| JFG |
Jan 12 2020, 08:50 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
On new years day i took my car out. There was intermittent rain for the early part of the drive. The wipers worked fine.
On the way back i had fog/mist which wet the screen but no wipers. I stopped in the services and checked the nut on the motor connection, this was tight. However there was no noise of power at the motor. This morning i've gone out to check for faults and the wipers worked fine. No blown fuses, all electrics work fine and there were no loose wires. Any ideas? The linkage jas been stripped and lubed previously. |
| FlacaProductions |
Jan 19 2020, 10:50 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,170 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
true early mirrors are a bit smaller.
they also have more of a sharp, right-angle bend on the arm - the late mirrors have more of a gentle curve. |
JFG screen wiper question Jan 12 2020, 08:50 AM
Bartlett 914
On new years day i took my car out. There was in... Jan 12 2020, 09:03 AM
Mark Henry
First suspect is a poor fuse connection. Clean t... Jan 12 2020, 10:52 AM
First suspect is a poor fuse connection. Clean ... Jan 12 2020, 02:05 PM
914Sixer + 1 on checking the 4 screws under steering wheel.... Jan 12 2020, 12:37 PM
JFG I've found replacement glass for the mirror bu... Jan 19 2020, 03:23 AM
Tom JFG,
Check J-13 relay on the fuse panel under t... Jan 19 2020, 11:41 PM
rosenfe I thought horn relay supplied power to fuse 8 Jan 20 2020, 10:44 AM
Tom Nope, horn relay (J4) is powered from top of fuse ... Jan 21 2020, 05:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th March 2026 - 12:35 AM |
