| anderssj |
Jan 12 2020, 12:10 PM
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,809 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region
I finally got around to installing the turbo tie rods I purchased from Pelican almost 4 years ago (!). I thought I should share some pictures from the install in hopes they might help somebody do the same job in the future (standard disclaimers apply--"your mileage may vary," etc.)
A couple of things up front: First, this upgrade is well worth doing. It made my car's steering much more precise, bringing it back to better-than-new levels. Second, earlier threads here in the garage were extremely helpful, especially GWN7's from back 2006: http://www.914world.com/bbs2/index.php?sho...c=56323&hl= Thanks to all who have shared their thoughts and pictures in this and other related threads! Third, those who have done this job without a lift, using only jack stands, etc., are amazing. Here's to you! (IMG:style_emoticons/default/beerchug.gif) I was lucky to have a lift, otherwise I'd still be under the car. The kit I bought from Pelican included two Lemforder tie-rod assemblies and a pair of boots. I also bought a pair of tie rod washers ("spacers"). All parts seem very well made. I also bought one of the custom-made tie rod wrenches during a group buy here on the world (more on that later). As far as general procedures, I followed the steps in GWN7's thread (as I said, very helpful). I did the right/passenger side first, so as to avoid working around the brake master cylinder until I was up on the learning curve a little. And now for the work itself: This may seem obvious, but first I disconnected the battery. Leaving the key in the on position let me "steer" the rack from left to right to improve access, and didn't want to risk hurting anything in the ignition. I also used a brush and compressed air to get rid of any crap that could fall into/onto the rack. Then, after removing the front wheel I used a tie rod separator (and a BFH) to remove the outer tie rod: The tie rod separator is also referred to as a "pickle fork"... The only odd thing I found here was that the nut on the right side was a Nyloc-type, not the castle nut/cotter pin I expected. Not sure who did that or when--but it was in keeping with some of the other odd stuff I found when replacing the clutch last month. With the tie rod hanging down, I pushed the outer end of the old boot back (towards the center of the car) and off the retainer. Left the spring on the boot for safe keeping. I used the "group buy wrench" to loosen the boot retainer. Another view... The wrench fit the boot retainer well and made loosening it easy. Observation: I think retaining the boot is only one function of this piece--given that the boot retainer is threaded and tightened to 51ft-lb (per Haynes, page 99), I think it also serves as a "jam nut" for the tie rod eye bolt. Too bad it wouldn't fit inside the new boot, or I'd have been tempted to reuse it instead of the new spacer. |
| soccerplyr |
Jan 13 2020, 07:56 PM
Newbie ![]() Group: Members Posts: 25 Joined: 31-August 13 From: Sandy, Utah Member No.: 16,329 Region Association: Rocky Mountains |
Thanks for posting. I bought some recently and plan on attempting as soon as it gets above freezing for a few days. Where did you get the tie rod wrench?
| anderssj |
Jan 14 2020, 08:51 AM
anderssj Turbo Tie Rod Install Jan 12 2020, 12:10 PM
anderssj And this is where the trouble began...
The next s... Jan 12 2020, 01:05 PM
Montreal914 Nice write up, looking forward to the rest. :popc... Jan 12 2020, 01:48 PM
Tdskip Nice job, thanks for posting Jan 12 2020, 03:38 PM
anderssj Doggone it--we got back from our drive and the pow... Jan 12 2020, 10:46 PM
cuddy_k Nicely done! Great details. Jan 13 2020, 12:15 AM
anderssj OK, on the driver's side things went much bett... Jan 14 2020, 09:42 AM
anderssj Almost forgot...check your car's alignment aft... Jan 14 2020, 11:26 AM![]() ![]() |
Lo-Fi Version | Time is now: 20th November 2026 - 09:05 PM |
