| tvdinnerbythepool |
Oct 9 2019, 10:55 AM
Member ![]() ![]() Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest
Back is done, on to the front (later in this thread)
Hey guys, Starting winter projects: Rear Brakes/Suspension are up first. -This is a street/daily driver. Just trying to get the sagging ass up and improve the ride quality. - So far I've got New: 100lb 914rubber upper and lower shock rubber bushings Plan is to buy: Rear control arm bushings (914Rubber) Rear Caliper Rebuild Kit (If that seems beyond me I will send to PMB) Discs and Pads will be addressed as needed once I get it all apart. Turn the discs if needed or replace with new pads. We shall see. Any suggestions on anything else with the rear brakes/suspension?? Thanks all! -Rob Front Suspension/Brakes will be part 2 of the project. Just trying to keep it manageable and on budget ish |
| tvdinnerbythepool |
Jan 5 2020, 08:14 PM
Here is a side view pic. The ride height is too high and the back of the car is on jack stands making it look even worse, however, I don't think this is my issue. I believe it is the stock valance.
I'm also now thinking the formula for front ride height is not working with the rivieras...ugh Attached thumbnail(s) |
| ndfrigi |
Jan 5 2020, 09:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,993 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
Here is a side view pic. The ride height is too high and the back of the car is on jack stands making it look even worse, however, I don't think this is my issue. I believe it is the stock valance. I'm also now thinking the formula for front ride height is not working with the rivieras...ugh maybe too much negative caster or something wrong with the suspension that makes the center wheel towards the front since the picture show there is a lot of space at the rear side. and the lower valance seems bent that makes it leaning inside or that was cause by the tire rubbing to the valance? |
| raynekat |
Jan 5 2020, 09:45 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,171 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest
Here is a side view pic. The ride height is too high and the back of the car is on jack stands making it look even worse, however, I don't think this is my issue. I believe it is the stock valance. I'm also now thinking the formula for front ride height is not working with the rivieras...ugh maybe too much negative caster or something wrong with the suspension that makes the center wheel towards the front since the picture show there is a lot of space at the rear side. and the lower valance seems bent that makes it leaning inside or that was cause by the tire rubbing to the valance? I agree with both: too much caster and the lower valance looks off. |
tvdinnerbythepool Suspension and Brake Refresh Oct 9 2019, 10:55 AM
mepstein Just say NO to KYB struts. Spend the money on Bils... Oct 9 2019, 11:01 AM
SirAndy Just say NO to KYB struts
:agree: Oct 9 2019, 12:02 PM
914_teener Hope your budget is $1800.
Might as well do... Oct 9 2019, 11:51 AM
Tbrown4x4 PMB is the benchmark for caliper rebuilds, but I h... Oct 9 2019, 05:13 PM
rhodyguy Better off spending more now rather than might bei... Oct 9 2019, 05:31 PM
roblav1 As others said, don't use KYB. Oct 9 2019, 06:23 PM
914Sixer KYB= Kill Your Back. If you want to feel every pe... Oct 10 2019, 04:22 AM
tvdinnerbythepool Awesome, thanks for the input guys.
Sounds like K... Oct 10 2019, 07:40 AM
tvdinnerbythepool @Tbrown4x4 did I see you by the Olympia airport a... Oct 10 2019, 07:41 AM
Tbrown4x4 I was down that way for a wedding , but we took th... Oct 11 2019, 04:54 AM
tvdinnerbythepool Hey guys!
I've seen a few methods online b... Oct 24 2019, 10:24 PM
Hey guys!
I've seen a few methods online ... Oct 25 2019, 06:13 AM
914werke From that pic it looks like you may have more work... Oct 25 2019, 12:24 AM
Tbrown4x4 I'm reading that you are blasting the calipers... Oct 25 2019, 05:01 AM
tvdinnerbythepool @914werke for sure! It was a ton of work just... Oct 25 2019, 09:59 AM
tvdinnerbythepool 1 down! Took about 40 minutes with heat and pr... Oct 25 2019, 10:49 AM
TonyA Like that operating room clean look of your shop.... Oct 25 2019, 01:31 PM
mepstein Mine took 5-10 minutes each side but I really laid... Oct 25 2019, 11:17 AM
914werke :( Mmmm IDK... I chuck them up in the lathe ... Oct 25 2019, 11:42 AM
tvdinnerbythepool Calipers stripped, blasted and painted.
