| DRPHIL914 |
Jan 16 2020, 04:57 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
A few issues here , after the bushing disintegrated I ordered new stuff, a new firewall bushing from RIX914PARTS and other goodies from 914rubber.com, and a new brass bushing for the coupling, however I can’t get the pin out, and I’m going to mess up the pin end and it’s not going to slide thru if I do that- so I’m going to have to find a press I guess somewhere?
1. Should it be that tight ? 2. Is this a normal weld end? Attached thumbnail(s) |
| Mikey914 |
Jan 18 2020, 04:19 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Why replace a perfectly good part ?
You still have to press the shaft out of the old assembly. We had looked at making these but got down to that question. Perhaps we make an entire assembly? Easy swap out. |
DRPHIL914 Shift rod - Update- new brass bushings, and another option-a 911 coupler from Rauch & Spiegel Jan 16 2020, 04:57 PM
dr914@autoatlanta.com lube the pin, support the coupler in a vice with w... Jan 16 2020, 05:25 PM
BeatNavy That was one of the more frustrating tasks I'v... Jan 16 2020, 06:05 PM
mepstein You will never regret getting a press. It’s one ... Jan 16 2020, 06:14 PM
BeatNavy
You will never regret getting a press. It’s one... Jan 16 2020, 06:34 PM
jmitro
You will never regret getting a press. It’s one... Jan 16 2020, 10:27 PM
Chris914n6 2. Normal
The coupler is not that strong. It... Jan 16 2020, 06:36 PM
poorsche914
2. Normal
The coupler is not that strong. It... Jan 16 2020, 09:12 PM
DRPHIL914
2. Normal
The coupler is not that strong. It... Jan 16 2020, 09:19 PM
IronHillRestorations I've done a bunch of those. I use two sockets... Jan 16 2020, 11:04 PM
anderssj Dr. Phil,
A couple of links I found helpful:
htt... Jan 17 2020, 08:53 AM
rhodyguy From the pictures the pin ends look pretty distort... Jan 18 2020, 11:32 AM
From the pictures the pin ends look pretty distor... Jan 18 2020, 12:14 PM
DRPHIL914
From the pictures the pin ends look pretty disto... Jan 18 2020, 03:21 PM
DRPHIL914 https://sierramadrecollection.com/Shift-Cou...-88-... Jan 18 2020, 03:26 PM
Mark Henry Six inch vice, the two socket method....and that w... Jan 18 2020, 07:29 PM
rhodyguy 1/2 step forward and 4 steps backwards with those ... Jan 18 2020, 08:59 PM
mlindner DrPhil, if all fails, I do have a nice one for sal... Jan 19 2020, 06:26 AM
DRPHIL914
DrPhil, if all fails, I do have a nice one for sa... Jan 19 2020, 06:01 PM
Tdskip Personally I’d replace it since if the repairs a... Jan 19 2020, 07:57 AM
TheCabinetmaker 911 has an oval hole in the bushings that won... Jan 19 2020, 08:43 AM
DRPHIL914 Ok tried getting the pin to move with clamp press ... Jan 20 2020, 08:01 PM
Ok tried getting the pin to move with clamp press... Jan 20 2020, 08:06 PM
DRPHIL914 Posting an update! I had given up after taking... Jan 30 2020, 11:52 AM
SirAndy :first: Jan 30 2020, 12:15 PM
DRPHIL914 i wish I had taken better pictures of the pin to s... Jan 30 2020, 12:41 PM
914Sixer Here is mine using the later stouter 911 coupler. ... Jan 30 2020, 02:11 PM
DRPHIL914
Here is mine using the later stouter 911 coupler.... Jan 30 2020, 05:27 PM
DRPHIL914 Update:
Just got a couple pictures of that shift ... Feb 21 2020, 08:51 AM
Olympic 914 That s the first time I have seen the bronze coupl... Feb 21 2020, 06:58 PM
DRPHIL914
That s the first time I have seen the bronze coup... Feb 21 2020, 07:11 PM
maf914
That s the first time I have seen the bronze coup... Feb 23 2020, 07:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:02 PM |
