> Door stay kit
post Dec 7 2019, 09:58 PM
914-6 GT in waiting
Help me understand. The door stay kit I’m using comes with a pin but it’s too big for the hole. I could make the hole bigger but there’s still no groove for a clip. Stock pin on right
@Mikey914
bbrock
post Jan 15 2020, 10:37 AM
@Mikey914
Here's how I tamed the click and a suggestion for making these kits nearly universal for only a few extra pennies.
My chassis stay brackets were not wallowed and I had no interest in reaming them out - especially with fresh paint on the car. Instead, I picked up some 1/4" O.D. aluminum bushings at the local ACE and JB Welded them into the arm bore.
(IMG:http://www.914world.com/bbs2/uploads/post-20845-1579104259_thumb.jpg)
Then I drilled the bushing out to 15/64" (~6mm) and filed it flush to the arm. In hind sight, it would have been better to bore the arm out to 3/8" and using a matching O.D. bushing to leave more "meat" behind after drilling it out.
(IMG:http://www.914world.com/bbs2/uploads/post-20845-1579104558_thumb.jpg)
I couldn't source OEM size 6x16mm clevis pins locally but substituted 6mm tension pins like I proposed earlier. I actually think tension pins are an improvement over the clevis pins because they don't rotate in the bracket bore. All of the wear should occur on the arm bore and keep the chassis brackets from wallowing out. They are a bit of a pain to install but once they are in, I get smooth, click-free action from the door stays. (IMG:style_emoticons/default/shades.gif)
There is more detail on this process here on my build thread.
Here's what I think could make these stay kits more user friendly. Bore the arms out to 3/8" and supply two sets of pre-drilled bushings so users can install OEM or overbore as needed for their car. Also include two sets of pins (clevis, tension, or both) to match the bore sizes. With 3/8" O.D. bushings, there should be no need to epoxy the bushings into place as there would be enough wall thickness left to just pop them into the bore. It might even be an improvement by creating a double bearing surface for wear.
Those are my thoughts anyway.
mepstein   Door stay kit   Dec 7 2019, 09:58 PM
Krieger   Iirc the pins were made oversized because the mont...   Dec 8 2019, 12:07 AM
mepstein   Iirc the pins were made oversized because the mon...   Dec 8 2019, 07:47 AM
mb911   That explains why they fit so tight for me and end...   Dec 8 2019, 05:48 AM
roblav1   Turn 'em on a lathe! On mine, which I just...   Dec 8 2019, 07:18 AM
FlacaProductions   Check here (specifically posts 14 and 16): http://...   Dec 8 2019, 08:42 AM
Mikey914   We initially made them to the OEM size. The compla...   Dec 9 2019, 02:00 AM
raynekat   So we made them slightly larger to eliminate the ...   Dec 10 2019, 11:18 AM
914forme   :agree: So my plans to be buried in space in my 9...   Dec 9 2019, 04:40 AM
Mikey914   Yes we are trying to be a little more clear for ou...   Dec 9 2019, 10:29 AM
mepstein   I appreciate that 914rubber is making the parts. I...   Dec 9 2019, 10:50 AM
BeatNavy   I appreciate that 914rubber is making the parts. ...   Dec 10 2019, 08:52 AM
raynekat   So if I have to file the pin smaller to fit the ho...   Dec 10 2019, 01:43 AM
bbrock   I happened to glance at the door stay on my Nissan...   Dec 10 2019, 08:37 AM
Bartlett 914   I happened to glance at the door stay on my Nissa...   Dec 11 2019, 08:54 AM
Mikey914   Forgot we did change the arms. So perhaps This nex...   Dec 10 2019, 11:51 PM
Superhawk996   Wow! Hard group to please on this topic. L...   Dec 11 2019, 06:06 AM
mepstein   I think it would be helpful to print in the part d...   Dec 11 2019, 07:21 AM
ThePaintedMan   :agree: They do one heck of a job trying to please...   Dec 11 2019, 07:43 AM
Mikey914   Guys, I do really appreciate the input. We made ch...   Dec 11 2019, 07:50 AM
mepstein   Guys, I do really appreciate the input. We made c...   Dec 11 2019, 08:33 AM
ctc911ctc   All, I bought this kit for both doors and install...   Dec 18 2019, 04:21 PM
Mikey914   All, I bought this kit for both doors and instal...   Dec 18 2019, 05:12 PM
oldschool   I've been hoping to get the repair kit.......S...   Dec 18 2019, 11:07 PM
bbrock   @[url=http://www.914world.com/bbs2/index.php?showu...   Jan 15 2020, 10:37 AM
Mikey914   Our current game plan is to go back to stock hole ...   Jan 15 2020, 11:00 AM
bbrock   Our current game plan is to go back to stock hole...   Jan 15 2020, 11:05 AM
914lover17   Our current game plan is to go back to stock hole...   Sep 7 2021, 09:34 PM
jfort   glad to see this thread. my kit is somewhere, neve...   Jan 15 2020, 01:47 PM
bbrock   glad to see this thread. my kit is somewhere, nev...   Jan 15 2020, 03:27 PM
Front yard mechanic   Just use bailing wire and end the bitching :stooge...   Sep 8 2021, 06:34 AM
- Lo-Fi Version Time is now: 19th September 2026 - 02:57 AM