Will repo... Oct 31 2019, 08:14 AM
Tdskip It will be. Like all vintage German cars 914s resp... Oct 31 2019, 10:12 AM
tvdinnerbythepool RE: Suspension and Brake Refresh Oct 31 2019, 10:28 AM
tvdinnerbythepool RE: Suspension and Brake Refresh Oct 31 2019, 10:29 AM
tvdinnerbythepool RE: Suspension and Brake Refresh Oct 31 2019, 10:30 AM
DucRS Calipers are looking good!
Please chime in o... Oct 31 2019, 11:10 AM
mepstein Here’s Eric’s /PMB Performance video for rebui... Oct 31 2019, 11:18 AM
tvdinnerbythepool @ducrs I followed the pelican disassembly article... Nov 1 2019, 07:30 AM
mepstein I’m pretty sure all the calipers had nuts for th... Nov 1 2019, 07:34 AM
tvdinnerbythepool
I’m pretty sure all the calipers had nuts for t... Nov 1 2019, 07:45 AM
[quote name='mepstein' post='2758729' date='Nov 1... Nov 1 2019, 07:55 AM
bbrock
I’m pretty sure all the calipers had nuts for t... Nov 1 2019, 08:00 AM
[quote name='mepstein' post='2758729' date='Nov 1... Nov 1 2019, 08:48 AM
tvdinnerbythepool
Drivers side sans nuts Nov 1 2019, 07:46 AM
tvdinnerbythepool Drivers side caliper rebuilt!
Still sourcing b... Nov 5 2019, 07:46 PM
eatpez
Still sourcing ... Nov 5 2019, 08:00 PM
Tbrown4x4 Yes, those look great! Nov 5 2019, 09:34 PM
914werke Shafted! Nov 7 2019, 02:14 PM
TargaToy
Shafted!
I've been curious, since you m... Nov 15 2019, 02:32 PM
tvdinnerbythepool
914Rubber 100lb Springs on Bilsteins :headbang... Nov 13 2019, 09:45 AM
914Rubber 100lb Springs on Bilsteins :headban... Nov 13 2019, 10:27 AM
tvdinnerbythepool
914Rubber 100lb Springs on Bilsteins :headba... Nov 13 2019, 11:29 AM
type2man If you already have the rear arms out, I would def... Nov 13 2019, 06:26 PM
tvdinnerbythepool
Bearings are in! Going to make a threaded to... Nov 14 2019, 11:11 PM
tvdinnerbythepool Maybe a stupid question...how do I know when the h... Nov 15 2019, 11:55 AM
tvdinnerbythepool Should the hub shaft be flush with bearing?? Nov 15 2019, 11:56 AM
Tbrown4x4 The shoulder on the hub will bottom out on the inn... Nov 15 2019, 01:14 PM
914werke If you look at the process for installing either t... Nov 15 2019, 03:35 PM
TargaToy
If you look at the process for installing either ... Nov 15 2019, 03:59 PM
Mikey914 Actually when Elephant made their rods they used a... Nov 15 2019, 06:19 PM
914werke Actually when Elephant made their rods they used ... Nov 16 2019, 12:21 AM
Mikey914
Actually when Elephant made their rods they used... Nov 16 2019, 11:22 PM
tvdinnerbythepool Starting to see some progress and feeling like I d... Nov 16 2019, 07:05 PM
Starting to see some progress and feeling like I ... Nov 23 2019, 01:36 PM
tvdinnerbythepool
Starting to see some progress and feeling like I... Nov 23 2019, 02:07 PM
[quote name='mepstein' post='2764453' date='Nov 2... Nov 23 2019, 02:10 PM
tvdinnerbythepool @mepstein I was thinking the same thing! :co... Nov 23 2019, 03:13 PM
[b]@[url=http://www.914world.com/bbs2/index.php?s... Nov 24 2019, 12:24 PM
tvdinnerbythepool With the back pretty much wrapped up it's on t... Nov 23 2019, 12:54 PM
