Shift rod - Update- new brass bushings, and another option-a 911 coupler from Rauch & Spiegel, Is this a normal looking rod? And how the heck do I get the pin out? |
DRPHIL914 |
Jan 16 2020, 04:57 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
A few issues here , after the bushing disintegrated I ordered new stuff, a new firewall bushing from RIX914PARTS and other goodies from 914rubber.com, and a new brass bushing for the coupling, however I can’t get the pin out, and I’m going to mess up the pin end and it’s not going to slide thru if I do that- so I’m going to have to find a press I guess somewhere?
1. Should it be that tight ? 2. Is this a normal weld end? Attached thumbnail(s) |
rhodyguy |
Jan 18 2020, 11:32 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
From the pictures the pin ends look pretty distorted. That won't make the task any easier.
IronHillRestorations |
Jan 18 2020, 12:14 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
From the pictures the pin ends look pretty distorted. That won't make the task any easier. Good point. So you want to make sure the pin doesn't have any burrs on it that would give you trouble pressing it through. If both sides have boogers, you can get by cleaning off the press through side. |
Lo-Fi Version | Time is now: 11th June 2024 - 08:18 AM |
