| raynekat |
Jan 9 2020, 11:58 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,171 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest
Just curious what the typical volt meter reading is:
1) when you're sitting at the stoplight 2) cruising down the boulevard at 3-4000 rpm Trying to see if I'm seeing typical or low readings Thanks I just recently noted a low charging issue that I believe came down to an alternator/voltage regulator mismatch. I was using a Bosch VR with my Motorola alternator. Now I've switched to a Marchal VR and the charging voltages look better. About 13.75 volts while cruising. |
| raynekat |
Jan 11 2020, 11:17 PM
My car still has normal light bulbs in all the gauges including the generator light. The generator light appears to act normally. Turn the key, and the generator lamp lights up until you start the car. When I first start it up, I get a small glow until I blip the throttle and get the revs up, and the light disappears. After a few minutes warming up on the hand throttle, upon release of the hand throttle and idling at about 700-800 rpm, you don't see the generator light.
The engine is your standard MFI with the CDI box arrangement. When I had my issue, I had the headlights on, brakes on and wipers on plus the engine of course. I'll pick up one of the current clamps that you mentioned here in the next day or so, and report back on what I find. Is it easy to measure DC current? Or are we measuring AC current? Thought most everything on the car was DC. |
| Superhawk996 |
Jan 12 2020, 07:32 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,136 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
My car still has normal light bulbs in all the gauges including the generator light. The generator light appears to act normally. Turn the key, and the generator lamp lights up until you start the car. When I first start it up, I get a small glow until I blip the throttle and get the revs up, and the light disappears. After a few minutes warming up on the hand throttle, upon release of the hand throttle and idling at about 700-800 rpm, you don't see the generator light. The engine is your standard MFI with the CDI box arrangement. When I had my issue, I had the headlights on, brakes on and wipers on plus the engine of course. I'll pick up one of the current clamps that you mentioned here in the next day or so, and report back on what I find. Is it easy to measure DC current? Or are we measuring AC current? Thought most everything on the car was DC. Glad to hear the Generator bulb is still incandescent. That takes one variable out of the loop. Seems to be working properly. Don't underestimate a CDI current draw. Quick info I can find seems on Summit Racing site for a Mallory CDI indicate about 0.7 to 0.9A/1000 rev's. So at a 3000 RPM cruise, that is 2.7A just from that device alone. We are measuring DC current. With a current clamp it is super easy non invasive measurement. Just place the clamp around the red wire that leads from the alternator to the B+ source (actually starter motor terminal IIRC) to see what the alternator is doing on its own (is it sourcing current to the battery, how much current, etc). Likewise, if you want to see the net inflow/outflow of the battery, you can put the clamp around the large (like 4AWG gauge) red battery wire. This is where you would be able to see what your actual electrical loads are that the battery is sourcing current to. There are hall effect AC/DC current clamps that can read both AC and DC current. The super cheap ones (like $30) usually are AC only - you don't want one of those. However, I think last I looked, you could find one that measure AC & DC for about $80. Just be sure that it has something on the order of a 0-6A or 0-10A low range for DC current. Be sure to look at specs on low end units. Sometimes the range is 0-60A; depneding on the accuracy, something on the order of 6A load might very well be +/- a couple of amps which might make it difficult to see what is going on. Could definately tell current direction (charging or not charging) but it might be hard to see if the Li-ion BMS is throttling current by a couple amps. |
raynekat What's your volt meter reading when cruising around town? Jan 9 2020, 11:58 PM
Pursang When driving I think it runs around 13v or so. War... Jan 10 2020, 02:12 AM
Mark Henry You're good at 13.75v Jan 10 2020, 05:55 AM
dr914@autoatlanta.com 13.6 is the standard. Anything over 14 volts mean... Jan 10 2020, 10:46 AM
porschetub
13.6 is the standard. Anything over 14 volts mea... Jan 10 2020, 01:29 PM
porschetub I seemed to remember there was a gold foil sticker... Jan 10 2020, 01:49 PM
ctc911ctc Kitty Forman : So, what do you want for your birth... Feb 15 2020, 06:29 PM
SO.O.C914er I’m seeing just under 14v day time driving but w... Jan 10 2020, 02:17 PM
914Toy Question: what is the accuracy of these voltmeters... Jan 10 2020, 02:55 PM
914Toy Question: what is the accuracy of these voltmeters... Jan 10 2020, 02:56 PM
raynekat My 13.75 volts is coming from a voltmeter across t... Jan 10 2020, 11:45 PM
Superhawk996
My 13.75 volts is coming from a voltmeter across ... Jan 11 2020, 07:06 AM
SO.O.C914er Extremely good input (superhawk) this really answe... Jan 11 2020, 12:01 PM
raynekat Lots of great info there Superhawk.
I have one of... Jan 11 2020, 12:56 PM
porschetub It's entirely possible that this battery will ... Jan 11 2020, 02:00 PM
Superhawk996
I have one o... Jan 11 2020, 02:46 PM
raynekat Superhawk....again some great comments and insight... Jan 11 2020, 05:37 PM
Superhawk996
Superhawk....again some great comments and insigh... Jan 11 2020, 07:03 PM
Spoke As far as LED current is concerned, my brake board... Jan 11 2020, 07:17 PM
Superhawk996
As far as LED current is concerned, my brake boar... Jan 11 2020, 08:10 PM
raynekat Here's the current clamp I purchased.
Took qui... Jan 16 2020, 02:28 PM
Superhawk996
Guess the next question is where exactly would ... Jan 16 2020, 06:09 PM
raynekat On a positive note, I checked the charging at my b... Jan 16 2020, 02:30 PM
raynekat Superhawk....I think you were dead on about that L... Jan 17 2020, 05:52 PM
Superhawk996 Nice work and great information for the community.... Jan 18 2020, 08:50 AM
VaccaRabite
Out of curiosity, did you get the current clamp ... Jan 21 2020, 07:56 PM
bbrock Thanks for posting those number Doug! This is... Jan 18 2020, 10:18 AM
GeorgeRud Makes me long for the days of ammeter gauges on th... Jan 18 2020, 10:33 AM
GeorgeRud Usually reads about 13.5 volts while driving. I d... Jan 18 2020, 10:35 AM
Spoke
...I don’t know how accurate the VDO voltmeter ... Jan 18 2020, 01:34 PM
raynekat Here's what the "offending" battery ... Jan 21 2020, 11:59 PM
raynekat Looking at one of these AGM batteries as a replace... Jan 22 2020, 12:53 AM
raynekat Received my new battery today from JEGS.
Man is i... Feb 15 2020, 02:57 PM
raynekat So the real important thing for me is fit in the c... Feb 15 2020, 03:03 PM
raynekat My car had 2 issues.
1) non matching voltage regul... Feb 15 2020, 07:40 PM
FlacaProductions @raynekat - that's a really good find and whi... Feb 15 2020, 08:35 PM
raynekat
[b]@[url=http://www.914world.com/bbs2/index.php?s... Feb 15 2020, 09:54 PM
raynekat Here's what the battery looks like with one of... Feb 24 2020, 06:38 PM
FlacaProductions Looks good! Feb 24 2020, 06:40 PM
raynekat Final iteration with a bit of black vinyl and a fu... Mar 12 2020, 09:30 PM
FlacaProductions Slick. Nicely done!! Mar 12 2020, 09:45 PM
Superhawk996 Glad to see its running properly for you now. Bat... Mar 13 2020, 03:11 PM
raynekat
Glad to see its running properly for you now. Ba... Mar 13 2020, 04:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th October 2026 - 10:23 PM |