tvdinnerbythepool RE: Suspension and Brake Refresh Nov 23 2019, 12:54 PM
tvdinnerbythepool This was the worse of the two sides
Nov 23 2019, 12:55 PM
mepstein Heat up the fittings that hold the bushings until ... Nov 23 2019, 01:31 PM
DRPHIL914 Looks nice , did you put the spring retainer clip ... Nov 23 2019, 02:34 PM
tvdinnerbythepool @DRPHIL914 Hi! Not sure what that means...can... Nov 23 2019, 03:14 PM
DRPHIL914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Nov 23 2019, 04:47 PM
tvdinnerbythepool @DRPHIL914 gotcha! Thanks for clarifying. Yes... Nov 23 2019, 05:06 PM
[b]@[url=http://www.914world.com/bbs2/index.php?s... Nov 23 2019, 05:44 PM
jmitro
There are 6 I think slots for the retainer that h... Nov 24 2019, 02:29 PM
DRPHIL914 Looking at the tyre size charts for comparison my
... Nov 23 2019, 07:16 PM
tvdinnerbythepool Any one else have Rivieras that can weigh in?
@d... Nov 23 2019, 08:35 PM
DRPHIL914
[... Nov 24 2019, 06:35 AM
tvdinnerbythepool
Holy cow! That was stressful!
Not sure ... Dec 1 2019, 10:43 AM
cuddy_k
Not sure h... Dec 2 2019, 09:58 PM
tvdinnerbythepool Stupid question for the night. Bilsteins going up ... Dec 2 2019, 09:40 PM
Stupid question for the night. Bilsteins going up... Dec 2 2019, 10:15 PM
tvdinnerbythepool And while I'm asking...Torsion Bars!
L fo... Dec 2 2019, 09:43 PM
L f... Dec 2 2019, 10:15 PM
bbrock
L f... Dec 3 2019, 08:55 AM
tvdinnerbythepool Thank you! @mepstein and [b]@[url=http://ww... Dec 3 2019, 08:10 AM
tvdinnerbythepool Making slow progress on the front rebuild.
Rebui... Dec 18 2019, 10:34 PM
Mikey914
Rebu... Dec 19 2019, 01:50 PM
maf914 Very nice looking work!
Make sure the O-rings... Dec 19 2019, 07:16 AM
tvdinnerbythepool Thanks @mikey914 text with specs sent
Can someo... Dec 19 2019, 08:16 PM
bbrock
Thanks [b]@[url=http://www.914world.com/bbs2/ind... Dec 20 2019, 12:50 AM
rgalla9146 If doing both calipers at the same time be sure to... Dec 20 2019, 07:23 AM
tvdinnerbythepool Thanks guys, trying to wrap my mind around it.
Fou... Dec 20 2019, 09:22 AM
tvdinnerbythepool Did a test fit just to make sure I had it oriented... Dec 21 2019, 02:39 PM
tvdinnerbythepool New discs and bearings are in!
Followed Ian... Dec 21 2019, 02:40 PM
tvdinnerbythepool This car is like the most frustrating game of Whac... Jan 5 2020, 06:44 PM
DickSteinkamp
What do you guys think? Am I missing anything e... Jan 5 2020, 07:44 PM
ndfrigi with 195x60 tires, it should not be that close to ... Jan 5 2020, 07:23 PM
mepstein It’s the Rivs. That’s a wide tire for them but... Jan 5 2020, 07:41 PM
tvdinnerbythepool RE: Suspension and Brake Refresh Jan 5 2020, 08:15 PM
rhodyguy Have you settled the suspension? You need to roll ... Jan 5 2020, 08:19 PM
tvdinnerbythepool
Have you settled the suspension? You need to roll... Jan 5 2020, 08:25 PM
mepstein The type of wheel won’t make a difference. They ... Jan 5 2020, 08:25 PM
burton73
The type of wheel won’t make a difference. They... Jan 5 2020, 09:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th September 2026 - 09:52 PM |
