| DRPHIL914 |
Jan 10 2020, 09:07 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
I have been driving the 914 this week to work , perfect weather and better gas mileage than truck, anyway sudden loss of all gears but 2&3, had just left neighborhood so put car back in garage and last night I found that the shifter coupling bushing was completely gone, all the parts still inside the dirt boot cover, and of course this is a bushing I overlooked last time the motor and trans were out of the car!
It may be the original one . At first I thought I had a cone screw back out but on further inspection found this to be the culprit. So I see that there are 3-4 variations of these from bronze to stock to poly. I am wondering if it’s worth spending the extra $25 for the brass ones? Seems there are not any available that I can get over night to get car back on road before next weekend which is a bummer. So any money have suggestion are appreciate, also do we use any lube on installation. Phil This brass one looks pretty good how do the work? Attached thumbnail(s) |
76-914 They're awesome. You won't regret buying t... Jan 10 2020, 09:29 AM
914Sixer BE Careful when buying bushings. There are TWO ty... Jan 10 2020, 10:06 AM
DRPHIL914 Thanks for the info guys I think I will spring for... Jan 10 2020, 10:50 AM
ndfrigi Dr. Phil, since you will be replacing the coupler ... Jan 10 2020, 11:50 AM
Robson51 [quote name='ndfrigi' date='Jan 10 202... Jan 10 2020, 12:36 PM
DRPHIL914 Is that one Chris Foley’s or Rixx914parts? Jan 10 2020, 12:44 PM
GregAmy Tangerine Racing (Chris Foley). Installs in minute... Jan 10 2020, 01:07 PM
euro911 :agree:
I installed one of Chris' spherical ... Jan 10 2020, 06:02 PM
Mikey914 When it comes to replacing the knuckle bushing. Yo... Jan 10 2020, 07:46 PM
DRPHIL914
When it comes to replacing the knuckle bushing. Y... Jan 10 2020, 08:55 PM
IronHillRestorations I have a few sets of NOS Stoddard bushings for 914... Jan 11 2020, 07:31 AM
Dominic I had this issue a few back, NONE of the normal su... Jan 11 2020, 11:03 AM
914forme I would use a steering shaft U-joint, and figure o... Jan 11 2020, 01:57 PM
I would use a steering shaft U-joint, and figure ... Jan 12 2020, 02:01 PM
DRPHIL914
I would use a steering shaft U-joint, and figure... Jan 13 2020, 06:22 AM
Mikey914 I actually designed mine specifically cor the appl... Jan 12 2020, 12:34 PM
euro911 ahhhh ... A German Mauser? :shoot2kill: Jan 12 2020, 02:51 PM
Mikey914 Post up a pic.
I think you have the steering knuck... Jan 13 2020, 01:03 PM
Mikey914 And these easily pres in with a bench vice Jan 13 2020, 01:05 PM
mepstein Jwest used a splined stub that once welded onto th... Jan 13 2020, 01:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th September 2026 - 08:57 AM |
