The Dreaded Idle Mystery, Idle Me This |
Apexster |
Jan 2 2020, 03:05 PM
Newbie Group: Members Posts: 8 Joined: 1-June 18 From: Concord, CA Member No.: 22,180 Region Association: Northern California |
Looking for a little insight on the dreaded idle mysteries of a 1974 2.0 914. I've searched the archives for a couple months and tried just about everything.
Valves freshly adjusted. Compression is above 135psi and within 2% on all cylinders. Original D-jet intact with new hoses and all components tested and working. Fuel pressure tested (30-31psi from original 3 hose fuel pump). New plug wires, newly rebuilt distributor, recent fuel filter. I'm about to replace the 20 year old CHT sensor as well. The car revs smoothly and pulls very strong. Engine runs great anywhere above 1200 rpm. Problem is 3 or so minutes after a cold start it drops off the high idle and transitions to a rough idle, like it's running on three cylinders. When I spray carb cleaner in the air cleaner the idle smooths out immediately. Has anyone else come across this issue and perhaps suggest a plan of action to resolve it? (IMG:style_emoticons/default/confused24.gif) Thanks and Happy New Year to All. |
Olympic 914 |
Jan 2 2020, 03:59 PM
Group: Members Posts: 1,679 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
JawjaPorsche |
Jan 2 2020, 04:34 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
(IMG:style_emoticons/default/agree.gif) I got a spacer two months ago along with a new CHT and it solved a lot of similar problems. |
Lo-Fi Version | Time is now: 13th June 2024 - 11:52 PM |
