW is better :blink: v6qtHxp_ZGg I...   Dec 26 2019, 05:00 PM
jcd914   [quote name='Superhawk996' post='2772507' date='D...   Dec 26 2019, 07:36 PM
Mark Henry   Doing heavy work, blasting, big paint jobs, entry ...   Dec 26 2019, 05:15 PM
mepstein   Doing heavy work, blasting, big paint jobs, entry...   Dec 26 2019, 05:41 PM
IronHillRestorations   The issue for painting is clean, dry air so be sur...   Dec 26 2019, 06:11 PM
Costa05   I am running a 3.7 hp Dewalt 60 gal from Tractor S...   Dec 26 2019, 06:40 PM
jmitro   Here's a more specific question: is a 60 gall...   Dec 26 2019, 08:20 PM
914forme   I used to paint with compressors, and since went t...   Dec 26 2019, 09:17 PM
jd74914   :agree: With Mark, if you can find a screw compr...   Dec 27 2019, 01:24 PM
BeatNavy   That Eastwood scroll compressor looks pretty sweet...   Dec 27 2019, 05:40 AM
mb911   What about dbs? I may need a quiet one ..   Dec 27 2019, 06:45 AM
roblav1   My old 110V portable Sears unit I bought in 1988 c...   Dec 27 2019, 07:45 AM
enikolayev   https://www.youtube.com/watch?v=cfjSm_ieRkE Air c...   Dec 27 2019, 09:18 AM
bbrock   Great advice on size. I will add that I would avo...   Dec 27 2019, 09:42 AM
tvdinnerbythepool   I think what you mention in the original post will...   Dec 27 2019, 10:26 AM
rhodyguy   Continuous duty cycle.   Dec 27 2019, 10:55 AM
IronHillRestorations   The Eastwood scroll looks interesting to me, but t...   Dec 27 2019, 06:05 PM
mb911   Perry, Same here. Looking at a California compre...   Dec 27 2019, 06:44 PM
maf914   I am curious what sort of filter/separator is need...   Dec 28 2019, 07:54 AM
Mark Henry   I am curious what sort of filter/separator is nee...   Dec 28 2019, 08:48 AM
mb911   From a sound stand point I am going to look at sou...   Dec 28 2019, 08:16 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:21 PM
