> What's your volt meter reading when cruising around town?
raynekat
post Jan 9 2020, 11:58 PM
Just curious what the typical volt meter reading is:
1) when you're sitting at the stoplight
2) cruising down the boulevard at 3-4000 rpm
Trying to see if I'm seeing typical or low readings
Thanks
I just recently noted a low charging issue that I believe came down to an alternator/voltage regulator mismatch.
I was using a Bosch VR with my Motorola alternator.
Now I've switched to a Marchal VR and the charging voltages look better.
About 13.75 volts while cruising.
raynekat
post Jan 11 2020, 05:37 PM
Superhawk....again some great comments and insights.
The Antigravity Rs-30 has 1200 cranking amps and weighs 11.5 lbs (one of important reasons I chose this battery....possibly the wrong one).
The Optima 34R has less at 800 cranking amps and weighs in a whopping 37.9 lbs. Obviously this is necessary (the added weight) to get the higher amp-hr rating.
Actually, after the current (or voltage) drops low enough in the Antigravity battery, it turns itself off saving enough power to do 2-3 restarts. Supposedly you'll never get stranded. ??? When I was driving around at night with all the lighting on and the wipers going, my little LED gauge plugged into the cigarette outlet was dropping down to 10V. That got my attention as well as the lights dimming quite a bit while idling at the stoplight.
Sounds to me, a larger amp-hr battery may be in my future.
You are likely right that this would be a great battery for a race car.
It's very lightweight and starts the car.
Wonder if this Antigravity will fit in my Vespa??? (IMG:style_emoticons/default/idea.gif)
raynekat   What's your volt meter reading when cruising around town?   Jan 9 2020, 11:58 PM
Pursang   When driving I think it runs around 13v or so. War...   Jan 10 2020, 02:12 AM
Mark Henry   You're good at 13.75v   Jan 10 2020, 05:55 AM
dr914@autoatlanta.com   13.6 is the standard. Anything over 14 volts mean...   Jan 10 2020, 10:46 AM
porschetub   13.6 is the standard. Anything over 14 volts mea...   Jan 10 2020, 01:29 PM
porschetub   I seemed to remember there was a gold foil sticker...   Jan 10 2020, 01:49 PM
ctc911ctc   Kitty Forman : So, what do you want for your birth...   Feb 15 2020, 06:29 PM
SO.O.C914er   I’m seeing just under 14v day time driving but w...   Jan 10 2020, 02:17 PM
914Toy   Question: what is the accuracy of these voltmeters...   Jan 10 2020, 02:55 PM
914Toy   Question: what is the accuracy of these voltmeters...   Jan 10 2020, 02:56 PM
raynekat   My 13.75 volts is coming from a voltmeter across t...   Jan 10 2020, 11:45 PM
Superhawk996   My 13.75 volts is coming from a voltmeter across ...   Jan 11 2020, 07:06 AM
SO.O.C914er   Extremely good input (superhawk) this really answe...   Jan 11 2020, 12:01 PM
raynekat   Lots of great info there Superhawk. I have one of...   Jan 11 2020, 12:56 PM
porschetub   It's entirely possible that this battery will ...   Jan 11 2020, 02:00 PM
Superhawk996   Lots of great info there Superhawk. I have one o...   Jan 11 2020, 02:46 PM
raynekat   Superhawk....again some great comments and insight...   Jan 11 2020, 05:37 PM
Superhawk996   Superhawk....again some great comments and insigh...   Jan 11 2020, 07:03 PM
Spoke   As far as LED current is concerned, my brake board...   Jan 11 2020, 07:17 PM
Superhawk996   As far as LED current is concerned, my brake boar...   Jan 11 2020, 08:10 PM
raynekat   My car still has normal light bulbs in all the gau...   Jan 11 2020, 11:17 PM
Superhawk996   My car still has normal light bulbs in all the ga...   Jan 12 2020, 07:32 AM
raynekat   Here's the current clamp I purchased. Took qui...   Jan 16 2020, 02:28 PM
Superhawk996   Guess the next question is where exactly would ...   Jan 16 2020, 06:09 PM
raynekat   On a positive note, I checked the charging at my b...   Jan 16 2020, 02:30 PM
raynekat   Superhawk....I think you were dead on about that L...   Jan 17 2020, 05:52 PM
Superhawk996   Nice work and great information for the community....   Jan 18 2020, 08:50 AM
VaccaRabite   Out of curiosity, did you get the current clamp ...   Jan 21 2020, 07:56 PM
bbrock   Thanks for posting those number Doug! This is...   Jan 18 2020, 10:18 AM
GeorgeRud   Makes me long for the days of ammeter gauges on th...   Jan 18 2020, 10:33 AM
GeorgeRud   Usually reads about 13.5 volts while driving. I d...   Jan 18 2020, 10:35 AM
Spoke   ...I don’t know how accurate the VDO voltmeter ...   Jan 18 2020, 01:34 PM
raynekat   Here's what the "offending" battery ...   Jan 21 2020, 11:59 PM
raynekat   Looking at one of these AGM batteries as a replace...   Jan 22 2020, 12:53 AM
raynekat   Received my new battery today from JEGS. Man is i...   Feb 15 2020, 02:57 PM
raynekat   So the real important thing for me is fit in the c...   Feb 15 2020, 03:03 PM
raynekat   My car had 2 issues. 1) non matching voltage regul...   Feb 15 2020, 07:40 PM
FlacaProductions   @raynekat - that's a really good find and whi...   Feb 15 2020, 08:35 PM
raynekat   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Feb 15 2020, 09:54 PM
raynekat   Here's what the battery looks like with one of...   Feb 24 2020, 06:38 PM
FlacaProductions   Looks good!   Feb 24 2020, 06:40 PM
raynekat   Final iteration with a bit of black vinyl and a fu...   Mar 12 2020, 09:30 PM
FlacaProductions   Slick. Nicely done!!   Mar 12 2020, 09:45 PM
Superhawk996   Glad to see its running properly for you now. Bat...   Mar 13 2020, 03:11 PM
raynekat   Glad to see its running properly for you now. Ba...   Mar 13 2020, 04:38 PM
- Lo-Fi Version Time is now: 18th October 2026 - 10:24 PM
