I've been cuttin' some more, rear end is just about gone |
URY914 |
Dec 6 2004, 08:40 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,944 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
This weekend I welded the 1 1/4" tube that locates the rear tranny mount. After that I was able to cut out the left side sheet metal. I have a BIG pile of metal left over. (IMG:style_emoticons/default/sawzall-smiley.gif)
Attached thumbnail(s) |
Mike T |
Dec 8 2004, 02:42 PM
can't 'member Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
it's a 1975 tub still all steel except for the GT flares which are riveted on.
rear tires are 23.5x12.0-15 Hoosier R35 on 14"wide x 15" dia wheels. 5.5" backspace. front tires are 22.5 x 9.0-15 on 10" wide by 15" dia. wheels with 4" B.S. weltmeister 22mm front swaybar, 22mm swayaway T-bars, 250lb springs rear, Koni reds all around. Poly bushings with monoball upper front strut mounts. As Paul mentioned it was a V6 (2.8 Chevy) for 6 years and I had it working pretty well. Now with the V8 I'm starting the tuning process over. It's still pretty heavy and this winter I'm doing a lot of cutting. The car is really too wide and I may try narrower rear wheels next season. 12" wide. I have more pictures at home. I'll post later. (Not trying to hijack your thread Paul) Mike T |
Lo-Fi Version | Time is now: 1st June 2024 - 11:22 AM |
