> 914World Classifieds Rules
> Shift coupler bushing failure- what’s the best replacement, Lost all but 2&3 -
DRPHIL914
post Jan 10 2020, 09:07 AM
Dr. Phil
I have been driving the 914 this week to work , perfect weather and better gas mileage than truck, anyway sudden loss of all gears but 2&3, had just left neighborhood so put car back in garage and last night I found that the shifter coupling bushing was completely gone, all the parts still inside the dirt boot cover, and of course this is a bushing I overlooked last time the motor and trans were out of the car!
It may be the original one . At first I thought I had a cone screw back out but on further inspection found this to be the culprit.
So I see that there are 3-4 variations of these from bronze to stock to poly.
I am wondering if it’s worth spending the extra $25 for the brass ones? Seems there are not any available that I can get over night to get car back on road before next weekend which is a bummer. So any money have suggestion are appreciate, also do we use any lube on installation.
Phil
This brass one looks pretty good how do the work?
euro911
post Jan 10 2020, 06:02 PM
I installed one of Chris' spherical bushings on my '75 (the 'BB') and it really improved the shifting (along with bronze coupler bushings and a bronze shift console bushing).
Due to special circumstances, I had to modify the bushing's housing a tad to inset it into the firewall, as I was unable to engage all gears, and didn't want to go through the process to move the motor and trans rearward.
YMMV ... in normal instances, you should be able to bolt (or rivet) it to your firewall without modifications ... especially on a late model's firewall.
DRPHIL914   Shift coupler bushing failure- what’s the best replacement   Jan 10 2020, 09:07 AM
76-914   They're awesome. You won't regret buying t...   Jan 10 2020, 09:29 AM
914Sixer   BE Careful when buying bushings. There are TWO ty...   Jan 10 2020, 10:06 AM
DRPHIL914   Thanks for the info guys I think I will spring for...   Jan 10 2020, 10:50 AM
ndfrigi   Dr. Phil, since you will be replacing the coupler ...   Jan 10 2020, 11:50 AM
Robson51   [quote name='ndfrigi' date='Jan 10 202...   Jan 10 2020, 12:36 PM
DRPHIL914   Is that one Chris Foley’s or Rixx914parts?   Jan 10 2020, 12:44 PM
GregAmy   Tangerine Racing (Chris Foley). Installs in minute...   Jan 10 2020, 01:07 PM
euro911   :agree: I installed one of Chris' spherical ...   Jan 10 2020, 06:02 PM
Mikey914   When it comes to replacing the knuckle bushing. Yo...   Jan 10 2020, 07:46 PM
DRPHIL914   When it comes to replacing the knuckle bushing. Y...   Jan 10 2020, 08:55 PM
IronHillRestorations   I have a few sets of NOS Stoddard bushings for 914...   Jan 11 2020, 07:31 AM
Dominic   I had this issue a few back, NONE of the normal su...   Jan 11 2020, 11:03 AM
914forme   I would use a steering shaft U-joint, and figure o...   Jan 11 2020, 01:57 PM
mepstein   I would use a steering shaft U-joint, and figure ...   Jan 12 2020, 02:01 PM
DRPHIL914   I would use a steering shaft U-joint, and figure...   Jan 13 2020, 06:22 AM
Mikey914   I actually designed mine specifically cor the appl...   Jan 12 2020, 12:34 PM
euro911   ahhhh ... A German Mauser? :shoot2kill:   Jan 12 2020, 02:51 PM
Mikey914   Post up a pic. I think you have the steering knuck...   Jan 13 2020, 01:03 PM
Mikey914   And these easily pres in with a bench vice   Jan 13 2020, 01:05 PM
mepstein   Jwest used a splined stub that once welded onto th...   Jan 13 2020, 01:48 PM
- Lo-Fi Version Time is now: 19th September 2026 - 08:56 AM
