123Ignition setting Map Curve (Bluetooth) |
9144me2enjoy |
Dec 28 2019, 05:55 PM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
I’ve followed the past postings on the 123Ignition and was able to get mine (Bluetooth Version) installed in my 914 with a Raby 2270 engine. My question is I’ve never messed with the Map Curve Settings, I’m still getting some misfires when the car is cold until it warms up. I’m not sure if I need to adjust the Map settings to address this problem or help on reaching peak performance? Thanks for any suggestions. I’ve attached a couple of current pics of the settings for the Centrifugal Curve and Map Curve. Thanks
Attached thumbnail(s) |
yeahmag |
Dec 29 2019, 09:13 AM
Advanced Member Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
When you say misfires when cold, do you mean a “sneeze” out of the carbs when cold. If so, it’s fairly normal when cold. Do you have a wide band O2 sensor installed?
9144me2enjoy |
Dec 29 2019, 12:01 PM
When you say misfires when cold, do you mean a “sneeze” out of the carbs when cold. If so, it’s fairly normal when cold. Do you have a wide band O2 sensor installed? No 02 sensors installed on this Type 4 engine. As far as the misfire its more of a cough. I’m not sure that you even need a Map Curve setting when your using carbs instead of Fuel Injection. |
Lo-Fi Version | Time is now: 16th June 2024 - 04:46 AM |
