| raynekat |
Jan 9 2020, 11:58 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,171 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest
Just curious what the typical volt meter reading is:
1) when you're sitting at the stoplight 2) cruising down the boulevard at 3-4000 rpm Trying to see if I'm seeing typical or low readings Thanks I just recently noted a low charging issue that I believe came down to an alternator/voltage regulator mismatch. I was using a Bosch VR with my Motorola alternator. Now I've switched to a Marchal VR and the charging voltages look better. About 13.75 volts while cruising. |
| 914Toy |
Jan 10 2020, 02:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 746 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California
Question: what is the accuracy of these voltmeters? - I suspect not better than +/- one volt
raynekat What's your volt meter reading when cruising around town? Jan 9 2020, 11:58 PM
Pursang When driving I think it runs around 13v or so. War... Jan 10 2020, 02:12 AM
Mark Henry You're good at 13.75v Jan 10 2020, 05:55 AM
dr914@autoatlanta.com 13.6 is the standard. Anything over 14 volts mean... Jan 10 2020, 10:46 AM
porschetub
13.6 is the standard. Anything over 14 volts mea... Jan 10 2020, 01:29 PM
porschetub I seemed to remember there was a gold foil sticker... Jan 10 2020, 01:49 PM
ctc911ctc Kitty Forman : So, what do you want for your birth... Feb 15 2020, 06:29 PM
SO.O.C914er I’m seeing just under 14v day time driving but w... Jan 10 2020, 02:17 PM
914Toy Question: what is the accuracy of these voltmeters... Jan 10 2020, 02:56 PM
raynekat My 13.75 volts is coming from a voltmeter across t... Jan 10 2020, 11:45 PM
Superhawk996
My 13.75 volts is coming from a voltmeter across ... Jan 11 2020, 07:06 AM
SO.O.C914er Extremely good input (superhawk) this really answe... Jan 11 2020, 12:01 PM
raynekat Lots of great info there Superhawk.
I have one of... Jan 11 2020, 12:56 PM
porschetub It's entirely possible that this battery will ... Jan 11 2020, 02:00 PM
Superhawk996
I have one o... Jan 11 2020, 02:46 PM
raynekat Superhawk....again some great comments and insight... Jan 11 2020, 05:37 PM
Superhawk996
Superhawk....again some great comments and insigh... Jan 11 2020, 07:03 PM
Spoke As far as LED current is concerned, my brake board... Jan 11 2020, 07:17 PM
Superhawk996
As far as LED current is concerned, my brake boar... Jan 11 2020, 08:10 PM
raynekat My car still has normal light bulbs in all the gau... Jan 11 2020, 11:17 PM
Superhawk996
My car still has normal light bulbs in all the ga... Jan 12 2020, 07:32 AM
raynekat Here's the current clamp I purchased.
Took qui... Jan 16 2020, 02:28 PM
Superhawk996
Guess the next question is where exactly would ... Jan 16 2020, 06:09 PM
raynekat On a positive note, I checked the charging at my b... Jan 16 2020, 02:30 PM
raynekat Superhawk....I think you were dead on about that L... Jan 17 2020, 05:52 PM
Superhawk996 Nice work and great information for the community.... Jan 18 2020, 08:50 AM
VaccaRabite
Out of curiosity, did you get the current clamp ... Jan 21 2020, 07:56 PM
bbrock Thanks for posting those number Doug! This is... Jan 18 2020, 10:18 AM
GeorgeRud Makes me long for the days of ammeter gauges on th... Jan 18 2020, 10:33 AM
GeorgeRud Usually reads about 13.5 volts while driving. I d... Jan 18 2020, 10:35 AM
Spoke
...I don’t know how accurate the VDO voltmeter ... Jan 18 2020, 01:34 PM
raynekat Here's what the "offending" battery ... Jan 21 2020, 11:59 PM
raynekat Looking at one of these AGM batteries as a replace... Jan 22 2020, 12:53 AM
raynekat Received my new battery today from JEGS.
Man is i... Feb 15 2020, 02:57 PM
raynekat So the real important thing for me is fit in the c... Feb 15 2020, 03:03 PM
raynekat My car had 2 issues.
1) non matching voltage regul... Feb 15 2020, 07:40 PM
FlacaProductions @raynekat - that's a really good find and whi... Feb 15 2020, 08:35 PM
raynekat
[b]@[url=http://www.914world.com/bbs2/index.php?s... Feb 15 2020, 09:54 PM
raynekat Here's what the battery looks like with one of... Feb 24 2020, 06:38 PM
FlacaProductions Looks good! Feb 24 2020, 06:40 PM
raynekat Final iteration with a bit of black vinyl and a fu... Mar 12 2020, 09:30 PM
FlacaProductions Slick. Nicely done!! Mar 12 2020, 09:45 PM
Superhawk996 Glad to see its running properly for you now. Bat... Mar 13 2020, 03:11 PM
raynekat
Glad to see its running properly for you now. Ba... Mar 13 2020, 04:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th October 2026 - 10:21 PM |
